Project "Frank" - The Un-Gaying of a 110 - Page 5 - Defender Source
Old January 26th, 2010, 09:28 AM
Yeah that's my concern. If the pin depth is too much, then standard hitch pieces may not work. I really want it for my own attachments if say for example I get in a position where I'd need to pull it from the rear, so I guess as long as my stuf works I'll be ok
Old January 26th, 2010, 09:36 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Standard stuff should be long enough, you just need to drill a new hole farther back.
Signing off, boarding a 14 hour flight to Dubai. Uggggh.
Semper Fi!
Old February 8th, 2010, 03:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
Took advantage of the snow day to take care of the little projects.
1. I got the Cobra 75 CB installed (anyone have an antenna tuner???). I found a nifty warning label on ebay to at least make the thieves laugh before they steal my antenna.
2. I installed a MUD UK dash pod for the EGT gauge and eventual ARB switches and boost gauge
3. Discovered that the axle breathers are the same thread as the ARB fittings, so I ran remote breathers to the snorkel.
ID:	25015   Click image for larger version
ID:	25017   Click image for larger version
Semper Fi!
Old February 21st, 2010, 02:11 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Something you might want to do is either weld a guard onto the cage in the back that comes up and over the hi-lift (like a pinion guard) or cut it down so that it is below the height of the top of the roof in the back by a couple inches. I've seen photos of people who've been leaning over or just driving along and caught their carrier mounted hi-lift onto something less than flexible... not pretty.
Old February 21st, 2010, 03:02 PM
I like the receiver in the cross member, just don't think it would be strong enough for the stuff I do like pulling a car trailer with a 110 on it or aggressive kinetic rope recoverys- the cross member itself can't (hasn't in my case) taken the full load there, the load needs to be tied back up the frame rail to spread the load further up the frame and keep the whole rear crossmember from twisting downward.
See signature line below....
Old February 21st, 2010, 06:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
You are absolutely right. But, keep in mind all the pintle hooks and bolt on receivers that bolt directly to the crossmember. None of those spread the load.
I am designing and building some c-shackle swivels similar to the Equipe design that bolt through the large holes on either side of the cross member.
------ Follow up post added February 21st, 2010 06:26 PM ------
You mean like this? (see below) Already done long ago.....
Semper Fi!
Old February 21st, 2010, 06:29 PM
Wolf Fabrication
Sterling Archer
'08 D3
Got the diesel gas can mount welded on today. It's attached directly to the tire carrier with some 1-1/4" .120 wall square tube. The can mount itself is removable.
ID:	25340   Click image for larger version
Semper Fi!
Old February 21st, 2010, 06:41 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Be interested in seeing some pics of these when you're done, if they are what I am thinking. Looking to remove my rear step and considering options for rear recovery point(s).
Ian
Old February 21st, 2010, 08:13 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Where did you get that can?
Old February 21st, 2010, 08:22 PM
Wolf Fabrication
Sterling Archer
'08 D3
It's a "Briggs & Stratton" can I painted yellow. But it looks like a Sceptor.
Semper Fi!
Old February 22nd, 2010, 10:00 AM
These guys will check/set you gear with an SWR meter for free.
http://www.google.com/search?q=manas...uto+outfitters
Old February 25th, 2010, 11:49 PM
crown14's Avatar
crown14
Verticalscrote
I thought you were trying to un gay it
Old February 26th, 2010, 12:46 AM
Scepter poser or is that posuer
Old February 26th, 2010, 07:41 AM
Wolf Fabrication
Sterling Archer
'08 D3
Actually, I am completely wrong. It's a Wedco can I painted yellow. Briggs and Stratton sells the Wedco can under their name. See the attached pic from EE. You can get the Wedco can at your local Ace Hardware by the way.
Semper Fi!
Old February 26th, 2010, 08:39 AM
Actually its poseur. But yellow is the correct color for diesel cans be they scepter, wedco, or plastic hardware store non-jerry-can shaped things. I wouldn't have bothered but to each their own. I have three and they are black.
Old February 26th, 2010, 08:43 AM
Actually I have been wondering why you want to take a happy truck and make it un-happy anyway?
ROFL
Wolf Fabrication
Sterling Archer
'08 D3
You ever put diesel in a gas engine? Not pretty! I had a buddy get same color jerry cans mixed up on a trail ride in Moab and one of the guys put diesel in his Jeep. A tow ride home and $2k later everything was fixed. I'll stick with the proper can marking.
Semper Fi!
Old February 26th, 2010, 09:19 AM
Rugbier's Avatar
Rugbier
Gustavo
Or you could simply mark the Jerry Can with a decal oh lets say .. " DIESEL FUEL ONLY " around the neck, but that it is not applicable to GAY CARB Cans *LMAO*
NO SIGNATURE
Old February 26th, 2010, 09:21 AM
Wolf Fabrication
Sterling Archer
'08 D3
So why did you sell your red Wedco cans then? "LMAO"
F all of you. Don't you have anything better to do than haze me on a Friday?
Semper Fi!
Old February 26th, 2010, 09:24 AM
Yeah I do, but it's still great fun to raz you. I'm putting in a half day of work and then going out to work on my trailer!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
