Previous LR3 owner...now a noob Defender owner. - Page 2 - Defender Source
Old May 17th, 2017, 01:59 PM
kilr4d
1999 110 TD5
Originally Posted by Al Blue4.6l View Post
Any ETA on when it may be done? Doing anything to the TD5?
Well, the great (terrible?) part about the blasting is that it's identified ALL of the areas that need repair.
Sooo...ordering a bunch of stuff from Bearmach next week; learned my lesson on which freight companies NOT use hoping to start aluminum repairs asap. Then fit Recaros, then have frame cleaned up, then reassemble.
As far as the TD5, it's already got a boost box so I think I'll just repair the leaks (valve cover, injector harness,etc) and ceramic coat the the exhaust. Maybe en EGR blanking plate.
Old May 17th, 2017, 02:02 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
2006 LR3
Different shop than the one that did that ugly white/black/red thing?
Old May 17th, 2017, 02:10 PM
kilr4d
1999 110 TD5
Yeah...really a different project. I've got a bodyman from the Caribbean doing the paint and body. Lots and lots of Defenders in the Islands so he's really familiar with the ins and outs.
Old May 18th, 2017, 03:40 PM
Vedrover
Alex
1988 Land Rover 110
Great project! Nothing too too horrible, all problem areas are standard for Defenders, so, fear not, the rear xmember does look a bit dodgy, though.
For the upstand and rear tub floor you may order Bearmach, but you can also go to YRM. Better yet, you can get it custom-cut and bent for you locally, all you need is 1/8" aluminum sheet. I went with 1/8" checker plate for mine and it costed me significantly less than getting it from UK.
Here's my DefenderSource build page to date: LINK
I'll PM you about your bodyman, would be curious to see what he would charge to take care of my Landy. As I'm now in Montreal, and not in Calgary, I'm hoping I can get a quality job done for less than what Calgary bodyshops wanted.
Old May 23rd, 2017, 08:59 AM
kilr4d
1999 110 TD5
That's a great idea and probably what I'll do. The aluminum and a various brakes are on hand locally.
Looks awesome.
Old May 31st, 2017, 01:12 PM
kilr4d
1999 110 TD5
Finally degreased and actually not too bad.
Tomorrow it's off to blasting and then paint.
Old June 2nd, 2017, 12:19 PM
kilr4d
1999 110 TD5
Used an aggressive blasting media and the chassis has responded very well.
Primer and paint are tomorrow if everything stays on schedule.
Old June 2nd, 2017, 12:31 PM
speedpin's Avatar
speedpin
Looking ;)
"degreased and actually not too bad"
How did you do it?
~ Semper Fidelis ~
Old June 2nd, 2017, 12:38 PM
kilr4d
1999 110 TD5
How did you do it?
Steam...lots and lots of steam from a diesel fired pressure washer. After plastic wrapping anything that looked vulnerable.
Old June 7th, 2017, 01:55 PM
kilr4d
1999 110 TD5
Thumbs up
Primed and painted.
Old September 1st, 2017, 06:18 PM
roadworn's Avatar
roadworn
jonathan
1990 110 5 door
Originally Posted by kilr4d View Post
Finally starting to turn the corner. I'm truly amazed at the efficacy of soda blasting. Little slow but the results are blowing my mind.
Are you soda blasting yourself or sending parts out. If you are doing it yourself,what gear do you have?
Iam about to take on similar 1990 UK 110. Waiting on truck delivery now.
defender, lr3
Stalking previous Rovers BlackField The Flea Market 1 January 18th, 2015 03:24 PM
Defender Oil change for a noob jamonhemingway Defender Technical Discussions 7 April 10th, 2013 08:40 PM
Seriously....previous owner. egor Defender Technical Discussions 6 October 16th, 2012 08:05 PM
Noob oil question Arjun Defender Technical Discussions 2 June 25th, 2010 02:43 PM
Defender Noob KWmisfit Defender Technical Discussions 11 April 4th, 2005 06:21 PM
» Defender Registry
Lucky
85Red110
RAF
Realm
Add your Defender
