Rear frame work on NAS Defender 90 - Defender Source
Old December 12th, 2014, 07:52 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Started the rear cross member replacement today. Cut out all existing rear member, sand blasted trailing arms and rear bumper for paint. New rear frame member is galvanized and includes rear shock mounts.
The rest of the frame is in extremely good condition but when all is back together I'm having a full WaxOyl treatment done for rust proofing and black coating of the under carriage.
Old December 12th, 2014, 10:02 PM
Make sure to grind the galvy off the ends where you weld.
Old December 12th, 2014, 10:39 PM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Ugh, this is exactly the repair I need. Dreading it.
Old December 12th, 2014, 11:48 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You're lucky it's just this, and not the entire chassis.
Old December 13th, 2014, 12:40 AM
wmatos1001's Avatar
wmatos1001
William
I know I am lucky. We have been through the rest of the frame and it really is quite good. The only other thing that needed replacement is the tubular bar that bolts to the body and frame just forward of the rear wheel well. That bar was fine except both end where it bolts to the body were pretty rotted.
Although it is expensive I'll be happy when it is all done.
Old December 13th, 2014, 08:49 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
While you have the back portion removed and out of the way are there plans to take a look inside. That's usually where all the big trouble starts.
In an ideal world one would allocate some resource to the frame's interior as well I guess.
Clay
Old December 13th, 2014, 08:51 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Come on down i actually enjoy doing chassis repairs
and you can pick up you door hinges .....LOL
No Mall crawler here
Old December 13th, 2014, 11:32 AM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Originally Posted by rovertek View Post
Come on down i actually enjoy doing chassis repairs and you can pick up you door hinges .....LOL
HAHA, I know Chris! I'll shoot you a text this week, we have to set something up. Hinges for sure and talk about my cross - which I can put my fingers through. LOL.
Old December 13th, 2014, 07:23 PM
wmatos1001's Avatar
wmatos1001
William
Here are some more shots of the tub bar mount replacement, under carriage and the old rear frame member. Definitely needed to come out!
ID:	108607   Click image for larger version
ID:	108609   Click image for larger version
ID:	108611   Click image for larger version
Old December 13th, 2014, 07:28 PM
wmatos1001's Avatar
wmatos1001
William
I did my hinges myself for what its worth and I'm not very mechanically inclined. With a lot of research me and my wife were able to get a near perfect paint job on them, drilled out or removed the stubborn bolts, put new captive nuts in where needed and got it all done. Took a good part of weekend but was really rewarding when we were done and saw it all finished. We did all three doors.
As for the rear member, I do think Atlantic British now sells just the rear cross member, not the frame from the rear shock mounts back. I haven't priced it out but imagine since it is just the rear part that sits behind the bumper it must be cheaper. On my vehicle that very rear most part was the worst but I figured since I'm going in I might as well get it all done.
Good luck with whatever you chose and if you decide on doing hinges yourself and want advice/tips just shoot me a PM and I'll give you my cell #.
Old December 14th, 2014, 12:04 AM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Originally Posted by wmatos1001 View Post
I did my hinges myself for what its worth and I'm not very mechanically inclined. With a lot of research me and my wife were able to get a near perfect paint job on them, drilled out or removed the stubborn bolts, put new captive nuts in where needed and got it all done. Took a good part of weekend but was really rewarding when we were done and saw it all finished. We did all three doors. As for the rear member, I do think Atlantic British now sells just the rear cross member, not the frame from the rear shock mounts back. I haven't priced it out but imagine since it is just the rear part that sits behind the bumper it must be cheaper. On my vehicle that very rear most part was the worst but I figured since I'm going in I might as well get it all done. Good luck with whatever you chose and if you decide on doing hinges yourself and want advice/tips just shoot me a PM and I'll give you my cell #.
Awesome! Thanks Will I will definitely take you up on that offer!
Old December 14th, 2014, 03:27 AM
Chip's Avatar
Chip
Andrew
Did you lower the gearbox crossmember and check the chassis there? That's where mine rotted away.
Old December 14th, 2014, 09:55 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Do you guys add a plate(s) on the outside of the frame rail when butt welding the new frame section in? I swear LR designed that rear cross member to catch and hold mud. I SMH every time I look back there.
If you have time, might be good to get those tub bars galvied. Speaking of which I will have to do my tub supports when I do the body swap next spring.
Nice to see those crispy frame parts taken out.
Old December 14th, 2014, 10:23 AM
No the replacement cross members slide over the existing frame with about 6" overlap.
Are they re-using the existing fuel tank hangers? If not, hang onto those as someone else could surely use them.
Originally Posted by pendy
I'm here for the D's
Old December 14th, 2014, 01:46 PM
wmatos1001's Avatar
wmatos1001
William
No not yet but we definitely will thanks for the tip!
------ Follow up post added December 14th, 2014 01:51 PM ------
I will inquire about the plate(s) on the outside of the frame rail. Good idea to keep that mud out. Also the tub bars are not galvanized and are already in so too late for that. But the new tub rail is actually two sections and slide into each other in the middle. My mechanic hit the inside of the tub rail with rust proofing (waxoyl) and once the rear member is on and everything is buttoned up he is hitting the whole under carriage with waxoyl again. So i'm hopeful I will be able to keep rust at bay with that and good under carriage cleaning after off roading or winter driving.
Old December 29th, 2014, 10:28 AM
BrianKelley
Brian Kelley
94 Defender 90 NAS
Just finished doing this repair as well. I opted to take off the rear tub to get a better look at the frame (a full waxoyl treatment is planned because of this,) I was prompted to do this when my rear skid plate protecting the gas tank had rotted out. So in total, I've added in rear crossmember w/ 15" extensions, new brackets to mount skid plate, as well as custom aluminum skid plate.
Probably much more too....fun project, good luck with yours.
ID:	109623   Click image for larger version
Old December 29th, 2014, 10:42 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Are we not going to mention the car in the background....
Old December 29th, 2014, 10:51 AM
BrianKelley
Brian Kelley
94 Defender 90 NAS
Smile
Oh yes, that's my buddy's Factory Five super car that he's building. Talk about the opposite ends of the transportation spectrum all in the same garage!
90, defender, defender 90, nas
NAS 110 frame needs bulkhead outrigger and rear crossmember $400 or labor philly evilfij For Sale - Parts 5 October 7th, 2013 07:59 PM
What wheels work with a NAS 90 bikerblock Defender Technical Discussions 4 March 22nd, 2012 12:46 PM
1997 NAS frame vs a Richards galv frame? tomaco1 Defender Technical Discussions 1 November 13th, 2011 05:41 PM
NAS V8 tach- will it work with a Tdi ? Uncle Douglas Defender Technical Discussions 6 January 30th, 2009 03:13 PM
Rear Work Lamp rover4x4 Misc. Chit-Chat 5 February 19th, 2005 12:41 PM
