R/V A/C system on D110? - Defender Source
Old May 17th, 2017, 05:16 PM
EricTheRed
Eric
1993 Range Rover
Ok, is this a stupid idea? I do have a factory A/C system in my 110. It is pretty much a joke. I live in Southeast Texas and it gets HOT! I was thinking of installing an R/V rooftop air conditioner system. I am assuming I will need an inverter and a two battery system. I also go camping quite a bit and want to be able to use it while camping. Sooo back to my original question. Is this a stupid idea?
Old May 17th, 2017, 07:25 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RV AC is a bad idea.
What system do you have?
We are in VA and it gets hot here.
Our Diavia AC was so cold it would freeze humidity mid air.
RDavisinVA
Old May 17th, 2017, 08:52 PM
EricTheRed
Eric
1993 Range Rover
UNDERSTOOD! I am not sure what system it is. A friend of mine said it was stock in many NAS Defenders. My truck is a hodgepodge of parts. Most being from a 96. It is a squareish box on the firewall with A/C vents on the dash. The pictures are what the truck looked like when I picked it up. Looks way nicer now.
ID:	245394   Click image for larger version
Old May 17th, 2017, 09:03 PM
phoenix37's Avatar
phoenix37
john
Looks like the same in dash system as the NAS 110s...The under dash units like the one Robert is describing are much more efficient. Or you could take it up a notch and get a Red Dot.
Old May 17th, 2017, 09:26 PM
First stop would be making sure it is all working correctly.
Old May 17th, 2017, 09:42 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
That's the dash mounted unit which I am not familiar with.
We had a Diavia unit like the one in the pictures.
In my humble opinion the way to get efficiency is air flow through the condenser.
We never run a clutch fan.
Instead we have a 12V cooling fan behind the radiator and a 12V fan in front of the condenser.
When you turn on the AC both fans run providing instant cold air.
When the AC is off, a thermo-switch turns both fans on and off to cool the engine.
As John suggested, make sure your existing AC works and if broken fix it.
RDavisinVA
Old May 18th, 2017, 05:11 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Pictures that accompany post 6.
This was before I trimmed and installed the fuse cover.
ID:	245450   Click image for larger version
RDavisinVA
Old May 18th, 2017, 08:50 AM
EricTheRed
Eric
1993 Range Rover
I have a new fan clutch, and 2 new condenser fans. The system is operating ok, however I had to rebuild the interior of the evaporator/blower motor box. The blower motor was frozen and the plastic framing broken beyond repair. The parts are unubtanium. I improvised a blower motor but it is only achieving 150cfm. That is not enough. I do not have any other ideas to replace the original blower motor assembly. Please do not berate me for my ingenuity!
ID:	245570   Click image for larger version
Old May 18th, 2017, 08:52 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Did you look into insulating your seat boxes? A lot of heat comes in that way also. Once the A/C is functioning you then need to seal up the truck to keep that cold air cold.
Old May 18th, 2017, 08:54 AM
Ah, well, all the information makes a difference in the advice. Then you are just needed to figure out a working blower. If you went that far, I'm sure you can figure out how to add a proper fan.
Old May 18th, 2017, 09:07 AM
EricTheRed
Eric
1993 Range Rover
Ok, I am still looking. Seems all I have to work with is 3". I can achieve 100cfm+ more if I could go to a 4". I have scoured the internet, I guess I need to dig even deeper. Anyone have an original blower motor hanging around??
110, ac, d110
'94 D-90 full A/C system for sale max For Sale - Parts 2 March 15th, 2012 09:24 PM
Rear A/C system Uncle Douglas Defender Technical Discussions 16 December 9th, 2011 11:34 AM
'95 Defender A/C System: Complete Bozman For Sale - Parts 2 January 11th, 2007 12:24 PM
WTB Complete A/C system lrnasd90 Wanted 12 October 24th, 2006 08:39 AM
NAS 110 A/C System newfD90 Misc. Chit-Chat 18 September 2nd, 2006 11:21 AM
