rollover rebuild.. - Page 16 - Defender Source
Old March 7th, 2013, 09:32 AM
I have this same problem. I get something all done, then I step back and look at it for a while, then I tear it all apart and do it over.
Old March 7th, 2013, 09:38 AM
That is an amazing amount of travel on the rear!
Old March 7th, 2013, 09:41 AM
Wow nice new garage! Room for everything it looks like.
Old March 7th, 2013, 11:58 AM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Originally Posted by woldd90 View Post
Glad to see you back... BTW, awesome garage.
THanks glad to bee back, as many of you know i did alot of builds on my rv pad, jsut over a year ago i built a new house and made my garage huge.. HA!! found a lift online used got it and off I went.. LOVE THE HOUSE!!
Garage is attatched The 3rd bay is 17.5 ft wide by 46 ft long, 18 ft ceiling, and my 2 car side is 28x26
The open peice of tubing needs to be capped and plated, thats the tube that the front heim welded too.
Ohh and I had a second baby in this time, a boy named Graham who is now 15 months!
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old March 7th, 2013, 12:25 PM
mightymg's Avatar
mightymg
Lane Farka
Few more pics...
My 57 rag top bug, rear tub fix where my dumb ass cut it.. front droop shot with out coilovers in, and that using the stock frame end pin and bushings.
Name:	bugwhite walls.jpg
ID:	67606   Click image for larger version
Name:	front droop.jpeg
ID:	67608   Click image for larger version
Name:	rear tub fix.jpeg
project whore!
95 RRC LWB-- DD
Old March 7th, 2013, 12:44 PM
mightymg's Avatar
mightymg
Lane Farka
The top set up works great, I just built 4 bars with tabs welded on them so it can bolt to the tub and top, then it holds it up with out the sides needed. Works great!
project whore!
95 RRC LWB-- DD
Old March 7th, 2013, 01:26 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Are you doing away with your aluminum surrey? (I saw your post that you were looking for a canvas setup.)
I've been thinking of doing a very similar setup for mine and wanted to hear your opinions on how it worked well or not so well. Thanks!
Old March 7th, 2013, 06:16 PM
mightymg's Avatar
mightymg
Lane Farka
I really love this setup for wheeling and cruising around. Was thinking for those crappy days wanting to go wheeling it would be quick and easy to throw on the soft top.
project whore!
95 RRC LWB-- DD
Old March 7th, 2013, 06:20 PM
mightymg's Avatar
mightymg
Lane Farka
More pics. Got the front arb third built and front shaft in. Also a few pics of the truck at full droop.
ID:	67646   Click image for larger version
ID:	67648   Click image for larger version
ID:	67650   Click image for larger version
project whore!
95 RRC LWB-- DD
Old March 20th, 2013, 08:58 AM
mightymg's Avatar
mightymg
Lane Farka
Steering finished, and winshield spreader built..
project whore!
95 RRC LWB-- DD
Old March 22nd, 2013, 10:07 AM
mightymg's Avatar
mightymg
Lane Farka
Rear cage removable cross bar X built, still need to finish the lower part to the floor.
And a few shots of it outside, I need to get all my gear in the back to see how it sinks, I need it to drop 2 inches back there to get my ride height correct, so hopefully the gear gets me close....
ID:	68651   Click image for larger version
ID:	68653   Click image for larger version
project whore!
95 RRC LWB-- DD
Old March 24th, 2013, 10:22 AM
mightymg's Avatar
mightymg
Lane Farka
Some flex shots
ID:	68878   Click image for larger version
ID:	68880   Click image for larger version
project whore!
95 RRC LWB-- DD
Old March 30th, 2013, 11:38 PM
mightymg's Avatar
mightymg
Lane Farka
More. Got the hydra assist on. Ohh ya ..
ID:	69301   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 3rd, 2013, 02:48 PM
mightymg's Avatar
mightymg
Lane Farka
Full belly and y link uhmw skid done
project whore!
95 RRC LWB-- DD
Old April 5th, 2013, 12:09 AM
mightymg's Avatar
mightymg
Lane Farka
Testing
ID:	69562   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 5th, 2013, 01:00 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Man that's something else! Looks Good!!
Old April 19th, 2013, 09:39 AM
mightymg's Avatar
mightymg
Lane Farka
K well moab trip went great other than a few minor/major issues( ha)
2 days in torsional sway bar broke, that makes a locked truck on coilovers go full flex on essentially every turn which is scary!!
day 4 trans shat out and i only have first and second gear, still got to finish wheelign though, PSC 'p' power steering pump is trying to die and my tcase leaks like a mother. Other than all that it was a blast!
my buddy mike also came down to play in bucks old 90 KOH buggy
ID:	70365   Click image for larger version
ID:	70367   Click image for larger version
ID:	70369   Click image for larger version
ID:	70371   Click image for larger version
ID:	70373   Click image for larger version
ID:	70375   Click image for larger version
ID:	70377   Click image for larger version
ID:	70379   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 19th, 2013, 10:16 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
wow you have done so much engineering on that truck. It's amazing. Good job
Old April 19th, 2013, 10:17 AM
Bill Larson
Bill Larson
That's some crazy slick rock wheeling...looks like you had a great time. Thanks for the photos!
Old April 19th, 2013, 11:30 AM
Wow. You western boys are crazy. Must get there and try it
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
