Project "Frank" - The Un-Gaying of a 110 - Page 13 - Defender Source
Old September 24th, 2010, 05:46 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've actually had it out 4 or five times. I wheeled it in CO and Moab in June, did some GWNF trails in July, and Canada last April. I plan on just enjoying it and bouncing between MAR, Uwaharrie, and RC.
Semper Fi!
Old September 24th, 2010, 07:25 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Originally Posted by Wolf Fabrication View Post
Coming to the end of the project (yeah, right). Installed a MudUK rear door panel, Terrafirma caster corrected radius arms with new bushes, KAM HD rear shafts, and HD drive flanges at all 4 corners. Also finished the auxillary air tank install using a 4 gallon stainless tank.
What are the dimensions of that tank? Does it hang down and need protection? Curious because I had a fun time getting my 2.5 gallon tucked up tight...
Old September 24th, 2010, 12:44 PM
You took it to Moab?? What trails did you do? Were you happy with its performance? Any photos to share? Surprised you haven't mentioned that at all until now. I'm bummed to not be going to Moab this fall for the National. Guessing you trailered it out there?
Old September 24th, 2010, 04:12 PM
Wolf Fabrication
Sterling Archer
'08 D3
Went with a buddy's CO Jeep club for a long weekend and did Chicken Corners, Elephant Hill, Copper Ridge, Crystal Geyser, Seven Mile Rim, and Dome Plateau IIRC. Mostly 2 and 3 level trails, nothing crazy. Also did some camping and mountain biking. Definitely had to trailer it - that's a long drive!
Semper Fi!
Old September 24th, 2010, 09:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
Remember I have a 110, so more space underneath. Mine tucks nicely lengthwise under the truck between the exhaust and driveshaft. The tank is roughly 30" long and 10" in diameter.
Semper Fi!
Old September 29th, 2010, 10:54 AM
Wolf Fabrication
Sterling Archer
'08 D3
Spent the better part of two days fabricating some rear corner protectors. I agonized for a long time over the design, but in the end decided to use a design similar to the Equipe ones. I used 2" DOM .25 wall tube and 1/4" steel plate. The frame outriggers are 1-1/2" DOM .165 wall tube. I welded a tube to the frame and the outrigger slides in to it.
The protectors follow the body lines and include a jack point and a mount for my rear air line.
Semper Fi!
Old November 29th, 2010, 08:40 AM
Wolf Fabrication
Sterling Archer
'08 D3
While at Rausch Creek my front SG diff guard fell off whilst wheeling a rock pile and I bashed my front diff. So what better time to install a Rovertracks diff guard. I also bent up and welded on an integral axle/diff skid plate to further protect things.
ID:	33547   Click image for larger version
ID:	33549   Click image for larger version
ID:	33551   Click image for larger version
Semper Fi!
Old December 6th, 2010, 10:10 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Jonathan,
Are you still running the 315/75R16 tires on the Wolf rims ?
How are you liking it ?
(we were looking for those 'unobtanium' 255/100R16 michies and this is looking like a much more viable alternative)
Frank
Old December 6th, 2010, 10:42 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by ersatzknarf
Jonathan,
Frank
I love the KM2s. For the 315s I am running 1.5" spacers and a 5" lift to clear them though.
Semper Fi!
Old December 6th, 2010, 11:19 AM
ersatzknarf
Frank
'96 hybrid
Thanks for the fast reply.
Really like this Rover
We have the spacers. A 5" lift to clear those tires is certainly something to cause me to think further. Thank you for clarifying that.
Cheers,
Frank
Old December 6th, 2010, 11:39 AM
Wolf Fabrication
Sterling Archer
'08 D3
Let me clarify a little. The 315s fit on a 2-3" lift, but will rub when turning unless you adjust your stops. They seemed to tuck nicely under the fenders. When I added spacers to improve turning radius that pushed the tires outsides the flares, thus requiring more lift. With 5" of lift everything now works and looks good.
More lift also requires some suspension mods, so keep that in mind.
Semper Fi!
Old December 6th, 2010, 12:03 PM
ersatzknarf
Frank
'96 hybrid
Understood. Thanks, again.
Old December 14th, 2010, 08:43 PM
DBZ2009's Avatar
DBZ2009
Z
ex-1994 D90/ 2 j**ps
5 in lift, are you using rovertym springs? How are the manners on the road with the 5 in lift?
Old December 14th, 2010, 09:35 PM
Wolf Fabrication
Sterling Archer
'08 D3
I'm using the MM4x4 (UK) 5" lift kit. To my knowledge, no one is making a 5" 110 rear spring, so I had to use 2" spacers. The kit - http://www.mm-4x4.com/5-super-lift-k...ver-3485-p.asp - has everything you need. I just built my own similar suspension.
Surprisingly, the truck drives awesome and I have no issues. I think stiffer shocks help keep the truck level in corners and I have almost no body roll. I don't even have sway bars.
Semper Fi!
Old March 16th, 2011, 05:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
Installed the Rotopax mount and fuel cans last week. I really like these cans. They are simple, plastic, 1 or 2 gallon cans with internal spouts. The cans mount through the middle with a rotary handle that locks. I mounted two 2 gallon cans. I could also mount a 2 gallon water can.
I also built a custom rear drawer for all my gear. It's 30"x30"x12" and built from 1" 16ga square tube and angle iron, skinned in aluminum diamond plate. To save weight, the drawer itself is a steel frame with wood bottom and sides. The exterior is finished in bed liner.
ID:	36996   Click image for larger version
ID:	36998   Click image for larger version
ID:	37000   Click image for larger version
Semper Fi!
Old March 16th, 2011, 05:42 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Why did you choose those dimensions? Seems odd to loose a few inches on each side and then not have it be level with the wheel arches. Curious about your design rationale. Is it a function of the slide out drawer width v back door opening?
Old March 16th, 2011, 05:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Looks cool. What ever happened to the NAS 110 you were restoring to sell?
Old March 16th, 2011, 05:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
It got sold from under us!
Semper Fi!
Old March 16th, 2011, 05:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Are you still involved in buying and selling trucks?
Old March 16th, 2011, 06:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
30x30 allows it to slide in the back of the truck and clear the door hardware and allow for longer gear to sit along side it. I chose 30" deep so I can fit a trunk between it and the rear seats.
I wanted it level with the fenderwells, but that would have made the drawer itself only 7" deep. By going 12" that created "pockets" on the wells for gear to sit. Believe me, it makes sense in my Rover fantasy world.
------ Follow up post added March 16th, 2011 06:02 PM ------
I am, rare, exotic, and muscle cars. Somewhere in there are Rovers.
Semper Fi!
110 Soft Top project nearing completion rivermike For Sale - Vehicles 34 March 25th, 2013 04:49 PM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
