rollover rebuild.. - Page 5 - Defender Source
Old September 24th, 2009, 11:26 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
OK MORE MORE MORE>> tonight was very productive thanks to my buds showing up...
Well tonight I took my 30 spline rear end out of the trug, I cut off the coilover tabs... next I took stock axle out, and I cut the coil spring perches off so I could weld them onto my old housing.. over all I think it came out AWESOME!! and i looks very clean and strong..
I still need to put on my new rear rovertracks links, but i was in a hurry tonight..
Also the rear springs are OME 762 disco front springs... In the rear they give it a perfect height. My new softer and shorter front coilover springs will be here tomorrow so it will be level..
ID:	21743   Click image for larger version
ID:	21745   Click image for larger version
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old September 26th, 2009, 10:40 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Looks nice....
Are you going to be able to pull that out of the garage when your done? Garage door looks low!!
Old September 26th, 2009, 11:25 AM
mightymg's Avatar
mightymg
Lane Farka
Originally Posted by Campbell
Looks nice....
Yeah I just lowered the front ,and I have the SW top off, Ill bolt that on out side..
OK more updates.. Yesterday I got my new upper coilover springs, so I got the front dropped about 2 1/2 inches, so its where its gonna stay for now.. wiht the flares on its a perfect lift height for the 37s..
ID:	21748   Click image for larger version
project whore!
95 RRC LWB-- DD
Old September 26th, 2009, 12:17 PM
marcingham
Marc Ingham
1967 IIA 88
I am loving this build up.
Q: are you going to do anything about sealing the coilover cut-out in the front inner wings/mudshields? We currently have a similar issue with a project and have all but decided to just leave it open, but I am still concerned about crap getting into the engine bay.
Old September 26th, 2009, 12:39 PM
mightymg's Avatar
mightymg
Lane Farka
Thanks!
As far as the front coilover I went a little plasma cutter crazy! Im gonna leave it open, I try to steer clear of mud as much as possible, so I dont think it will get to gummed up.. However it would be really easy to take some sheet metal and weld it in to the hoops, and the old original inners...
project whore!
95 RRC LWB-- DD
Old September 26th, 2009, 01:36 PM
I think you'll find you want to cover it. I ran without the stock covers for years before finally buying some (I guess the PO had aftermarket shocks and went back to stock for the sale) and even that little hole let in way too much mud.
How high is the top of the fender off the ground? It's hard to gauge the height.
charles
p.s. The shocks and mounts came today. thanks again!
Old September 26th, 2009, 05:06 PM
mightymg's Avatar
mightymg
Lane Farka
charles
Awesome IM glad the shocks made it!
The height is 52" to the top of the fender...
project whore!
95 RRC LWB-- DD
Old September 27th, 2009, 06:49 AM
Not bad. That's only 6" higher than mine with a 2" OME and half of that is likely in the tires.
Looking good!
Old September 27th, 2009, 09:35 AM
mightymg's Avatar
mightymg
Lane Farka
Looking good!
Good thats good info... .. Id still like it maybe an inch lower in the front, Im gonna wait to see where it all ends up once the winch ,cage and all the finish stuff is on...
project whore!
95 RRC LWB-- DD
Old September 27th, 2009, 11:14 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Mine's 49ish to the top of the wing with 32" tires.
That's an inch more lift than I have, leaving the tires out of the picture.
Not bad, but I know I want to be 1" to 2" lower.
Keith
Big, Red and ... aaa Red..
Old September 27th, 2009, 11:51 AM
mightymg's Avatar
mightymg
Lane Farka
Awesome thanks for measuring that man!
OK more updates yesterday afternoon I started working on my rear bumperettes... this is what I came up with, they will be welded on the rear crossmember just as if it were part of the crossmember itself..
ID:	21773   Click image for larger version
ID:	21775   Click image for larger version
project whore!
95 RRC LWB-- DD
Old September 27th, 2009, 06:03 PM
mightymg's Avatar
mightymg
Lane Farka
OK well i got the drivers side bumperette done and welded, I still need to attach it, but i can do that anytime...
ID:	21790   Click image for larger version
ID:	21792   Click image for larger version
project whore!
95 RRC LWB-- DD
Old September 27th, 2009, 06:48 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Inspiring! Nice thoughs.. I'll not deal with teh bling brackets, I'll probably use something subtle, Dimple died .0625: box sections.. Or maybe some gay 3/16" plates
Keith
Old September 28th, 2009, 12:46 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Lane,
I'm at 51" with fully inflated 40's! Better drop that biotch!
Originally Posted by redrockrover
Buck,
I have always loved your D-90. You have really taken it a long ways. Keep up the good work and the innovation. I love to see extreme D-90's and you probably have the most extreme D-90 out there. You represent a very limited extreme rover community very well at events like King of the Hammers. Just wanted to say I like your D-90 and always have.
Russ
Thanks a ton man. That is a very nice thing to say for sure. I really appreciate it!
Like with a penis cut out instead of a skull?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 28th, 2009, 01:13 AM
So how do you guys lower your trucks? Raise the top shock mounts?
I like the bumperettes, will do something similar with my trailer, but in 2x3.
Old September 28th, 2009, 01:32 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Coilovers are adjustable via an adjustment ring. Once you run out of that you can get softer springs, once you run out of that you have to relocate the upper or lower mount. They can actually be quite involved to get set up perfectly.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 28th, 2009, 07:47 AM
mightymg's Avatar
mightymg
Lane Farka
Exactly.. I have my adjusting ring all the way up, I think i can go a little softer on my primary spring if i had to, but i'm gonna wait til the cage is done to see where its at..
IM not looking forward to changing the height of my mounts! so im gonna avoid that at all cost.. i have it pretty much where i want it...
I think a picture of richard simmons would go nice on your 3/16!
project whore!
95 RRC LWB-- DD
Old September 28th, 2009, 09:45 PM
mightymg's Avatar
mightymg
Lane Farka
Well tonight I got all the front brakes done with new rotors. Tomorrow I will hook up my stock drive lines for now until I get some new ones, then I'm gonna bleed the brakes, and I should be all ready to drive this bad boy over to get the cage work done..
project whore!
95 RRC LWB-- DD
Old September 29th, 2009, 10:16 PM
mightymg's Avatar
mightymg
Lane Farka
Alright i see the light! Yeah I'M about to be able to drive this bad boy!
Tonight I got my brakes bled, the rear driveshaft hooked up, and I got my van sides in the mail, and I got them kinda bolted on..
Now at least I can get it over to my buds shop so we can make the cage next week!
heres some pics..
ID:	21822   Click image for larger version
ID:	21824   Click image for larger version
project whore!
95 RRC LWB-- DD
Old September 30th, 2009, 01:59 AM
michaels
mike
2004 DII
He is doing generation one. I think it looked quite nice. Pictures below. If your referring to generation two, then yes, I don't really think it looked all that nice either.
If your referring to generation three (last pic) then skrew you, your blind.
Gen III is the shit!!!!! i love your latest creation! maybe i just prefer soft-top defenders. i drove a 2 door soft top 200TDi this past weekend. i was in love! too bad it was RHD.
lookin' good laners! i think an SD style cage with your own touch will be tits!
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
