Sam's 110 resurrection - Page 2 - Defender Source
Old October 24th, 2011, 07:35 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I used up the whole 5 gallons of Quietcar on these pieces then decided I didn't like the color gray so after letting it cure for a week I painted it all black then later went over most of that with Herculiner a few weeks later which will show up in future pics.
Name:	2011-09-03 16.16.18.jpg
ID:	43108   Click image for larger version
Name:	2011-09-03 16.16.31.jpg
Name:	2011-09-03 16.16.44.jpg
ID:	43110   Click image for larger version
Name:	2011-09-10 08.18.32.jpg
Old October 24th, 2011, 07:41 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I converted the front RR classic double line calipers into a single line via a T as can be seen in the pics. Installed brand new rotors too. Haven't tested it yet but I've been told by others who did this that it works fine. I also installed an adjustable brake proportioning valve for the rear axle because of having switched it to disc. I could take a pic of that if anyone wants it. Got it from Summit racing equip.
Name:	2011-09-04 12.54.56.jpg
ID:	43112   Click image for larger version
Name:	2011-09-04 12.55.44.jpg
Old October 24th, 2011, 07:48 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Got the hood, grill surround and a few other pieces painted. Bought new headlight cones and LED lights for the front. They look clear but light up amber.
Name:	2011-09-11 09.31.00.jpg
ID:	43114   Click image for larger version
Name:	2011-09-26 16.20.54.jpg
Old October 24th, 2011, 07:55 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Nice work! Wish I could move that fast! My 110 build is 4 + years in the making.
Can you explain why the need for the adjustable proportioning valve for the rear brakes?
Thanks!
Old October 24th, 2011, 07:56 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Had the sides of the tub and bottom supports blasted but completely replaced the floor with all new aluminum. I modified it to allow an access hole for the fuel pump like they do in RR's and Discos.
Name:	2011-09-29 20.00.24.jpg
ID:	43116   Click image for larger version
Name:	2011-09-29 20.25.05.jpg
Name:	2011-10-02 10.50.41.jpg
ID:	43118   Click image for larger version
Name:	2011-10-08 18.05.14.jpg
Old October 24th, 2011, 08:05 PM
california
Geoff M
This is so rad.
By that one pic where the body panels are hanging.... did you do the paint in the garage?
Old October 24th, 2011, 08:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
You are the second person I have seen to use those turn signals. They look cool. What did you use for the lights in the bumpers?
Old October 24th, 2011, 08:15 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Disc brakes do the same stopping as drum brakes but with less fluid pressure needed. If I didn't in stall it there's a good chance the back brakes would lock up when braking. The valve allows me to reduce pressure to the rear by up to 60%.
------ Follow up post added October 24th, 2011 05:17 PM ------
Yes, painting everything in the garage. The lights in the bumpers a just generic trailer type back up lights. I have amber ones too. I'm not sure if I want to make them turn signals or fog lights.
Old October 24th, 2011, 08:24 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Got the rear tub painted and did Herculiner inside it and on the new pieces I had cut for the floor. This is as far as I've got. Currently working on the B-post/sill pieces (or whatever they're called). I had mine media blasted and I'm rebuilding them with thicker metal on the sill piece and incorporating rocksliders into the design.
Name:	2011-10-15 15.08.04.jpg
ID:	43120   Click image for larger version
Name:	2011-10-15 15.08.26.jpg
Name:	2011-10-16 14.48.13.jpg
Old October 24th, 2011, 08:26 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Here's a preview. More pics and explanations to follow when they are done.
Name:	2011-10-23 13.50.52.jpg
ID:	43125   Click image for larger version
Name:	2011-10-23 15.14.36.jpg
Old October 24th, 2011, 08:29 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Very nice work with the rear floor, just to let you know the old S2's and S3's came with a cut out in the rear floor to gain access to the fuel sending unit and what not. It was square. The way you are working this project and quality I think you bought it like it was on purpose so you could say "Oh no damn'it, well better get to "fixing it right"." lol
Old October 24th, 2011, 08:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have seen it added to a 110. Very cool and smart.
Old October 24th, 2011, 08:41 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
This is kinda the look I'm going for. Maybe I'll be driving it by spring if I'm lucky.
ID:	43127   Click image for larger version
Name:	110 gerard.jpg
Old October 24th, 2011, 10:50 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Really nice job and I love that color! Keep up the great work.
Daniel
Old October 27th, 2011, 07:27 PM
surf110's Avatar
surf110
Ze
130 Project
What type of led lights are these next to headlight? Great build by-The-way.
Old October 27th, 2011, 11:13 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I got them on ebay from a place called closertowholesale.
Old October 28th, 2011, 10:42 AM
bjf's Avatar
bjf
barry f
94 ST #395
There is a place that makes LED versions of those flat lights. Front and back. Need to find the link.
Old October 28th, 2011, 11:05 AM
I'm not sure how I missed it, but this is the first time I have seen this thread. I love what you are doing to her!
Originally Posted by pendy
I'm here for the D's
Old October 28th, 2011, 12:53 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
They are LED's
Old October 28th, 2011, 01:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
oh there you go.
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
