Project "Frank" - The Un-Gaying of a 110 - Page 16 - Defender Source
Old June 3rd, 2011, 02:40 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Sexy new Tom Woods HD driveshafts came today!
Semper Fi!
Old June 3rd, 2011, 06:27 PM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Very nice! How long did it take for him to make those? Been thinking about the same- I lifted your old rig slightly and have been getting some driveline vibration.
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old June 3rd, 2011, 06:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
Ordered them through Lucky8. Took two weeks total. Price was actually less than I anticipated too.
Semper Fi!
Old June 3rd, 2011, 09:33 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I've got some left over at home you can have.
cool thanks. Maybe a HH or something.
we'll be in touch
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 25th, 2011, 04:00 PM
Wolf Fabrication
Sterling Archer
'08 D3
My X-Deflex kit arrived from X-Eng yesterday. Simon puts together some very nice kit and I am impressed with the design, especially the fact that it used a lot of off the shelf Rover parts to include a spare shaft, drive flange, and tie rod ends.
I had been driving without a rear sway bar, but with 5" of lift and gear on top my truck could be scary at times.
The installation was pretty straightforward. I ended up bolting the sway bar to the Equipe skid plate vice the frame as the skid plate is in the way.
ID:	39916   Click image for larger version
Semper Fi!
Old June 25th, 2011, 04:05 PM
Wolf Fabrication
Sterling Archer
'08 D3
My X-Brake also arrived and made it's way on to my truck. I am very happy to finally ditch the stock drum setup. The kit is awesome and was a pretty easy install. In the end I gained about an 1" of clearance under the e-brake.
ID:	39919   Click image for larger version
ID:	39921   Click image for larger version
Semper Fi!
Old June 25th, 2011, 04:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
How is the handling now with the rear say bar kit? How much was it and where did u get it?
Legend in My Own Mind.
Old June 25th, 2011, 05:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
Only driven 5 miles so far, so I can't really tell. It does feel different though. I got the kit through Lucky8. Not sure how much it is as was part of a drug deal.
Semper Fi!
Old June 25th, 2011, 08:16 PM
LFORGUE8
Lucas Forgue
2011 Rangie
the xbrake......do you have a cable ebrake set up from a d1? or do you have to use the original set up with that caliper?
59 SII....on the back burner!
11 Rangie
Old June 25th, 2011, 08:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
Aren't all LR e-brakes cable operated? You just use your stock cable unless your cable enters the back of the e-brake backing plate.
Semper Fi!
Old June 26th, 2011, 11:56 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Point of reference, after about 2,000 miles my X-Brake wasn't gripping tight enough to hold the truck. Quick adjustment of the cable sorted it, obviously it just bedded in a little.
Tony
1984 110 "Smokey" (sold)
Old June 28th, 2011, 08:03 AM
LFORGUE8
Lucas Forgue
2011 Rangie
true that all are cable....i should have said cable all the way to the drum..... i used a d1 full cable setup on my 88 rrc since my linkage had gotten all rusted and seized....just wondering if that xbrake would still work as im surprised at the big gain in ground clearance
11 Rangie
Old June 28th, 2011, 08:10 AM
Wolf Fabrication
Sterling Archer
'08 D3
I have a Disco 200Tdi and it sits pretty high up, so the little X-Brake skid plate now sits flush with the bottom of the frame rails.
Semper Fi!
Old August 14th, 2011, 05:05 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I fitted my X-Deflex to my 90 and found a noticable improvement in road handling. Used the same mounting method as Wolf. Great product.
Old August 14th, 2011, 06:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
How does it bolt to a NAS truck? What do they cost?
Old August 14th, 2011, 07:12 PM
Wolf Fabrication
Sterling Archer
'08 D3
They bolt to the sway bar mount or to the fuel tank skid like we did. I think they run about $450 for the kit.
Semper Fi!
Old August 16th, 2011, 05:46 PM
kevkon's Avatar
kevkon
kevin
Randy, if you or Chris want to check it out let me know. Definately handles a lot better.
Old August 22nd, 2011, 08:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
Started the 4.10 gear swap! Rear is done, waiting on some parts to finish the front.
Semper Fi!
Old August 22nd, 2011, 11:43 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The people you are looking for for the handbrake and anti-roll bar (and a lot of other cool kit) are here
http://www.x-eng.co.uk/Index.asp?MID=18
Mike Hammond
Old August 29th, 2011, 08:06 AM
Wolf Fabrication
Sterling Archer
'08 D3
After a few hiccups, like having to change the front pinion flange from 4 spline to 24, and having to replace the front pinion outer bearing, all the gears are in. I was suprised and relieved that I was able to shift front pinion shims around to get a nice wear pattern on the ring.
The 4.10 gears are a nice upgrade. I've lost some of my top end speed, but now I have more low end "umph." I can't wait to try the new gears on the trail. The best part is that now my speedometer is actually spot on!
Semper Fi!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
