Project "Orvis": The Un-Argentinizing of a 107 - Page 3 - Defender Source
Old July 15th, 2011, 08:15 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
A few pics from this morning...
ID:	40332   Click image for larger version
Semper Fi!
Old July 15th, 2011, 06:33 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by Wolf Fabrication View Post
This is as good as it gets.
J,
I know it is your truck but you have an awesome looking truck that it doesn't deserve those wheels/tyres.
Maybe the tyres but I will put back on the original rims..so freaking sexy without the wholes
NO SIGNATURE
Old July 15th, 2011, 06:46 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Rugbier View Post
J,
Yes Goose, I know. The Wolf rims are temporary until I find correct Series I rims. The ones I took off are not correct.
Semper Fi!
Old July 18th, 2011, 10:43 AM
Wolf Fabrication
Sterling Archer
'08 D3
Just got this pic of the 107 in Argentina prior to restoration.
Semper Fi!
Old July 18th, 2011, 03:07 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I've got a set of 7.50 XZL's on 5.5" wheels that make their way on to the 80" from time to time.
They fit fine...I've cheated and use the 1-1/16th lug nuts from a II that still fit the small studs...but are just tall enough to rub on the frame without steering stop adjustment..
Unless you're really set on the 4.5" rims, don't discount using 5.5" ones.
Old July 18th, 2011, 05:16 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Didn't the 107/109" have a 5.5" wheel with a lot of inset that looked like a 4.5" wheel when fitted? I had one such wheel a long time ago, got rid of it - it did nothing for the turning circle.
Mike Hammond
Old July 18th, 2011, 07:14 PM
Wolf Fabrication
Sterling Archer
'08 D3
I believe you are correct, which is why I like running the Wolf rims.
Semper Fi!
Old July 18th, 2011, 10:07 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There have been a seemingly lot of series 1 parts for sale on the uk ebay site.
Old July 19th, 2011, 10:44 AM
Wolf Fabrication
Sterling Archer
'08 D3
Finally got my crate of small bits for the 107. Got the crossmember grab handles, all 4 interior door pulls, interior S2 rearview mirror, and drivers side mirror installed. Also found an original grill badge that turned out pretty good after a repaint. sanding, and polishing.
ID:	40469   Click image for larger version
ID:	40471   Click image for larger version
Semper Fi!
Old July 19th, 2011, 12:26 PM
mikeslandrover
Mike Hammond
Looking good
Mike Hammond
Old July 30th, 2011, 03:39 PM
Wolf Fabrication
Sterling Archer
'08 D3
Finally finished the install of the Koenig crank driven winch with cab controls, as well as the refurbishment and installation of an original rear step.
Next up: tranny swap
ID:	40697   Click image for larger version
Semper Fi!
Old July 30th, 2011, 04:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Great looking Rover. Not too often am I really envious. This is one instance.
For period correct tires there's Avon Traction Mileage from Vintage tires. For less money there's a close look-a-like from Specialty Tires of America. http://www.stausaonline.com/light-tr...r-traxion.html
If you are interested unusual period wheels I have a set of two part rims (PN 217267) I'd consider parting with.
If you aren't familiar with them, they look like this.
http://i134.photobucket.com/albums/q...e/100_1134.jpg
http://i134.photobucket.com/albums/q...e/100_1133.jpg
They were designed for 6.00x16 or 7.00x16 but I always ran 7.50x16's on them without issue.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 30th, 2011, 04:53 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
That's a massive winch! Is it heavy? Looks Good!
Those are some pretty cool looking rims Tom. What years / models did they come on?
Old July 30th, 2011, 04:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
Winch weighs 217lbs with the massive mounting plate.
They look to be split (military style) rims. More correct for early Series Is.
Semper Fi!
Old July 31st, 2011, 08:17 AM
Antichrist's Avatar
Antichrist
Tom Rowe
They were used on '49's and in to the '60's. They were an option for civilian. The military used them more.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 31st, 2011, 06:49 PM
airbornrover
William Skidmore
SIII 109 SW
Thing is looking like a monster.
Old August 1st, 2011, 06:22 PM
Wolf Fabrication
Sterling Archer
'08 D3
This is why I love Rovers. I had the seatbox, floor, and tranny/tcase out in less than 2 hours.
So if it wasn't obvious, I am swapping in a new tranny....
ID:	40796   Click image for larger version
Semper Fi!
Old August 1st, 2011, 06:38 PM
James Pierce
James Pierce Jr.
So what took so long? Did you fall asleep on your creeper again?
Old August 2nd, 2011, 12:14 AM
Clean, grind, POR15/primer/rust converter/paint the top of the frame while you are in there. I have seen the frames rust out on the top under the bulkhead area. I would also spray waxoyl into the holes on the top, especially the curved outriggers. Clean out the drain holes under it first.
Hope to see you soon, but I doubt you will drive that truck up my way (although I would love to see it).
Old August 2nd, 2011, 07:52 AM
Wolf Fabrication
Sterling Archer
'08 D3
Won't waste my time. There is galvanizing in the frame's future!!! But this frame is strangely solid with only a few minor issue.
Semper Fi!
orvis
Friends I greatly need your votes for a family project draaronr Misc. Chit-Chat 33 October 29th, 2010 10:23 AM
I have a project in mind EndlessEarth4WD Misc. Chit-Chat 23 July 21st, 2008 06:29 PM
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
