Project Zambesi - Td5 NAS 110 - Page 2 - Defender Source
Old September 6th, 2008, 11:38 PM
surf110's Avatar
surf110
Ze
130 Project
Originally Posted by diesel_jim
It's looking very smart.
'tis a good feeling when you fire the lump up for the first time isn't it? The Td5 sounds good as well, doesn't it?
funnily enough, i recorded my exhaust today to see what the turbo whistle sounds like (i've got a standard non cat downpipe, standard 110 middle silencer, and a straight out stainless V8 sports tail section i used to have on an old 110)
sounds pretty good!
I've got to ask... you fitted a panel in the rear tub to get to the fuel pump... what did you use for the actual removable piece? thats just what i want to do to mine. i suppose any round piece of steel or ali would do, but yours looks like it's got a recess punched in it?
cheers
Jamie
Yes. It was great hearing that turbo whine.
I have a stainless exhaust from a V8 that I'm thinking about using with the Td5 non cat down pipe.
I was looking at Td5 Alive the other day and their exhaust looks really good. Pricey.
Is it easy to find Td5 exhausts over there?
I used a Range Rover Classic fuel pump cover. Just go to a scrap yard and get one. That fuel pump access already saved me the hassle of dropping the fuel tank. We had the fuel lines crossed and it was getting very low fuel pressure. Checked the diagram plugged them correclty and it started right up.
I miss seeing your 110 project on lr4x4. Do you have a place where I can see what you've done lately?
Old September 7th, 2008, 04:25 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yes, the Td5 alive stuff looks good, but like you say, pricey.
a good friend of mine works at landrover on the engine development department, and he worked on the Td5, and hence know it inside out.
he says that one of the best value for money systems, is a non cat downpipe, the middle silencer "removal" pipe (like one of these and a plain rear system.
The pipes on a Td5 are 2.5", so is the Td5 alive one, so unless he has really smooth curves i don't think you'll gain that much.
But getting Td5 stuff here is easy. on ebay (like the link above) there's plenty. go to UK ebay "Td5 exhaust"
I was at a breakers yard today and they had a rangie in there! damn! i'll go back tomorrow and get it!
I removed my build up from the LR4x4 as there's been a lot of defender thefts in the UK, and i figured i was "advertising" mine a bit too much.
I'll PM you some photo's and an update.
Old September 7th, 2008, 08:34 PM
surf110's Avatar
surf110
Ze
130 Project
Great. I'll check uot those links. Thanks.
Old December 4th, 2008, 01:00 AM
surf110's Avatar
surf110
Ze
130 Project
It is drivable now.
Just updated the site.
http://gallery.mac.com/zduarte#100036
Old December 4th, 2008, 02:26 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Great work, love the attention to detail. Always nice to see some passion in good craftsmanship. Keep it up and keep on posting.
Pat
Kirk Lazarus, Tropic Thunder
Old December 4th, 2008, 10:18 AM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
I really like your truck. Nice 5 bar rubber in the back.
Are you one of those guys that enjoys building it and then sells it shortly after or plans to keep it forever?
Old December 4th, 2008, 10:49 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Wow it looks beautiful. What size tires and springs are in there?
Old December 4th, 2008, 11:28 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Beautiful. What did you guys do with the rest of the hi-cap parts?
Chance
Old December 4th, 2008, 02:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
That thing is insane. Looks like a fairly inexpensive project!!
Love the wheels and the exhaust
Old December 4th, 2008, 10:14 PM
surf110's Avatar
surf110
Ze
130 Project
Pat
Coming from you is a great compliment. Great job on your crew cab.
If I can get double of what I put into it, I'll sell it. What are the chances of this happening? NEVER.
BFG 285 KM2s
I still have them. And a NAS 110 chassis complete with drivetrain and rusted bulkhead. Was thinking of building it, but might sell. Are you interested?
Yes indeed!
Old December 4th, 2008, 11:37 PM
tommyd's Avatar
tommyd
Tom
LR3
Outstanding work! Beautiful truck. Great color, love the wheels. Love to see it next time I'm in San Diego...
Old December 5th, 2008, 12:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
When will the cage go back on?
Old December 6th, 2008, 08:49 AM
Hey, why don't we move a bunch of these photos to this site? It makes them a little more perpetual in case you change your hosting or something and gives us a nice archive - if you aren't against it, but don't have the time, I can work on it.
Old December 6th, 2008, 02:15 PM
Retrofit's Avatar
Retrofit
Pat
I second that !
Pat
Old December 6th, 2008, 03:05 PM
surf110's Avatar
surf110
Ze
130 Project
Jim. I can put the images on an FTP site for you to download. Do you want all of them?
I didin't want to flood Source with so many photos.
Soon.
Old December 6th, 2008, 03:11 PM
Yes, and FTP would be ideal. Then I'll go through them and put up a nice selection.
Old December 8th, 2008, 07:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
Are your fenders euro specs that you cut holes in for the roll cage?
Old December 9th, 2008, 09:37 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You can buy the fender skins off the shelf for Td5/300Tdi (with the air intake hole on the RH side) and cut-outs for the rollcage (bear in mind they'll have the Td5 shaped hole for the turn-light repeaters too)
RH wing ASB710480 (used to be ALR7974)
LH wing ASB710490 (used to be ALR7975) both are 91.40 UKP (each)
These are used on the G4 and defender "black" special editions (plus numerous others i suspect with the front cage on)
Old December 9th, 2008, 12:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ah that makes things easier if you are switching a NAS90 to a diesel and you don't want to use a snorkle. Certainly easier to and cleaner to use td5 turn light repeaters than to cut air intake hole in the NAS fender. Well easier for most.
Old December 13th, 2008, 12:59 PM
surf110's Avatar
surf110
Ze
130 Project
PM sent a few days ago with instructions.
Yes.
110, nas, nas 110, td5
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
90/110 project wanted (NAS or import) mlepisto Wanted 13 June 22nd, 2004 08:56 PM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
