Project "Frank" - The Un-Gaying of a 110 - Page 14 - Defender Source
Old May 20th, 2011, 08:18 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Finally got around to building a front bumper. My goal was a clean, low-profile look, with the best approach angle as possible. The only real limiting factor is the size of the winch. The bumper is made from 1/4" steel plate, with 1/2" plate at the frame horns. I used Equipe swivel shackles and also added two jack points on either end, oh, a bottle opener. It's also got a THICK coat of powdercoating.
And yes, that is a chicken coop flooring grill (design thanks to Ron Peppard).
ID:	38874   Click image for larger version
ID:	38876   Click image for larger version
Semper Fi!
Old May 20th, 2011, 08:50 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
hey i've seen the front grill somewhere ....hhhmmmmm
Old May 20th, 2011, 08:55 AM
Wolf Fabrication
Sterling Archer
'08 D3
I love the idea. It's cheap, rugged, and looks somewhat decent on the front of a Rover. I am now trying to find a Series grill badge to put on it.
Did you get your rear end fixed (on your D90)?
Semper Fi!
Old May 20th, 2011, 09:32 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
like the grill, got a source for it?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 20th, 2011, 10:55 AM
farmtec.com cool people. have you pay after it arrives. bizzare in todays world.
Old May 20th, 2011, 11:06 AM
Wolf Fabrication
Sterling Archer
'08 D3
I've got some left over at home you can have.
Semper Fi!
Old May 20th, 2011, 11:31 AM
ron's Avatar
ron
Ron
the diff is at Matt Browns in ME getting fixed... all the ring pinion bolts were finger loose and took out 2 nice chunks of my ring gear.
i drove home 500 miles in front wheel drive
Old May 20th, 2011, 11:34 AM
Wolf Fabrication
Sterling Archer
'08 D3
That is awesome! You definetely deserved the trophy!
Semper Fi!
Old May 20th, 2011, 11:37 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
I concur. They are great to deal with. We ordered some material and one of the packages arrived damaged. Let them know and they had a replacement sent before I could even say "thank you" !
Old May 20th, 2011, 12:36 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Did you drill those speaker mounts into you're tuffy? Genius! I've been thinking about how to maintain front speakers when I mount my rockware safari doors.
Regards,
Jay
Old May 20th, 2011, 12:39 PM
Wolf Fabrication
Sterling Archer
'08 D3
Regards,
Jay
I did. Lined the inside with Dynamat too.
Semper Fi!
Old May 24th, 2011, 02:42 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
what did you use to cut the tuffy? Now that I'm home from a trip I want to do this mod asap!
Thanks!
Jay
Old May 24th, 2011, 05:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
Plasma cutter. Makes quick work of it!
Semper Fi!
Old May 24th, 2011, 06:03 PM
What post is this tuffy mod on? I scanned back a ways but don't see it.
Originally Posted by pendy
I'm here for the D's
Old May 24th, 2011, 06:39 PM
x2 I looked the other day and could not find
Old May 24th, 2011, 08:09 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Page 4 top post...
Now I need to get a plasma cutter!
Old May 24th, 2011, 08:46 PM
Wolf Fabrication
Sterling Archer
'08 D3
Here are two pics from today
ID:	39052   Click image for larger version
Semper Fi!
Old May 24th, 2011, 08:52 PM
Wolf Fabrication
Sterling Archer
'08 D3
Started the rear NAS front seat install today. I'm building a seat box similar to the front that will allow for a lot more storage. There will be a Tuffy center console between the seats and new seat belts. The seat box will get bed liner inside and out and be sealed from water.
Oh, for the purists, the seat box is bolt in and does not require any body mods.
ID:	39054   Click image for larger version
Semper Fi!
Old May 24th, 2011, 10:15 PM
you are reducing rear leg room ? my 110 had a similar twin bucketseat setup but they were mounted as far back as possible which also lifted them
one note on speakers mounted in the cubby box. Don't ever put your wallet in there-I had one briefly and the magnets wiped the magnetic strips on a couple of cards.
Old May 24th, 2011, 10:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
you are reducing rear leg room ? my 110 had a similar twin bucketseat setup but they were mounted as far back as possible which also lifted them.
It's kind of an illusion. The knee room is the same, the leg room at the heel is reduced 3.5," and that is where someone would tuck their feet under the seat anyway. Either way, I am doing this for the safety and comfort of my kids. I wanted to move the seats back, but that would have meant cutting in to the wheel wells or raising the seats, which I did not want to do.
Semper Fi!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
