Project "Frank" - The Un-Gaying of a 110 - Page 9 - Defender Source
Old May 25th, 2010, 08:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
whats that tool look like?
Legend in My Own Mind.
Old May 25th, 2010, 08:11 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
The tool makes is much easier. I can't believe I have been using two flat head screwdrivers and lots of cuss words for years until I got the tool.
Semper Fi!
Old May 25th, 2010, 08:24 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
cool... you have a link to that sucker
Old May 25th, 2010, 08:42 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
http://www.lislecorp.com/divisions/p...=1&category=12
Old May 26th, 2010, 12:16 AM
Did you buy it online? I hate to pay $10 to ship a $15 tool.
Old May 26th, 2010, 12:34 AM
Rugbier's Avatar
Rugbier
Gustavo
Ron,
get a local mechanic friend to get it from Snap On, got mine for 22.00
NO SIGNATURE
Old May 26th, 2010, 08:09 AM
I had two Annapolis glass shops tell me they couldn't get the locking strip in unless I took the cage off first-neither would even try. Punks
Old May 26th, 2010, 08:13 AM
Wolf Fabrication
Sterling Archer
'08 D3
They are just lazy. It was a little hard to get the tool under the cage and on one side I had to use screw drivers under that portion, but it's not impossible. I cut the holes in the top and installed two windows in just under three hours.
Semper Fi!
Old May 31st, 2010, 12:21 PM
Wolf Fabrication
Sterling Archer
'08 D3
The next project on my list was to design and fabricate some frame sliders. I've learned the LR frames are pretty thin and vulnerable, especially in the middle area that seems to get high centered a lot. My design was simple: 2"x2" 1/8" thick angle iron clamped to the sides of the frame (notched to fit around obstructions), and then 1/8" plate welded to the bottom. This gives the bottom side a thickness of 1/4" but keeps the sides thin. The sliders were bent to fit the curve of the frame and bolted on with grade 8 hardware.
I am still trying to figure a way to build a small skid plate for the e-brake drum.
ID:	28136   Click image for larger version
Semper Fi!
Old May 31st, 2010, 12:44 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There was a write up done on the CROC website a couple of years ago i believe with a lightweight being the vehicle. Also seen pics of skidplates for series on either TNTLR orrrrr one of the comp/safari builder websites in the UK. Sorry for the vagueness.
Old May 31st, 2010, 12:59 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks, I think.
Semper Fi!
Old May 31st, 2010, 01:03 PM
Rugbier's Avatar
Rugbier
Gustavo
Neat .. I like
NO SIGNATURE
Old May 31st, 2010, 11:15 PM
I like it. But besides preventing damage to the frame rails, isn't one of the ideas behind the frame sliders to also smooth out the transition to the suspension ears? That's the place you are most likely to get hung up on.
Oh, how much did they end up weighing?
Old June 1st, 2010, 06:42 AM
Wolf Fabrication
Sterling Archer
'08 D3
You are correct. On my truck I was more concerned with the soft frame and less with the rear link ears. I don't mind dragging those and mine have developed a "natural" curve. Expanding the frame sliders to cover the ears is the next project however.
I didn't weigh them, but they are likely about 10lbs each.
Semper Fi!
Old June 2nd, 2010, 04:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks solid. I'd be interested in seeing how the next set looks as my ears got a little 'adjustment' last time out.
Man - I need to get a welder. My buddy can TIG like a wizard but just being able to make stuff out in the garage would be the treats.
Old June 2nd, 2010, 06:12 PM
Wolf Fabrication
Sterling Archer
'08 D3
Next up, shifting the angle of the Equipe front skid plate. I have the Equipe competition front bumper with steeper approach angle and a tighter fit, but was only able to get the regular Equipe front skid plate (I was told Equipe does not make a competition skid?!). As you can see in the first pic, the front skid left a huge hole in front of the bumper and looks awkward, so my solution was to cut the mounting brackets down and re-weld them.
I cut about 1" out of the front of the brackets and a pie shape out of the rear of the brackets and bent them up about 1". I ground off the zinc coating and re-welded. The welds were covered in gold spray paint and clear coat to make a close match to the zinc coating.
It looks a little better now...
ID:	28238   Click image for larger version
ID:	28240   Click image for larger version
Semper Fi!
Old June 3rd, 2010, 11:10 PM
Don
Rockware makes them for the 90's.
Old June 4th, 2010, 11:28 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Ren - I'll give them a look at.
Old June 6th, 2010, 05:32 PM
Wolf Fabrication
Sterling Archer
'08 D3
The next item up for modification was the crossmember. It seems like the stock crossmember always ends up being an anchor and my e-brake drum likes to drag on the rocks. My solution was to raise the rear end of the drivetrain up (I noticed my motor leaned back about 5 degrees) by building a new crossmember.
My "stock" crossmember was actually welded in by the a$$hole that did my drivetrain swap, so I spent quite a while cutting it out and grinding the mounting plates flat (I kept the mounting plates welded to the frame and just cut out the crossmember). Next, I built a crossmember out of two sticks of 2" DOM tube with a chunk of 1/4" angle iron welded to the leading edge. Why did I use 2" tube? I didn't have any square tube!
I tossed the stock LR tranny mount in favor of an Energy Suspension GM tranny mount. Switching mounts saved me 2" already, and the new crossmember shaved off about 2". Overall I raised up the e-brake drum about 2", and I can still raise it up another 1" with a spacer to get it level with the frame - at that point the fan hits the shroud. I'll see how this works out and if I still drag on stuff.
ID:	28310   Click image for larger version
ID:	28312   Click image for larger version
ID:	28314   Click image for larger version
Semper Fi!
Old June 6th, 2010, 08:15 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Looks good man! It's nice seeing mods done to actually enhance off road prowess, instead on "bolt on " stuff.
Maybe I missed it, but have you done anything to protect your tie rod?
Dig the frame sliders, you're right about the frames being thin,.... found that out this weekend in my D2.
What tree?
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
