Project Blizzard 1985 110 Full Restoration - Defender Source
Old September 17th, 2014, 08:17 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Here is another build that we finished this month. Very simple truck with just the right amount of creature comforts.
The Specs:
Galvanized Marsland Chassis
Exmoor Trim Interior
2.8 Diesel Engine
Proper Wiring Looms Throughout
Td5 Dash
New Doors
Tire Carrier
Roof Rack
LED Headlights
Bed Lined Interior
Puma Bonnet
LED Rear Lights
Rebuilt Gearbox / Transfer Box
New Headliner
Power Front Windows
AC
2 Inch Lift
KBX Grill
Wing Top Protectors
Rear MUD UK Door Card
Disc Brakes
Full image gallery is on our Facebook Page
https://www.facebook.com/media/set/?...7660519&type=1
ID:	103119   Click image for larger version
ID:	103121   Click image for larger version
ID:	103123   Click image for larger version
ID:	103125   Click image for larger version
ID:	103127   Click image for larger version
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Old September 17th, 2014, 08:34 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Very nice,
Old September 17th, 2014, 08:50 PM
Very nicely done. Is that an M&D kit? Q's
- tell me about the servo vacuum tube. did you make that or is that a particular part no you found that fits? mine could use something better like that. very tidy.
- top heater hose from the head. how did you get it to bend that way, or is that a particular part no you cut to fit?
- did you do any soundproofing?
- what mpg are you getting? is it stock tune? what' tcase ratio?
more engine bay pics please!
Mark Kellgren
KM4BOR
Old September 17th, 2014, 09:08 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Looks fantastic... minus the rack and the white. I can't stand the solid white arches but that's the look it seems people want. These two builds are fancy!
Rear axle is P38 Defender type?
Old September 17th, 2014, 09:40 PM
which headlights are you using?
Old September 17th, 2014, 09:47 PM
the rover shop
shayne young
Dammit.... Your knobs crooked..
As far as headlights go, isn't that the trucklites.??
Old September 18th, 2014, 01:05 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
No Salisbury rear axle???
Old September 18th, 2014, 07:28 AM
SafariHP's Avatar
SafariHP
1983 Defender 110
Morning Mark
We used a 300 LHD TDI hose and a heat gun to make it look stock.
We use the newer style heater box and the matched hoses for a later box.
We did our normal sound proofing but nothing special. I hate the static clutch noise of the 2.8 but but as you know once in drive it the clutch noise goes away.
We tried a 1-2 box and a 1-4. Stuck with the 1-2 on this one. MPH - who cares its fun to drive,
Will see what other engine bay images we have. We've installed several of the M&D kits this year so we have some images some place. If you need something special we have an install going on now and I can grab some images for you.
ID:	103153   Click image for larger version
ID:	103155   Click image for larger version
ID:	103157   Click image for larger version
Winter Park, FL
(407)517-4983
Old September 18th, 2014, 07:35 AM
SafariHP's Avatar
SafariHP
1983 Defender 110
Rover Axle as it was decided that was the best choice for the end customer.
------ Follow up post added September 18th, 2014 07:36 AM ------
Trucklites for sure. Best light we have used. Installed 12 sets this year with ZERO failures.
Winter Park, FL
(407)517-4983
Old September 18th, 2014, 08:58 PM
D90_982
Chad
1994 ST #982 (SOLD)
How much did this sell for? Looks nice
Old September 20th, 2014, 07:50 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Those seats are really nice. Ex more ?
Legend in My Own Mind.
Old October 22nd, 2014, 07:31 PM
hey, since you guys are installing M&D 2.8 kits now, have you come up with a better routing for the turbo to intercooler pipe? My M&d kit came with a piece of 2" straight pipe, and 45deg and 90deg silicone ends, that is pinched between the alternator the the inner wheel well, and it sucks balls. It really needs a shaped piece of pipe to work through there and avoid abrasion from rubbing on other things.
if you made something custom I want me a piece of that.
Mark Kellgren
KM4BOR
110, 1985, restoration
83-87 Defender 110 Restoration Project Wanted jeffrabhan Wanted 9 January 19th, 2014 06:37 PM
Another "It Wasn't Supposed to be a Restoration" project Axel Truck Build-up's & Restores 18 December 29th, 2012 09:20 PM
My daily driver turned restoration project RickM Defender Technical Discussions 10 January 26th, 2012 11:24 AM
D90 in New England Blizzard Brendon Misc. Chit-Chat 4 January 19th, 2011 11:24 PM
Heater fan lever broke...in a blizzard chris snell Defender Technical Discussions 8 January 8th, 2007 05:52 PM
