Project "Frank" - The Un-Gaying of a 110 - Page 4 - Defender Source
Old January 18th, 2010, 09:09 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Dig the bottle opener on the ladder
Old January 19th, 2010, 12:05 AM
surf110's Avatar
surf110
Ze
130 Project
Wow. What a difference. How did you get the snorkel to fit with the roll cage?
Old January 19th, 2010, 10:49 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
No fitment issues with the snorkel at all. Since I bought new NAS fender skins I was able to put the snorkel in the right spot the clear the cage.
Semper Fi!
Old January 19th, 2010, 02:26 PM
I have some ones with like 4 layers of miitary paint.
Old January 19th, 2010, 08:38 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Looking good Jonathan! Seeing yours is motivating me to finish mine finally. haha
Old January 22nd, 2010, 10:26 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Jonathan,
Did the hose that connects the air filter to the snorkel come with the snorkel? I have a disco 200 and I'm debating different air filter set-ups.
Old January 23rd, 2010, 08:10 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by RiftRover View Post
Jonathan,
I used an NAS V8 air filter and housing. Attaching the snorkel is as easy as cutting the air horn to fit the snorkel hose.
The used $20 Shop-Vac tubing I found at Lowe's.
Semper Fi!
Old January 23rd, 2010, 05:16 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
That bumper looks awful!!! wanna sell to it me? got a factory winch bumper that would fit yours much better!!!! huh huh
Old January 23rd, 2010, 05:21 PM
Wolf Fabrication
Sterling Archer
'08 D3
Uh, no! Unless you got $2k.
Semper Fi!
Old January 23rd, 2010, 05:56 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Dear Wolf,
(I am calling you wolf from now on because the intro on your website it too funny)
It looks like I am buying those flares from Phoenix37 for my bastard child. I'm looking at the pics and it looks like the flares would give me a few extra inches of possible wheel opening, based on the location of the bolt holes/rivet holes in the tub. What do you think? Did you get a good look at how much room they would give me if I cut the bodywork to follow the inner line of the flares?
Sorry for the hijack, looks great!
JL
Old January 23rd, 2010, 06:11 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
still lewks ghey.
Matt Browne
Old January 23rd, 2010, 06:14 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by oilburner View Post
Dear Wolf,
The previous owner trimmed about 2" all around on the front fenders, and about 2" on both sides of the rear openings. My truck had 35"s with no rubbing.
Semper Fi!
Old January 24th, 2010, 10:44 AM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
What year are is the rear seat arrangement out of? Is it anything special like custom seat mounts etc? I am looking for an arrangement like that for my project 110. Great job on the restomod.
Gary
Old January 25th, 2010, 07:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
Fabricated an integral receiver hitch today. I notched the rear crossmember and recessed the receiver tube. I welded 1/4" steel plate on the front as support. The rear of the tube has some angle welded to tube and that it bolted under the crossmember. The steel rods are for tow chains and a little lateral support.
I don't like the glossy paint on the crossmember - need to repaint in satin....
ID:	24687   Click image for larger version
ID:	24689   Click image for larger version
Semper Fi!
Old January 25th, 2010, 07:58 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Looks good, but I agree with you on the paint. It just looks weird to me in anything but Satin Black.
Old January 26th, 2010, 08:18 AM
why is there a fuel tank on the ground under your truck , access ?
Old January 26th, 2010, 08:42 AM
I'm guessing because he was cutting/welding his rear cross member and it was in the way and is a hazard to work around.
Old January 26th, 2010, 08:50 AM
Wolf Fabrication
Sterling Archer
'08 D3
Si mi amigo. Access to the back of the crossmember so I could weld. I also cleaned and painted everything, and cleaned the tank.
Semper Fi!
Old January 26th, 2010, 09:16 AM
Wolf, what are your thoughts on recessing a receiver into the cross member completely (assume no tank or enough room to get a pin behind it). I want to put one on my trailer but am not keen on having it stick out. Stupid I know. I am not sure if I could use a "standard" pin depth or one close enough to not be a problem using it.
Old January 26th, 2010, 09:24 AM
Wolf Fabrication
Sterling Archer
'08 D3
It's not hard, you would need longer stuff to go in the receiver tube as well.
Semper Fi!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
