Puma Dashboard Swap - Page 2 - Defender Source
Old October 16th, 2017, 05:28 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Originally Posted by Puma Upgrades View Post
I can't see why not.
Fitting the dials shouldn't be an issue.
How do they operate? Bearing in mind that the early Defender Speedos were cable driven and they had no Rev counter.
Ground speed radar for the speed and then alternator feed for the revs I presume?
Does it come as a full kit with all of that, plus the actuators for the fuel and temp, etc?
Jonathan,
The Dakota Digital brand instrument clusters have been used in conjunction with GM gen IV/LS style engine swaps on defenders. The kit comes with the corresponding senders and adapters for various engines, or you can get a module to read and display information via the can bus (obd2). The DD cluster is not really necessary for the LS swap but it gives you a little more information in one place than using something like a number of VDO gauges. There's a member who used the cluster I posted a pic of on a Puma dash swap, so maybe it would fit in yours as well.
Old October 16th, 2017, 10:03 PM
ron's Avatar
ron
Ron
1995 110 Beach Runner
nice work
good luck with your search
Old October 17th, 2017, 12:04 AM
MCMLXIX's Avatar
MCMLXIX
Rich
The link below is the website for the cluster with all the details. It comes with adapters and you can use a black box to convert the cable to digital signal. I was asking more for the LSx swap crowd.
VHX-1018: Universal 4.4" x 11.4" Rounded Rectangle, Analog VHX Instrument
------ Follow up post added October 16th, 2017 09:06 PM ------
Originally Posted by Macker View Post
Or this one
I think this cluster is too large to fit even the PUMA style dash.
Old October 17th, 2017, 12:39 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Bet you could make it fit. Thereís a user that fit this Camaro style one which is even larger. This was during his build process, never saw it when it was done.
Old October 17th, 2017, 12:40 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
This is the one I meant to post. The first one may be the wrong shape to fit.
Old October 17th, 2017, 12:55 AM
MCMLXIX's Avatar
MCMLXIX
Rich
That was for the Marquez Design 1969 Camaro custom dash.... I don't think the Marquez is still in business which means the dash may no longer be produced....
Old October 17th, 2017, 01:02 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Itís on their website and available through over a dozen retailers online.
Old October 17th, 2017, 01:17 AM
MCMLXIX's Avatar
MCMLXIX
Rich
It’s on their website and available through over a dozen retailers online.
I was in the Pro-Touring scene for a while. They had some issues with actually producing the product. Maybe they got it sorted and are managing the company better...
Dakota Digital still has it on their website.... and the description says the include a template... Maybe they would be willing to email a copy to see if it would fit. It looks like it would blend in great with the Puma dash...
The billet aluminum faceplate is powdercoated flat-black and features intricate machining to create a unique multi-layered look. Measuring in at 16" x 7.25"H
VHX-1200: 1967- 69 Marquez Designs Camaro
Old October 17th, 2017, 02:46 AM
WessonGroup
Karl
1983 Land Rover 110
Subscribing. Do you have a plaine black dash in stock?
Old October 17th, 2017, 02:52 AM
Puma Upgrades
Jonathan Bowman
Defender 90
We make them to order and 90% of them go out as plain black.
3-4 weeks waiting time right now for the DIY kit.
------ Follow up post added October 17th, 2017 07:57 AM ------
It does look nice, but would be too wide to fit based on those measurements.
And it's 'only' $1095.00
Is it worth it?
We did this one last week using the standard gauges...
Ministry of Defender
Old October 17th, 2017, 03:21 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Is it worth it?
Surely there are cheaper alternatives... but with all the money a stateside defender owner would be saving buying your dash vs. a new take off tdci bulkhead and dash, it would certainly be in budget. As mentioned already, it would be mostly appeal to the LS or Cummins r2.8 swap crowd.
Old October 17th, 2017, 03:24 AM
Puma Upgrades
Jonathan Bowman
Defender 90
That's a good point actually. Our complete dash kit costs $1100 which is nothing compared to buying a Puma bulkhead etc.
I'm used to dealing with Brits with no money.....
Old October 17th, 2017, 10:42 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I thought the stock Puma gauge cluster would work with an LS if the CanBus adapter was installed?
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old October 28th, 2017, 06:53 PM
Puma Upgrades
Jonathan Bowman
Defender 90
That's an option, but we just like to keep it simple and retain the original gauges; just wrap them in a Puma shell.
Keeps it easier for a DIY fit.
Old November 3rd, 2017, 06:30 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Nah, we're just tight!
Old November 9th, 2017, 05:49 AM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, 86 D110, 97 Hummer H1
Nice looking product.
Old November 9th, 2017, 09:20 AM
Belize Defenders
Jad
1993 110
I'm discussing with Jonathan and we need to work out the shipping to Belize, but will probably pull the trigger on this this week for shipment thru Miami in January.
I'll make sure to post a full install report with pics when I am done. It will be on my 92 D110. As I have A/C & heater there is an additional part that I need to acquire as well. I can't post a link yet, but it is a T7 designs heater/Aircon combination unit.
I'm just trying to figure out options for upholstery and/or painting...
Old November 9th, 2017, 09:32 AM
Chris B
72 + D1 drivetrain =?
These guys? http://www.t7design.co.uk/
Old November 9th, 2017, 10:11 AM
Belize Defenders
Jad
1993 110
Yes, that's the one.
dash, dashboard, puma
roof rack swap RiMiD814 For Sale - Parts 2 March 5th, 2006 12:04 AM
Frame Swap and Endcaps??? TurkD90 Defender Technical Discussions 10 December 31st, 2005 11:21 AM
Thinkin' about an engine swap! rustydefender Misc. Chit-Chat 11 June 17th, 2005 09:30 AM
TCase Swap Doug For Sale - Parts 5 June 10th, 2004 07:51 PM
» Defender Registry
DRAB
speedpin
Frosty
don
Add your Defender
