Project "Frank" - The Un-Gaying of a 110 - Page 3 - Defender Source
Old December 29th, 2009, 06:37 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Timing belt swap today. The old one looks nearly new, but changing it out will give me peace of mind. I thought the project would be much harder, but it's not too bad.
Semper Fi!
Old January 2nd, 2010, 02:46 PM
Wolf Fabrication
Sterling Archer
'08 D3
Finally getting things buttoned up. I finished the install of the timing belt. That was much easier than I thought it would be! With the front end apart I was able to fit the Disco fan shroud which nearly everyone said wouldn't fit, but it fits perfectly! Even the mounting holes line up and the fan is the proper distance inside the shroud.
With the timing belt done I was able to install the Equipe competition bumper and Superwinch 9.5i winch. The bumper required just a little trimming to fit the winch. The grill required some trimming since the competition bumper sits closer to the radiator, I also painted the grill to match the rest of the truck. Oh yeah, I put the proper Land Rover 110 decal on too!
Next, I finished the sliders by bending up some tree sliders/steps and welded 'em on and painted to match.
All the interior is finally done and all the seats match. You'll notice I mounted the speakers in the Tuffy console. I thought I'd give this a try, so I Dynamat'd the inside of it. I think the speakers sound much better than when they were in the doors.
ID:	24052   Click image for larger version
ID:	24054   Click image for larger version
Semper Fi!
Old January 2nd, 2010, 03:29 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
whats the deal with that bubble gum on the sliders?
Old January 2nd, 2010, 06:04 PM
Wolf Fabrication
Sterling Archer
'08 D3
Too funny! The lighting and angle makes it look like bubble gum. I didn't clean up the welds at all.
Here's that same weld from a different angle. It still looks weird in the dark light of my shop, but it's much better than the photo shows.
Semper Fi!
Old January 2nd, 2010, 07:04 PM
crown14's Avatar
crown14
Verticalscrote
Jon are those the Equipe sliders for the 110? Also, what thickness are your nerfs, nice job on the bends BTW.
Damn those rims cleaned up nice!!
Old January 2nd, 2010, 07:15 PM
Wolf Fabrication
Sterling Archer
'08 D3
Nope, they are the cheapo Mantecs. I used 1-1/2" .120 wall DOM tube for the tree sliders. The tube is just above the Jack holes so they are still functional. The rims are not the ones that came on the truck.
Semper Fi!
Old January 3rd, 2010, 09:28 AM
this hinge is upside down
Old January 3rd, 2010, 02:23 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, I knew the skinny side goes up, but for some reason I put that one bottom on without noticing. I didn't realize it until went to install the other door this morning that I figured it out.
Semper Fi!
Old January 3rd, 2010, 02:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Does equippe make sliders for a 110?
Old January 3rd, 2010, 05:06 PM
Originally Posted by Wolf Fabrication
Got the SD cage installed over the past few days. What a kick in the balls. The instructions for the kit SUCK! 4 pages with a few photos for a kit that contains literally 30 pieces and 300 pieces of hardware of all shapes and sizes. The installation leaves a lot to the imagination.
Couldn't agree more. The one I did had no hardware or instructions and was slightly bent/used and didn't fit together well.
Old January 4th, 2010, 01:10 PM
crown14's Avatar
crown14
Verticalscrote
Yeah I know, but arent they the ones I sold you?
Old January 4th, 2010, 06:33 PM
Wolf Fabrication
Sterling Archer
'08 D3
Probably. The people I got parts from all blur together!
Semper Fi!
Old January 4th, 2010, 09:10 PM
Rugbier's Avatar
Rugbier
Gustavo
They do and if I am not mistaken, Justin has a set of them with nerf, nice looking ( I just can't stand the nerf on sliders ), but I think they call them Rock/Tree Slider
NO SIGNATURE
Old January 5th, 2010, 06:12 AM
Wolf Fabrication
Sterling Archer
'08 D3
I like them because it gives me a place to stand on the side of the truck and keeps the wife happy when trying to climb in the truck!
Semper Fi!
Old January 18th, 2010, 05:32 PM
Wolf Fabrication
Sterling Archer
'08 D3
Meet Guinness
The light at the end of the tunnel!
Finally got everything buttoned up and finished.
1.I painted and installed the new front doors.
2. Installed new fenders and rear trim panels to replace the ones the previous owner chopped to fit oversize tires
3. Installed some NAS flares (although chopped, they were free)
4. Installed a Painless dual battery kit with Optimas
5. Installed Blue Sea aux fuse block
6. Wired the winch with power cutoff switch under the hood
7. Bled the brakes
8. Built a rear ladder with ever-important Guinness bottle opener
9. Installed new VDO oil pressure and Temp gauges.
Now that "Project Frank" is complete his name is now officially Guiness
Next up: ARBs, HD axle shafts, HD tie rod and drag link, and front and rear skid plates. Also need to build a rack and rear bumper.
ID:	24521   Click image for larger version
ID:	24523   Click image for larger version
ID:	24525   Click image for larger version
ID:	24527   Click image for larger version
ID:	24529   Click image for larger version
Semper Fi!
Old January 18th, 2010, 05:37 PM
KKilo23's Avatar
KKilo23
Kenny
Looks great! Congrats on the work!
Old January 18th, 2010, 06:02 PM
Get some proper flares.
Old January 18th, 2010, 08:30 PM
Rugbier's Avatar
Rugbier
Gustavo
WOW.. looks great
NO SIGNATURE
Old January 18th, 2010, 08:56 PM
Wolf Fabrication
Sterling Archer
'08 D3
Someday - these ones were free. Why, you got some?
Semper Fi!
Old January 18th, 2010, 09:07 PM
michaels
mike
2004 DII
i like it with the cut flares. would look even better with none at all.
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
