re-drilling the swivel balls - Defender Source
Old August 4th, 2008, 09:40 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Finally fired up the Cummins 4BT that's sitting between the frame rails on my 109 five door. Now it's on to the rest of the drive train.
I'm also going spring over at the same time. And will need to adjust the pinion angle accordingly.
Has anyone on this board use RoverTym for redrilling their swivel balls? Are you satisfied with the work. I was a bit concerned about the accuracy/tolerances.
I hope to post some pics of the project next weekend. Other things that are going in to this.
Cummins 4BT
SM420 Transmission
Divorced mounted LT230
Salisbury Axles Front and Rear
Spring over suspension with 88" rear springs on the front
Old August 4th, 2008, 09:12 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Lets see some pix
Legend in My Own Mind.
Old August 4th, 2008, 10:06 PM
I have a friend who has the castor corrected swivel balls on his disco with 5 inches of lift and 35s. He said the truck drives great and tracks straight @ 75 mph. Kicked my 110 around pretty good @ Pearls Pond in June.....
Old August 5th, 2008, 08:28 AM
slorocco
Dan Prasada-Rao
I'll try to get some pix up this week. It's torn down pretty far so there's not much to see as far as a finished product yet.
Doug, thanks for the feedback. I may try that. I'm considering two options, one is the castor corrected swivel balls the other is to re drill the flanges on the ends of the axle tubes. The second method would allow the use of stock swivels.
I have to laugh at the 75mph thing. With my drive train, this thing will be stump puller but it will probably never make it over 55mph.
Old August 5th, 2008, 07:08 PM
DEF110's Avatar
DEF110
Vern Lawrence
1983/ 110
What is your drive train behind the Cummins 4BT? what sort of adapter are you using for trans?
test
Old August 7th, 2008, 03:01 PM
slorocco
Dan Prasada-Rao
I found a 4BT that came out of a 1989 Chevy P30 stepvan. It already had the chevy adapter, flywheel, starter, and clutch.
The stock tranny behind it was an SM465 but that was gone. I'm using an SM420 that I already had laying around. It bolted right up.
The LT230 is divorced with a little stubby driveshaft running to it from the SM420. From there I'm running into salisbury series truck axles front and rear with stock 4.7:1 gearing.
Old August 9th, 2008, 06:05 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
What is the difference/benefit to redrilling the swivel balls rather than getting corrected radius arms?
Old August 10th, 2008, 06:23 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Keeping a good pinion angle.
Matt Browne
Old August 14th, 2008, 08:50 AM
slorocco
Dan Prasada-Rao
The way I see it, using the radius arms maintains the angle/relationship between the pinion and the caster. Redrilling the swivel balls allows you to re-orient your pinion angle and then re-establish the correct caster angle.
Old September 26th, 2008, 05:00 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Ah... I think we're talking leaf springs....109" is a series truck.
But I might be wrong
Mike Hammond
Old October 22nd, 2008, 06:54 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
did it with my 5" springs, drives normally again. Not sure about RTE since it sold, but Jordan was with Steve for a while so I assume the process is still the same.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old October 23rd, 2008, 11:56 AM
slorocco
Dan Prasada-Rao
Yup, I talked to the new owners of RTE at the Mid Atlantic Rally. They still offer the service. I'm going to run them as is for now and see how it does. I've got the stock axle set in place with about 4 degrees of caster. The pinion is pointing lower than i want but I'll see how it does before I disassemble the front axle and have the swivel balls drilled.
I am running a leafer here with the axle moved to a spring over configuration with the springs bolted on top of the axle tubes instead of below. I figure that gave me about a 5.5" lift over stock.
This front Salisbury axle is interesting. It's a leafer axle with the 4.7:1 gearing but it's running CV joints instead of U-joints in the front axle shafts.
Old October 23rd, 2008, 02:52 PM
mikeslandrover
Mike Hammond
Could the axle be from a stage 1 v8?? They were permanent 4x4 but I can't remember the ratio.
Mike Hammond
Old October 24th, 2008, 04:36 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
the stage 1 V8 109" had 3.54:1 diffs (in the rear salisbury as well) and 11" export spec drum brakes on the front.
It also had tracta joints in the front axle, enabling the full time 4wd without any "kick back" through the steering wheel.
Old October 24th, 2008, 05:19 PM
mikeslandrover
Mike Hammond
Couldn't remember but I suspected 3.54:1. Owned a stage 1 Sandringham Six for a while, it was a monster
Mike Hammond
Old November 17th, 2008, 11:44 AM
slorocco
Dan Prasada-Rao
Well, I took it out on the trails for the first time this weekend. This cummins motor has some grunt! As for the front axle, I haven't pulled it apart to see what's really inside there but looking in the oil fill port, it looks like it's got a true CV joint as opposed to some of the other options.
I'm told there's a video posted on you tube at the following link. I'm at work and can't access it from here.
http://www.youtube.com/results?searc...rch_type=&aq=f
Rovertym castor correct swivel balls D90user Defender Technical Discussions 6 August 29th, 2006 01:10 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
