rollover rebuild.. - Page 10 - Defender Source
Old March 22nd, 2010, 09:23 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Squirrel!!!!!
Where!?!?!?! Where!??!?
Keith
Big, Red and ... aaa Red..
Old March 27th, 2010, 10:16 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Pics so far
ID:	26053   Click image for larger version
ID:	26055   Click image for larger version
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old March 28th, 2010, 09:00 PM
mightymg's Avatar
mightymg
Lane Farka
OK tonight i got the pass side link tacked in... I triangulated it as much as i could..
ID:	26092   Click image for larger version
ID:	26094   Click image for larger version
project whore!
95 RRC LWB-- DD
Old March 28th, 2010, 09:03 PM
Nice. I like the fact you loose the "ears" that usually hang below the frame too. By triangulated, you mean pushing the axle mounts out as far as possible?
Old March 28th, 2010, 09:29 PM
mightymg's Avatar
mightymg
Lane Farka
Yes, Dave ( buck on 40s) said when he triangulated his it made a huge difference yn the geometry. I guess it handled a ton better. So we will see
Hes also sending me one of his new Billet bling bling sway bar setups that hes having made for the defenders.. pics to follow..
------ Follow up post added March 28th, 2010 09:31 PM ------
Also those weld on ears that i used are made by ballistic fab, and are like 20 bucks or soemthing like that.. all laser cut and very sexy..
http://www.ballisticfabrication.com/...41_p_1174.html
project whore!
95 RRC LWB-- DD
Old March 29th, 2010, 10:25 PM
mightymg's Avatar
mightymg
Lane Farka
Tonight i got the frame plated, and the link brackets burned in..... Came out pretty good...
ID:	26146   Click image for larger version
ID:	26148   Click image for larger version
project whore!
95 RRC LWB-- DD
Old March 30th, 2010, 09:26 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Post pix of the sway bar when you get it. sounds interesting.
Legend in My Own Mind.
Old March 30th, 2010, 10:16 AM
mightymg's Avatar
mightymg
Lane Farka
I will, im hoping to have it next week, its all machined with alluminum arms, very very slick set up..
project whore!
95 RRC LWB-- DD
Old March 31st, 2010, 12:32 AM
mightymg's Avatar
mightymg
Lane Farka
OK well my a arm extension is now done 2.5 square tube .25 wall.. So After i re drill my axle brackets, and burn them in all the way, the back is done underneath and ready for body work.. then its time to plumb the cell, mount the seats, build the belly skid, install my bling sway bar, and i should be out testin her...
ID:	26177   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 2nd, 2010, 08:42 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow. Really nice fab work - looks so clean. I've been following the build on pirate as well and was shocked at the folded frame pics that buck posted. Never thought the rover frame was that thin. Makes sense to plate the mount areas.
Like Randy I'm very interested to see how that sway bar comes out.
Old April 2nd, 2010, 08:48 PM
mightymg's Avatar
mightymg
Lane Farka
OK more updates.. the new fuel cell is now Plumbed mostly... i still need to finish the lines at the pump, but that 5 minutes...
Anyways as you can see it think it came out extremely clean. I ran it through the inside bed rail support, so it out of the way and protected.
Also heres a pic of of where in gonna cut the fenders...
ID:	26244   Click image for larger version
ID:	26246   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 2nd, 2010, 10:22 PM
I like your routing of the lines, but you know you can't fit a tailgate without mods to now right? Just asking because someone I"ll leave nameless made a bottom mount for his trailer lid hinge in a similar location and forgot to take into account the tailgate clearance properly. But I know you are smarter than that.
Can't wait to see it cut - then it'll "feel" stretched to me.
Oh and I love that a-arm extension!
Old April 2nd, 2010, 10:43 PM
mightymg's Avatar
mightymg
Lane Farka
THanks..
more pics in 5 minutes.. the CUT HAS HAPPENED!!
project whore!
95 RRC LWB-- DD
Old April 2nd, 2010, 10:51 PM
mightymg's Avatar
mightymg
Lane Farka
OK heres some shots of the rear with the tailgate on, and with a 110 bench placed in the back, where in gonna put it for passengers in the rear..
Also heres some pictures of the plumping, I decided to reuse the factory filter, so this is how it looks...
Also the cut! heres the pics of the preliminary cuts i still have some touching up to make it look perfect, but heres a teaser...
I also cut it just short if the lights and cover so it can all be be hidden when the plastic light cover is on...
ID:	26251   Click image for larger version
ID:	26253   Click image for larger version
ID:	26255   Click image for larger version
ID:	26257   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 3rd, 2010, 07:20 AM
You go girl!
Old April 5th, 2010, 01:59 PM
mightymg's Avatar
mightymg
Lane Farka
Heres a teaser of the swaybar arms...
project whore!
95 RRC LWB-- DD
Old April 5th, 2010, 09:57 PM
mightymg's Avatar
mightymg
Lane Farka
OK heres a mock up of the rear coil over mounts.. REMEMBER KEY WORD MOCK UP>>
Its all just tacked, the lower arm supports need to be cut down, gussets need to be made, and there will be a cross support bar to the other one that goes through the tub and will also double as the rear seat harness mounts..
ID:	26379   Click image for larger version
project whore!
95 RRC LWB-- DD
Old April 5th, 2010, 10:13 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I'll bitch..
I think you should add a tube on each side of the hoop down to the frame (plated of course) There's gonna be a hell of a load and flex there!! Especially if you want to keep up with me in the fast stuff!
Keith
Old April 5th, 2010, 10:19 PM
mightymg's Avatar
mightymg
Lane Farka
i CONCUR! MORE GUSSETS TO COME..
project whore!
95 RRC LWB-- DD
Old April 6th, 2010, 07:54 AM
Coming along nicely. Is there any science to the angle of the coils?
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
