Rebuild and Tdi Conversion Pix - Defender Source
Old December 10th, 2005, 01:32 AM
I've got a shed-load of pix from the rebuild and I've never gotten around to finishing the website I started, so I'm just going to post a heap of pix here. They aren't necessarily in rigorous order and I'll throw in comments as appropriate. I'll also probably get banned from the site because of bandwidth issues...
First row is how it started - George at RDS had a galvanized rolling 300tdi chassis "on sale" - I bought it so I could build up my project and keep the Rover on the road.
Row two: So I got about cleaning up and painting everything. I wanted the chassis to be black so I painted it with POR15 and POR15 Chassis-Coat. I painted the axles and suspension parts the same way.
Third row of pix: After a while I finally got the motor and it wasn't long before I had it in the chassis. Its much easier to move a 600 pound motor on wheels than on a pallet.
Row four: At this point it was time to start tearing the old girl apart. Evilfij came down and shoved the entire v8, r380, and lt230 into the back of his LWB fully assembled. I'm glad he was the one taking it out at the other end...
Row five shows the stacking of the driveline and the installation in the chassis. It was lots of fun trying to get the crossmember into the chassis, I had to use the hydraulic ram from the engine lift to spread it apart a wee bit to get the thing to go in.
Row 6 - more teardown, the bulkhead gets is own little wheelie cart. This proved very convenient for working on it.
Row 7 - setting up the side tank - I used an aircraft-style filler cap from MOCAL - great stuff.
8 - More teardown
Nine - the bulkhead needed some work to fix some spilled hydraulic fluid problems. I also cleaned up what little rust was there and went to town with clear POR15. The front part I repainted with color-matched spray cans from Tower Paint and then clearcoated with 2-part catalyzed clear from POR15. Note that the v8 air cleaner bracket had to be removed.
row 10 - very exciting stuff - I had to cut off the 300tdi sway bar mounts since I wanted to remount my NAS tank. Pendy made sweet replicas of the NAS tank brackets that I bolted onto the chassis. It took a lot of playing around to get the alignment correct, but once it was all together it looked great with one of Dave Lucas' stainless skid plates installed. I then primed and painted the brackets before installing.
11 - installing brake lines, mmm sweet. These are all stainless back from when ECR would actually sell them to you. I used braided stainless lines sourced from EE.
Row 12 - setting up the chassis, wiring, fuel lines, plumbing the bulkhead and motor. Its amazing how long it takes to do all these little things...
13 - the seatbox had to be modified with the removal of the passenger side locker to accomodate the secong fuel tank. Removing the locker involved drilling out some rivits and cutting some spotwelds, removing all the adhesive gunk crap involved hours of crummy scrubbing. Fortunately, my wonderful wife stepped up to the plate! After everything was done, the underside of the seatbox and floors were rhino-lined.
14 - tail lights light up, diesel sticker applied, and it starts to look like a truck again. This is where your friends come by, cheese for the camera, and make completely predictable Flintstones jokes.
Row 15 - damned thing started on the first crank.
Last Row - after its running it all gets down to little stuff. Time to do some upholstery, install checkerplate, hood release lever, etc. Now its all fun and games as I work out all the kinks over the next few hundred miles.
