Old school vs TD5 rear crossmember? - Defender Source
Old September 10th, 2015, 10:41 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is there any real downside to a TD5 rear cross member setup, as opposed to an old school one?
If i order a Richards chassis I want to get the TD5 rear tank setup, and the TD5 cross-member is a $100 cheaper than the older style one.
Old September 10th, 2015, 11:08 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Td5 chassis
I don't know what the difference is between Richards and Marsland, I have a Marsland and you get a spot to protect your trailer light socket on a Td5 chassis.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 10th, 2015, 11:14 AM
bjf's Avatar
bjf
barry f
94 ST #395
What exactly do you mean by td5 rear. The one just pictured is still old style in my book. Td5 style should have a separate floating mount to attach body to rear. In my opinion it makes body line up easier and looks slightly cleaner.
Old September 10th, 2015, 11:34 AM
roverman2010
1985 LR 90 200Tdi
If you look mine does have the separate tub mounting bar
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 10th, 2015, 11:41 AM
on a side note, can trailer harness protection be added by just drilling a big ass hole in the old style rear crossmember for mounting to the inside/front side of the box wall, or is there more to it?
Mark Kellgren
KM4BOR
Old September 10th, 2015, 11:46 AM
roverman2010
1985 LR 90 200Tdi
Structure, dear boy. The hole on the Td5 style is boxed in bringing structure back to that big arsed hole, lol
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 10th, 2015, 12:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
I see what you mean but I thought the tabs should be on the inside. Every td5 or newer frame I saw had them inside instead of out.
CHASSIS GALVANIZED 90 200 TDI, RNS561, NTC7989G - Kit Configuration Page
I guess you can pick external or concealed. I know from the factory they now conceal.
Old September 10th, 2015, 01:00 PM
roverman2010
1985 LR 90 200Tdi
I have never seen those pictures, so its either or. I had new nut plates fitted on the backside of the body so I gots exposed.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 10th, 2015, 01:41 PM
61rover's Avatar
61rover
John Crouse
Does one or the other work better with the NAS style bumper?
Old September 10th, 2015, 02:03 PM
TD5 style is ugly.
Old September 10th, 2015, 02:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Bumper makes no difference with this.
Old September 10th, 2015, 03:00 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
I went with the older style rear crossmember because I wanted it to be correct for a NAS Defender. But it's not an exact match. Four of the tabs are welded onto the face of the crossmember rather than welded on top (an L shape) like the original. Even the NAS rear crossmember with the gas tank brackets already on it RN sells is like that. I'm not sure where you can get an exact match to the original. So now I kinda wish I got the Td5 style so I could have the adjustable mounting bracket. We took good measurements to get it on right but I'm still kinda worried it won't line up precisely. The big hole for the trailer wiring does look kinda strange though.
Old September 10th, 2015, 03:34 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
How much protection does your trailer socket need?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 10th, 2015, 05:11 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
What hitch are you running on this? I have the Marland chassis with the td5 crossmember as well and like the look of yours.
td5
NAS D90 rear cross memeber ADK46er Wanted 22 July 31st, 2014 08:50 PM
Old school 110 shock mount help? tomaco1 Defender Technical Discussions 5 May 2nd, 2011 03:13 PM
FS: ICON CJ3B "old school" mpodgorski The Flea Market 22 January 25th, 2011 04:14 PM
Keys - so old school bjf Misc. Chit-Chat 28 January 12th, 2011 03:38 PM
Wtb- Old School Yellow Letter Rear 110 Mud Flaps NashvilleRover Wanted 4 August 7th, 2009 01:58 PM
