Re-build of B777 ONR - Page 2 - Defender Source
Old July 5th, 2013, 01:09 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Finally had a chance today to make up my OBA system box, sits behind the pass seat built into the front of the wheel well, enough room for the bigger ARB compressor and tools.
I have added a picture of the outside panel that shows the outline with rivets for the internal box.
This mod will not work with NAS as you need this area for the under tub support bar. But as BONER is a homeland LR90 which did have a bulkhead its the best place to put the comp. Wasted space anyways.
The SD roll cage RBL092 will reconnect the sides and roof in nearly the same place as the B/H so the cage will stiffen it all up again. (BUT still waiting on shipping notice of the cage SAFARI HP)
Next areas to get done is a locker fitted under the "what was the middle seat" just gotta work on the hinge placement and a under floor tool/storage box at the rear of the tub, where the NAS LR's have a fuel tank. Should be a good size this one.
Name:	05-jul-13 001 (1024x768).jpg
ID:	75422   Click image for larger version
Name:	05-jul-13 002 (1024x768).jpg
Name:	05-jul-13 004 (1024x768).jpg
ID:	75424   Click image for larger version
Name:	05-jul-13 005 (1024x768).jpg
Name:	05-jul-13 006 (1024x768).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 8th, 2013, 11:57 PM
roverman2010
1985 LR 90 200Tdi
Roll cage
Fitting SD LR092 roll cage, been slow going as the instructions supplied are worthless. The rear Diagonal braces where they go thru the rear wheel boxes need very careful measurements as the supplied measurements are wrong.
Need to make extra cover plates to hind the extra cuts.
But in all pretty good, need to weld on some light mounting bracket tabs on the top windshield bar sometime. Not fitted by SD
Name:	13-aug-13 039 (1024x768).jpg
ID:	79311   Click image for larger version
Name:	13-aug-13 040 (1024x768).jpg
Name:	13-aug-13 057 (768x1024).jpg
ID:	79313   Click image for larger version
Name:	13-aug-13 067 (1024x768).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 9th, 2013, 12:46 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
man great work! keep the pics coming!
Old September 9th, 2013, 08:18 AM
I have never seen that particular cage before. Is the cage close enough to the seat backs to impede reclining them back ?
Old September 9th, 2013, 09:42 AM
roverman2010
1985 LR 90 200Tdi
Doug, no this cage sits four inches back and was one of the reasons I wanted this one. I had to get rid of the bulkhead to have the seats slide back and recline some. The tub sides bolt to the cage which returns some of the stiffness that the B/H did.
thanks ya'll
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 9th, 2013, 10:05 AM
That's quite an interesting cage!
It looks like SD used a different approach for this design. One-piece bars straight through the front wings and a massive internal hoop. Looks to be similar to and/or based on the Series land rover cages they build.
They certify the cage as an "8 point cage", as opposed to the full exo design which looks to be a 6-point.
Old March 18th, 2014, 10:28 AM
roverman2010
1985 LR 90 200Tdi
fitting the IG console
updated photos
Fitting the Iron Goat console. I have no worries about cutting into the dash parts as this console will be a great asset having extra switch places, never did like those pod things you stick on top of the dash.
The hardest part of fitting the console is starting. take the "hockey stick" off and remove the grey vent panel as these can be cut later if you so wish so. I forgot to say throw those bloody directions away.
When you have those bits off you can offer the support frame up, you will have to pull the lower dash down a bit, I loosened the screws a bit. with the support panel in place you can now see what has to be cut. Cut on the big size as you can trim it later. I did use double sided tape and the back of the support panel to hold it in place while drilling the holes out for the screws.
I do intend pop riveting it in place once all has been done.
It really boils down to using common sense, and a sawsall. when you are happy with the fitting of the support panel just take your time cutting the rest to fit. some say you can leave the gray vent panel in place.
Name:	18-mar.14 019 (1024x768).jpg
ID:	91427   Click image for larger version
Name:	18-mar.14 020 (1024x768).jpg
Name:	18-mar.14 022 (1024x768).jpg
ID:	91429   Click image for larger version
Name:	18-mar.14 024 (1024x768).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 18th, 2014, 08:14 PM
roverman2010
1985 LR 90 200Tdi
Had a chance to get my towing arrangements sorted out on the rear crossmember, and modified the right hand side rear corner protector so I can get the tyre carrier on bolted back on.
ID:	107106   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 18th, 2014, 08:24 PM
UKmtrsp
Chip
95 RR Classic
Looks like a XKE in the background...what else do you have in that shop?
Old December 15th, 2014, 09:38 AM
roverman2010
1985 LR 90 200Tdi
More Rover bling thanks Santa
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old December 15th, 2014, 09:43 AM
roverman2010
1985 LR 90 200Tdi
second try
Name:	imagejpeg_0 (1024x579) (800x452).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old December 15th, 2014, 10:29 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looking great! Like the OBA fab work. Is that hitch custom? Looks like you could pull a house down with it!
Old December 15th, 2014, 10:46 PM
cbfritz_03
Carmen
none
And a Merry Christmas to you too. She's a drop dead gorgeous truck. Well done lad...
Old December 19th, 2014, 02:50 PM
roverman2010
1985 LR 90 200Tdi
Thanks Don, yes the hitch was made in house the cross bars to the chassis also serve as mounting points for the long range fuel tank protector plate.
The hitch will serve my purpose well.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old January 10th, 2015, 11:16 PM
roverman2010
1985 LR 90 200Tdi
Ol' Red
New plate fitted
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 3rd, 2015, 10:01 PM
roverman2010
1985 LR 90 200Tdi
B777 onr
Says it all
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 1st, 2015, 12:33 PM
roverman2010
1985 LR 90 200Tdi
Ol Red
More bling
in my time I have had three tanks split so I think this one should out live me I hope
ID:	114931   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 13th, 2015, 12:10 AM
roverman2010
1985 LR 90 200Tdi
Just wanted to post up a couple of pictures of two of three of my blue sea fuse boxes, first one sits on a bracket bolted the the brake servo, the relays are fitted behind the plate. this powers head lights, cooling fan and with two spare.
The other fuse panel sits on a bracket behind the heater fan unit the relays sit under the panel, this powers the roof lights, driving and/or fog lamps & horns with two spare spaces.
The third panel will be in the battery box to power compressor, fridge & misc
This sort of ties in with Chris Snells post "Battery Box Redux" using blue sea fuse panels
I am not finished yet, the reason from some un-secured wiring
ID:	115971   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 22nd, 2015, 11:12 AM
roverman2010
1985 LR 90 200Tdi
bonnet opener
Was looking for solution for opening the bonnet before fitting my new heritage grille. Was putting a new pull cord to my weed cutter, and hey brillant idea use the old pull cord. The picture is worth a thousand words
Took the tumbler out of the bonnet lock to pass the cord through
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 20th, 2015, 09:04 PM
roverman2010
1985 LR 90 200Tdi
Photo shoot scarr 2015,
ID:	118865   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Re-build of B777 ONR roverman2010 Defender Technical Discussions 10 February 11th, 2013 04:46 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
