Project "Frank" - The Un-Gaying of a 110 - Page 17 - Defender Source
Old October 11th, 2011, 04:38 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Installed a 20lb CO2 tank today!
Semper Fi!
Old October 11th, 2011, 05:04 PM
Let's see some photos of "installed galvanized cross member"
Old October 11th, 2011, 08:22 PM
been running one of these for a while. My last bottle lasted 12mos. Included a fair amount of impact work which uses lots of gas. Only way to go if you have the space.
Old November 10th, 2011, 07:20 PM
Wolf Fabrication
Sterling Archer
'08 D3
Started on some bottom of the list projects, to include a universal mount that slides into my jack points. With this mount I can attach a vise as shown, or a folding table top I'm building.
ID:	43582   Click image for larger version
Semper Fi!
Old November 10th, 2011, 07:39 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Intresting. I have seen a vise kit that fits into a hitch receiver for the back of trucks.
Old November 27th, 2011, 04:20 PM
Wolf Fabrication
Sterling Archer
'08 D3
And here's the folding table I fashioned from an old aluminum street sign. It's strong enough for use as a cooking/kitchen table and a few beers.
Semper Fi!
Old December 22nd, 2011, 03:49 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sex in a box just showed up.
ID:	45219   Click image for larger version
Semper Fi!
Old December 22nd, 2011, 05:47 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice.. What valving r u using?
Legend in My Own Mind.
Old December 23rd, 2011, 01:14 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Holy crap - you've got some pretty insane hardware going on there! Can't wait to see pics of that setup installed. Hope it solves that rear end dampening issues you posted about.
Old December 23rd, 2011, 06:42 AM
Wolf Fabrication
Sterling Archer
'08 D3
I can already tell the RTE rear upper mounts won't work and I'll have to fab up taller ones. Springs should arrive next week and I'll be ready to bolt everything up.
Semper Fi!
Old December 23rd, 2011, 04:35 PM
Wolf Fabrication
Sterling Archer
'08 D3
Fabbed up the rear upper mounts this afternoon.
Semper Fi!
Old December 23rd, 2011, 05:36 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
So just how much movement are you hoping for at the wheel
Mike Hammond
Old December 23rd, 2011, 05:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
I'm shooting for 5" up and at least 8" down. The rears are 14" travel shocks. I'm doing some work on the a-arm too.
Semper Fi!
Old December 24th, 2011, 02:28 AM
mikeslandrover
Mike Hammond
Something like this might be a good idea
http://www.x-eng.co.uk/X-Joint.asp
Mike Hammond
Old December 24th, 2011, 06:12 AM
Wolf Fabrication
Sterling Archer
'08 D3
I already have that.
Semper Fi!
Old December 24th, 2011, 08:29 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Is that on the 110? Those don't look like the KM2's you had on it? Can't really see the upper mount - but looks like it was done with square tubing?
That's going to have some setup when you are done - with the X-Eng trailing arm kit.
Old December 24th, 2011, 08:52 AM
Wolf Fabrication
Sterling Archer
'08 D3
I use a smaller (tiny!) set of tires on the truck when I am working on it - makes it easier to move around and work on. Upper mounts are 2" square .25" wall square tube welded to 1/2" plate.
Semper Fi!
Old December 27th, 2011, 05:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Makes sense. Mounts sound interesting. If you get any more pics of them please post. Cool that you can make your own stuff. I just got a Lincoln TIG machine and will be learning the ways of the torch this winter. One of the things I want to do are sliders - or at least modify the ones I have to fit much nicer.
Old December 28th, 2011, 06:11 PM
Wolf Fabrication
Sterling Archer
'08 D3
Front is all done with new springs, Fox Shox, and RTE mounts.
Rears all done too, with new springs, Fox Shox, RTE lower mounts, and custom upper mounts.
The other pic is my ride with hooptie tires.
Tomorrow: Rear disc conversion!
ID:	45356   Click image for larger version
ID:	45358   Click image for larger version
Semper Fi!
Old December 28th, 2011, 06:52 PM
Arjun
Arjun
Looks awesome. When's the next time you're coming to HH? I want to check out the X-Deflex kit you have on.
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
