RRC Heart Transplant - Defender Source
Old May 26th, 2015, 03:31 PM
boyrover
Sean
1996 Discovery
So on Saturday I started the process by removing the motor from the donor vehicle, a 1995 Discovery. 9 hours later I went home pictures follow:
All I can say is that those bellhousing bolts SUCK and that everything ever written about them is pretty much true.
Link to the truck that this engine is going into:
http://www.defendersource.com/forum/...ity-62236.html
ID:	121637   Click image for larger version
ID:	121639   Click image for larger version
ID:	121641   Click image for larger version
Old May 26th, 2015, 03:45 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What is the story with that E12? Beautiful car right there.
Old May 26th, 2015, 09:06 PM
carlosz's Avatar
carlosz
Carlos
the best way to attack those bolts is by removing the engine mounts as your first step. then the engine drops into the frame mount support and you acquire about 4 inches of room.
personally remove the top bolts first and then the bottom.
installation I hand thread the top bolts first, then do the bottom and last the mounts...
goes with out saying all the other details involved int removal of the lump....
good luck.
Old May 26th, 2015, 10:15 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I was just going to say what Carlos said- pic 5 & 6 show your motor mounts still attached to the motor.
That's why you had trouble with the bellhousing bolts.
What motor is going in the Disco?
That's a nice looking Conniston Green D1.
Rent my
Old May 26th, 2015, 10:31 PM
Yeh it sez to do that in the manual
Old May 27th, 2015, 03:03 AM
madcowdungbeetle
Carter
What's the story on the donor Disco? It looks nice...
Old May 27th, 2015, 04:39 AM
Ray_G's Avatar
Ray_G
Ray Gerber
That does look like a nice 95 Disco, would make for a good diesel swap candidate now that it has no heart unless it has catastrophic rust somewhere. While not as valuable as RRC's, unmolested D1's are getting harder to find too.
Old May 27th, 2015, 10:02 AM
boyrover
Sean
1996 Discovery
That is a nice e12, used to be mine. Long story short, it belongs to a friend, is a 1977 model and has around 100K on it.
I did see that passage on the motor mount removal in the shop manual, it made a lot of sense but when I got to looking at it on the truck it looked like the engine would sail right past those mount plates towards the ground. Maybe I miscalculated that though, I will have to try it when I remove the 3.9 from the RRC, do you lift the engine with an engine hoist or from underneath?
The donor D1 has a decent amount of rust in the frame, it is from Ohio and Pennsylvania. It isn't totaled but it IS rusty. Lots of good parts on it though.
Old May 27th, 2015, 10:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep...pull the rubber motor mounts out completely- allowing the motor to drop to the frame.
Then undo your bell housing bolts.
Do this for removal and reinstall.
Use a cherry picker/lift.
Rent my
Old May 27th, 2015, 10:48 AM
Just for taking out the engine rubber mounts, i will often jack up from below simply to have better access around the vehicle as I'm working. Once the mounts are out and I drop the engine onto the chassis, and get the bolts out, I'll move the hoist into place.
As a side benefit, having the jack below leaves it handy for putting under the transmission.
87 ex-mod heart transplant 2.5nad to 200tdi Cal Smaller Projects 99 June 10th, 2015 09:48 PM
300tdi transplant willtillery For Sale - Parts 8 November 1st, 2011 12:10 PM
Tony Fall dies of heart attack 61rover Misc. Chit-Chat 0 December 18th, 2007 05:12 PM
Body Transplant ajh Defender Technical Discussions 2 November 23rd, 2007 11:41 PM
video after my own heart, what a perfect combo! tkavan01 Misc. Chit-Chat 0 August 25th, 2007 07:44 PM
