rollover rebuild.. - Page 11 - Defender Source
Old April 6th, 2010, 08:05 AM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
YEah Im just not sure exactly what it is.. HA!
I just went off what Dave told me. They need to be angled forward for geometry, plus I didn't want to cut into the inside of the tub, so thats where they ended up fitting.. Also if you look at all the desert race trucks and buggies they are all angled forward to help absorb stuff better, and to add to travel IM sure they know what they are doing...
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old April 6th, 2010, 08:09 AM
Yeah I don't know anything about it but they just looked a bit more angled than you usually see. I guess test the full range of motion before burning it in and you should be fine.
Old April 6th, 2010, 08:55 AM
mightymg's Avatar
mightymg
Lane Farka
Good call, i will. Looking at it all under there, I dont see naything it will interfere with. Its about the same angle as a factory shock... WE SHALL SEE!
project whore!
95 RRC LWB-- DD
Old April 12th, 2010, 09:11 PM
mightymg's Avatar
mightymg
Lane Farka
OK back to some tech.....
The upper rear coil over mounts are now completely burned in..
and the drivers side is now trimmed as shown in pics...
Left to do on the rear is
Weld in the lower links
install my new longer upper brake line
fill coil overs with nitrogen
bolt on the rear shaft
install the buck wild racing sway bar
clean up the fenders
trim the rear cross member on the inside ( touches tire on full tuck)
gusset coil over mounts
Not bad I say not bad....
ID:	26558   Click image for larger version
ID:	26560   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 13th, 2010, 07:57 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Question, in pic #4 the shock tabs are on the side of the shock... Wont that bind during articulation? Shouldn't it match the way the bottom mount is? Just curious....
Legend in My Own Mind.
Old April 13th, 2010, 09:28 AM
mightymg's Avatar
mightymg
Lane Farka
With the heim mis alignement washers it gives me the perfect amount of movement not to bind on full tuck. I took my highlift and flexed it just the be sure...
project whore!
95 RRC LWB-- DD
Old April 16th, 2010, 10:40 PM
mightymg's Avatar
mightymg
Lane Farka
OK got her outside, Got the shocks filled, and I got everything bolted up and burned in..
I still need to crank the coilovers to get one inch of lift in the front..
Heres a few pics...
ID:	26697   Click image for larger version
ID:	26699   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 17th, 2010, 07:34 AM
Sweet, although I maintain the right to change my mind until I actually see pictures on the trail instead of your driveway
Remind me where you are going with this build - is the top off temporarily or are you going to go topless now?
Old April 17th, 2010, 09:45 AM
mightymg's Avatar
mightymg
Lane Farka
Rights reserved!
Im gonna run the exo... Ill have the station wagon top on as acting as a surrey, with a bar in each rear corner holding the back pf the top up.. then im getting a tonneau from bobcat for over the back... Ill try to get the SW top on today to get a updated pic..
project whore!
95 RRC LWB-- DD
Old April 17th, 2010, 09:50 AM
mightymg's Avatar
mightymg
Lane Farka
heres the exo
ID:	26714   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 18th, 2010, 06:14 PM
mightymg's Avatar
mightymg
Lane Farka
Heres a pic with the SW top on acting as an aluminum surrey, which is how im gonna run it...
Also a pic of my temporary top bar until my bling ones are done.. this is about the only good use for a 24 spline rover shaft.
ID:	26755   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 18th, 2010, 07:51 PM
Definitely a different look. But I like it!
Aaaw, don't be hating.
Old April 19th, 2010, 01:11 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Somehow I think the look would seem more natural with ST doors so you could run the open window-free look but it looks great anyway. Do you have glass in them there doors? I'm not sure any of the pictures have shown side windows...
Old April 19th, 2010, 08:05 AM
mightymg's Avatar
mightymg
Lane Farka
Yeah the doors are complete. I have a set of ST doors, Maybe Ill throw them on for shits and grins...
project whore!
95 RRC LWB-- DD
Old April 22nd, 2010, 09:56 PM
mightymg's Avatar
mightymg
Lane Farka
( TRUMPETS SOUNDING!!)
NOW INTRODUCING>>> BUCK WILD RACING AND M-A ENGINEERING SWAY BAR!
OK sexy is an understatement..
Well its in.. as you guys can see it fits money in the back.. Now this fitment is perfect for a row truck, or a NAS truck that doesnt have the B-pillar under tub cross support.. Im still working on a placement for this on a standard NAS defender have faith i have a few ideas....
Heres some pics of the money set up!
ID:	26976   Click image for larger version
ID:	26978   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 23rd, 2010, 07:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
cool....keep us posted
Old April 23rd, 2010, 10:42 PM
mightymg's Avatar
mightymg
Lane Farka
OK the sway bar brackets are tacked in..
ID:	27010   Click image for larger version
ID:	27012   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 24th, 2010, 08:57 AM
Maybe I'm jumping the gun and it will be clear once it's complete, but I don't understand how this works and why you need it. If you can explain that would be great otherwise I'll wait patiently to see the end result
Old April 24th, 2010, 09:11 AM
mightymg's Avatar
mightymg
Lane Farka
With the spool and coil overs all the way around and the light spring rates, when i turn it force articulates it self and tends to have a decent amount of body roll on the street. This will massively control that..
project whore!
95 RRC LWB-- DD
Old April 24th, 2010, 11:30 AM
Aah ok. I was thinking this was a trailer queen.
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
