Project "Frank" - The Un-Gaying of a 110 - Page 18 - Defender Source
Old December 28th, 2011, 07:35 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Arjun
Looks awesome. When's the next time you're coming to HH? I want to check out the X-Deflex kit you have on.
Whenever the next HH is, prolly next month.
Semper Fi!
Old December 28th, 2011, 08:11 PM
Um...Arjun...how about when's the next time YOU'RE coming to a HH for the first time ?
Old December 28th, 2011, 09:05 PM
Arjun
Arjun
Dude, you know I don't drink
Need to find a plausible excuse for the better half as to why I'm leaving her alone with the kids on a Thursday evening to go hang out at a bar. She's ok with one car event/week. If I start talking HH, I might come home one day and find all my cars gone.
Old December 28th, 2011, 09:10 PM
No need to drink. In fact, at the last one I didn't have a sip. Of course, that's because I was still banged up from the night before hanging with JP "Stormer".
But yes, I understand even Manisha must have a breaking point - she's way too patient with you to begin with!
Old December 29th, 2011, 06:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
Got the disc brakes installed today! Special thanks to Keith from RovingTracks for helping me figure this out.
After reading the Disc Brake Conversion thread in the tech section, the compiling of parts and installation was pretty straight forward. I kept my stock stub axles and used early 90 front disc brake hubs. I also chose to grind and finish sand the caliper brackets vice milling them. Still haven't had a chance to test drive it yet, but the pedal feels tighter.
ID:	45381   Click image for larger version
ID:	45383   Click image for larger version
ID:	45385   Click image for larger version
ID:	45387   Click image for larger version
Semper Fi!
Old December 29th, 2011, 06:23 PM
Don't those mounting surfaces need to be machined to be nice and square? Otherwise you are not going to get even pressure on the pads.
Originally Posted by pendy
I'm here for the D's
Old December 29th, 2011, 06:53 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sure, although I used a dial caliper and level. They are single piston calipers pushing in the middle of the caliper. Any minor deviances will be accounted for in the pad. Even the amount to remove off the bracket can vary from .100 to .140. Mine looked like I needed to take .150 off, but the variance has little effect.
Semper Fi!
Old December 29th, 2011, 09:20 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Don't bang on that bench vice to hard - looks like could use some bigger bolts or washers at a minimum!
Old December 30th, 2011, 07:07 AM
Wolf Fabrication
Sterling Archer
'08 D3
I know Military housing. 3" deck screws actually hold pretty well! I have another one on a steel table.
Semper Fi!
Old December 31st, 2011, 10:33 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looking good Wolf. Have you gotten any drive time on the new setup with both the disc brakes and new suspension? The Fox stuff looks trick.
And what is with you boys from VA? I thought it was us Yankees that were supposed to be the a$$holes and ruining the site, haha
Old December 31st, 2011, 01:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
I'm still waiting on a test drive as I finish up a few other projects. Sounds like I may need to rebuild my injection pump. I was also sent the wrong front springs, so I need to swap those out.
Semper Fi!
Old December 31st, 2011, 01:41 PM
oilburner's Avatar
oilburner
JL
large pile of parts
What is it doing (pump)? External leaking is an easy fix and usually happens due to newer ULSD.
JL
Old December 31st, 2011, 01:49 PM
Wolf Fabrication
Sterling Archer
'08 D3
I posted a help thread in the tech section, but it's leaking where it meets the timing cover. I'm not getting fluid out the bottom of the timing case though, which makes it hard to believe it's the input seal.
Semper Fi!
Old December 31st, 2011, 02:26 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Its never easy is it, Not sure if you were following my Toy axle thing but its been a lot of wrong parts but a lot of it was my fault/inexperience. Good when these projects finally get figured out tho.
Looking forward to the test drive report. :
Old January 18th, 2012, 02:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
New Paint
Well, I've gone down the rabbit hole of repainting my 110. As soon as I saw the semi-gloss olive drab on the Corsetti Engineering 110 I was sold.
Paint is ordered and on the way....
ID:	46285   Click image for larger version
Semper Fi!
Old January 18th, 2012, 03:13 PM
the rover shop
shayne young
Ummm...isn't olive drab a bit ummmm, whats the word I'm looking for..."gay"... why not go with something manly like sandglow ...LOL... I have done a couple of rovers lately in a flat black cleared, looks the same finish as the one in that pic, the clear stops the flat paint from staining...just sent a disco 2 to the paint shop to be done flat black...but after seeing that one above I may change colour...nothing like a drab olive green..
Old January 18th, 2012, 03:15 PM
You painting it yourself?
Old January 18th, 2012, 03:34 PM
Wolf Fabrication
Sterling Archer
'08 D3
I am. I'm a novice, but I've painted a few customer trucks with decent results. I figure if it's going to be thrashed, why waste $$ on an expensive paint job. The paint looks like shite now anyway.
Semper Fi!
Old January 18th, 2012, 03:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
Taking it apart?
Old January 18th, 2012, 04:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by bjf
Taking it apart?
Sorta. I'm pulling all the doors, hood, cage, and everything else bolted on, then will mask everything else. Not ideal, but...
Semper Fi!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
