Sam's 110 resurrection - Page 4 - Defender Source
Old November 22nd, 2011, 10:03 AM
surf110's Avatar
surf110
Ze
130 Project
Looking good. Does it have a custom dash?
Originally Posted by One Ten View Post
Yeah, the roof is on. I'm so happy everything lined up. I like being able to see the outline of the truck. I need that feeling like i'm making progress to keep motivated.
Old November 22nd, 2011, 08:03 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
It will. That's a cardboard mock-up in the picture. I'm toying with different ideas
Old November 22nd, 2011, 11:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why the custom dash? Why not just go td5?
Old November 23rd, 2011, 01:19 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
How much is a td5 dash? I assumed they'd be to pricey.
Old November 23rd, 2011, 10:55 AM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah they would but I think after the work you did it would be worth it. Even using an original one like what came in the truck would be nice
Old November 23rd, 2011, 11:05 AM
Spring for the dash lest you end up looking like the below and totally ruin all of your hard work : ).
Old November 23rd, 2011, 11:15 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Wow. That's awful. I was gonna just do a flat panel out of stainless or aluminium instead of the dash tray.
Old November 27th, 2011, 12:31 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I finished making my rock sliders out of 1x3 square steel tube. I had to taper the ends of course. In an earlier post I showed how I remade the rocker panel out of 3/16 steel and left the outside leg long and put several holes in it for attaching the sliders from the back side with bolts. I tapped holes in the back of the slider. I also put a tab in the front which attaches through same bolt that holds the bulkhead to the frame. The back has L brackets that attaches to the rear frame outriggers. It's all pretty solid and as integrated as it gets IMHO.
I also had the crummy plastic coating blasted of the front brush bar. You know, the original coating that traps rust underneath. I then primed it with an epoxy primer, then two coats of black single stage automotive paint on it and the slider/rocker panel pieces.
Also finally put the boost wheels on. Just makes it in the garage. In fact the three supports on top of the roof slightly rub the rubber flap on the garage door molding at the top when it passes under. Talk about just fitting in.
Name:	2011-11-24 20.49.03.jpg
ID:	44127   Click image for larger version
Name:	2011-11-24 20.54.59.jpg
Name:	2011-11-26 08.36.25.jpg
ID:	44129   Click image for larger version
Name:	2011-11-26 15.51.44.jpg
Name:	2011-11-26 16.58.16.jpg
Old November 27th, 2011, 11:11 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Sam's 110 ressurection
Here's some pics of the backside of the slider.
Name:	slider back 009.jpg
ID:	44140   Click image for larger version
Name:	slider back 004.jpg
Old November 27th, 2011, 11:49 AM
specops1526's Avatar
specops1526
Beluga '97 90
I say spring for the Td5 dash or at least a year specific dash. After all that work it will look so much better.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old November 27th, 2011, 10:09 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I'm starting to think that may just be easier. You're slowly convincing me.
Old November 27th, 2011, 10:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
While we are at it. Ditch the brush guard. Your truck looks better without it. Plus if you ever hit something it is just going to bend into the nice paint.
Old November 28th, 2011, 11:12 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I'm leaving the brush bar. I like it.
Old November 28th, 2011, 11:15 AM
bjf's Avatar
bjf
barry f
94 ST #395
Well it all looks good either way
Old December 1st, 2011, 09:20 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I got the brand new rear door on. Just used sheet metal for an inside panel. Don't ask why the tire cover says "Santa Fe, New Mexico". It was free and it fits! Beggars can't be choosers. Ordered all new door seals from Safari HP. Should be here in a few weeks. Also gonna get a TD5 upper dash section from him too ($169). Think I can blend it with the existing and have a pretty cool look. Will take a little customizing. Can't afford the $1800 for the whole set up. That's a little too pricey IMHO
Name:	2011-11-30 15.26.52.jpg
ID:	44301   Click image for larger version
Name:	2011-11-30 15.27.18.jpg
Old December 8th, 2011, 09:42 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I got my new wing top protectors installed. I also reinstalled the sliding rear windows. I had to take them apart, clean, repaint, then reassemble. I put new felt in the sliding part too. Feels nice and tight but still allows the windows to slide open. Shouldn't have any window rattle. Now starts the wiring/ dashboard portion of the project. Oh boy.
Name:	2011-12-03 14.24.28.jpg
ID:	44551   Click image for larger version
Name:	2011-12-08 18.29.41.jpg
Name:	2011-12-08 18.30.19.jpg
Old December 9th, 2011, 01:24 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
Very nice and clean looking rig! And i really like the colour! I have seen one before and i really liked it.
i attached a pic for you. Maybe you like it
Old December 11th, 2011, 09:35 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
Great Craftmanship
I was hoping to look for a TDI engine implant but I discovered all the areas that I had been addressing. Well Done. The sill's I have to rebuild and attach them as well. Do you happen to remeber the dimensions for this?
Old December 17th, 2011, 08:05 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Wow! You are doing an amazing job on the build. I assume you're not married, or you have the coolest wife on the planet to let you work on that thing as much as you must be.
Old December 18th, 2011, 01:40 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
wife
Funny you should mention that. I am married and I thank her on a regular basis for letting me have this kind of project. She's a wonderful woman. I think she see's how much enjoyment and satisfaction I get out of doing this so she lets me. I fully realize that none of it would be possible if she wasn't so cool about it.
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