Name:	Resized_Chassis Topv1.jpg
ID:	4499   Click image for larger version
Name:	Resized_Chassis Drivers Sidev1.jpg
ID:	4502   Click image for larger version
Name:	Resized_Chassis on Trailer 2v1.jpg
Name:	Resized_Etched Chassisv1.jpg
ID:	4504   Click image for larger version
Name:	Resized_Rear Crossmember 3v1.jpg
Name:	Resized_Chassis Front without Suspensionv1.jpg
ID:	4506   Click image for larger version
Name:	Resized_Radius Armsv1.jpg
Name:	Resized_Ugly Front Axelv1.jpg
ID:	4508   Click image for larger version
Name:	Resized_300 Tdi on Pallet 1v1.jpg
Name:	Resized_300 Tdi on Pallet 3v1.jpg
ID:	4510   Click image for larger version
Name:	Resized_300 Tdi on Pallet 4v1.jpg
Name:	Resized_300 Tdi on Crane 2v1.jpg
ID:	4512   Click image for larger version
Name:	Resized_Tdi on Frame 3v1.jpg
Name:	Resized_Grill Gonev1.jpg
ID:	4514   Click image for larger version
Name:	Resized_Naked Front Endv1.jpg
ID:	4516   Click image for larger version
ID:	4518   Click image for larger version
Name:	Resized_Tdi r380v1.jpg
Name:	Resized_Tdi r380 with Bellhousingv1.jpg
ID:	4520   Click image for larger version
Name:	Resized_Installing lt230 and r380 1v1.jpg
Name:	Resized_Installing lt230 and r380 2v1.jpg
ID:	4522   Click image for larger version
Name:	Resized_Tdi Driveline Installedv1.jpg
Name:	Resized_Removed Front Rollcagev1.jpg
ID:	4524   Click image for larger version
Name:	Resized_Front End Offv1.jpg
Name:	Resized_Bulkhead Rearv1.jpg
ID:	4526   Click image for larger version
Name:	Resized_Bulkhead on Cartv1.jpg
ID:	4528   Click image for larger version
Name:	Resized_Side Tank 2v1.jpg
Name:	Resized_Tank Capv1.jpg
ID:	4530   Click image for larger version
Name:	Resized_Side Tank 3v1.jpg
Name:	Resized_Fuel Valvesv2.jpg
ID:	4532   Click image for larger version
ID:	4534   Click image for larger version
ID:	4536   Click image for larger version
ID:	4538   Click image for larger version
ID:	4540   Click image for larger version
ID:	4542   Click image for larger version
ID:	4544   Click image for larger version
ID:	4546   Click image for larger version
ID:	4548   Click image for larger version
ID:	4550   Click image for larger version
ID:	4552   Click image for larger version
ID:	4554   Click image for larger version
ID:	4556   Click image for larger version
ID:	4558   Click image for larger version
ID:	4560   Click image for larger version
ID:	4562   Click image for larger version
Name:	Resized_Seat Box Ultimate Linerv2.jpg
ID:	4564   Click image for larger version
ID:	4567   Click image for larger version
ID:	4569   Click image for larger version
Name:	Resized_Running Defenderv3.jpg
ID:	4571   Click image for larger version
Name:	Resized_Road Testedv2.jpg
ID:	4573   Click image for larger version
Name:	Resized_Exmoor Seatsv2.jpg
Name:	Resized_Engine Bay 2v2.jpg
ID:	4575   Click image for larger version
Name:	Resized_Engine Bay 1v2.jpg
Old December 10th, 2005, 06:51 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Jim,
What an amazing project! How long did it take you? Nice work too.
Do you have any more of those LR "diesel" stickers left? If not where did you get it?
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old December 10th, 2005, 10:49 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Man,
All that AND a 110 on the way. Nice Jim, Nice...
"It's not a Jeep"
Old December 10th, 2005, 11:10 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I soo need a better paying job!!!
Jimmy Buffett
Old December 10th, 2005, 11:52 AM
To answer Sheki - I collected parts through most of the first half of 04. I brought the chassis home in April but the motor didnt arrive until August. I worked on the truck basically every weekend (for approx 15 hours per wkend) from Sept-January. So 5 months of weekends and a few months prep.
And I'm not exactly made of money - my wife and I are Army officers - the pay is fine but this consumed all my disposable income for the better part of a year. I also dont have any new car payments, children, or anything like that.
The 110 isnt going to come together nearly as fast...
Old December 12th, 2005, 05:00 PM
Sheki - the sticker came from George at RDS - I'm sure he'll have more when he opens back up - it cost like a dollar-fifty.
Old December 13th, 2005, 02:26 AM
sheki's Avatar
sheki
David Shechter
okay, thanks. I have my list of parts for him, just one more to add.
Old December 13th, 2005, 09:50 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
That hood release is far to bling.
Nah you wont get banned. I will most likely pull the pictures from the forum DB and redo the write up like I do the Trip gallerys to save load on the DB performance though. I think I should do that to Randys as well. Looks like might be enough going on to finally get the "Large projects" section going.
Chris von C
[/size]
Old January 9th, 2012, 11:11 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
well thats neat
Old January 10th, 2012, 04:58 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
very nice.
conversion, rebuild, tdi
1971 Ser IIa Custom Coil 88 with Tdi TDI Guy For Sale - Vehicles 67 January 18th, 2010 10:40 AM
300 Tdi, 2.5 NA and R380 for Sale moose For Sale - Parts 23 August 18th, 2008 01:10 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
