New 4.6 issue - Defender Source
Old March 6th, 2016, 01:22 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
New 4.6 issue
I've recently installed a new Rover 4.6 in my 110.
Now that spring weather is here it runs a lot hotter than it did. Been having green coolant spray out of the cap when I run it on the freeway. I'm using stock air intake trumpet and stock exhaust.
It hasn't overheated at all but the water temp gets above 200 nowadays.
Will a better air intake help? Seems pulling hot air through from inside the hot engine compartment can't help.
Old March 6th, 2016, 01:49 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Where I would start...
Electric fan or mechanical? And is it working?
Thermostat stuck?
What condition is the radiator in? New?
I doubt getting a better air intake will help much if at all.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old March 6th, 2016, 01:52 PM
jason1st
Jason Crandall
Thermostat stuck?
Radiator is new.
Electric fan and it's working.
The other stuff I'm not sure about.
Do you know where I can order a new hose that connect the intake to the MAF?
Old March 6th, 2016, 02:34 PM
Something is wrong if coolant is spraying out of the cap and it isn't overheating.
What radiator are you using? Some 4.6's require a bigger radiator, and some don't. I've put in a bunch a couple (including my own) have required a 4 core radiator. I also run a Range Rover Classic 11 blade fan.
Old March 6th, 2016, 02:52 PM
jason1st
Jason Crandall
You're over my head unfortunately.
I do know when I first crank it up in the morning it runs great. As soon as it's warmed up it doesn't seem to run as smoothly. I feel the issues are connected.
A new radiator was ordered and installed for this engine. I'll look under the hood, take some pics and provide more information.
Old March 6th, 2016, 02:53 PM
What radiator did you use?
Old March 6th, 2016, 03:42 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
How's your heat from your heater?
You may just have an air pocket. Try bleeding the system.
Old March 6th, 2016, 03:57 PM
jason1st
Jason Crandall
I never turn the heater on as there's so much heat radiating from the engine and trans I don't need it. I don't think the vents are hooked to the heater blower motor anyways.
Old March 6th, 2016, 04:35 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
The heater core utilizes coolant circulated as part of the system that cools the engine. It's like a smaller radiator. Do the coolant hoses to and from the heater core feel hot? Do you have an infrared temp gun? Was a new cap fitted to the expansion tank with the radiator and engine project? There may be a number stamped on it, such as 15 lbs or 15 psi.. How do you know it's running 200*?
A/C? Big lights on the brush bar?
Email is
Same place, new dogs.
Old April 26th, 2016, 05:36 PM
jason1st
Jason Crandall
The issue was not a hot running engine.
I definitely have and electronics issue. Talking with Cannibal V8 (where I bought the engine) the engine has too much spark knock or what they call "detonation". I need to know how to make sure the sensors system is working properly and if not how we can repair it.
Can anyone who has successfully installed a GEMS 4.6 help me out?
Old April 26th, 2016, 07:22 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Cannibal V8 strikes again!
Old April 26th, 2016, 07:24 PM
I was thinking the same thing.
------ Follow up post added April 26th, 2016 07:27 PM ------
Can you go into more detail of the symptoms you are experiencing?
Also, is this in an '83 110? Who converted it to GEMS? The more information you can provide the better. Post some pics if you feel like it.
Old April 26th, 2016, 07:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
First, the total advance on your timing is lower on the 4.6 than the 3.9 or other. It is something like 28 degrees total advance--so you will need to reset that. I also run electric fans and a four core radiator. I have to run right now, but I'll get you some more info on what I run...
Old April 27th, 2016, 01:40 AM
jason1st
Jason Crandall
Initial startup the engine runs smooth supposedly because the electronics know it's cold so it runs the engine rich. Once the engine and ECT warms up the O2's take control of the air/fuel mixture and I get knocking.
It's a new Cannibal V8 with GEMS electronics. None of my engine is from the 1983 3.9 liter that was in there originally. All the old has been removed.
Old April 27th, 2016, 02:44 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
If you mean oxygen sensors, do you know how long it has been since they were replaced? Not much harder than a spark plug to replace. And have you scanned for codes?
Old April 27th, 2016, 07:49 AM
Are the oxygen sensors definitely plugged in correctly? IIRC, it is pretty easy to mix them up on a GEMS truck.
Old April 27th, 2016, 08:12 AM
LRover's Avatar
LRover
J. Michael McCaig
Have a mechanic test for exhaust gasses in the coolant. You can buy the kit to do it yourself from NAPA if you want to do it yourself. If exhaust gasses are in the coolant, you have internal engine issues (head gasket or cylinder liner) which would explain the over pressurized cooling system.
Old April 27th, 2016, 08:46 AM
jason1st
Jason Crandall
My mechanic is scanning for codes but says the codes his machine spits out are unreadable. I'll ask about the O2 sensors.
------ Follow up post added April 27th, 2016 08:49 AM ------
This is a new install.
Old April 27th, 2016, 08:58 AM
It would be interesting to run the heater and see if it affects the overflow of coolant.
Was a new wTer pump used?
Old April 27th, 2016, 09:12 AM
jason1st
Jason Crandall
The coolant is not the issue. I've updated what the issue is.
New soft top header bar issue...help? josh-man Defender Technical Discussions 7 November 25th, 2013 12:31 AM
New Guy w/Brake Issue... emmodg Defender Technical Discussions 5 May 12th, 2011 08:30 PM
New Brake Issue bcourtney Series Technical Discussions 5 June 19th, 2010 06:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Private Messaging "Read Reciept" issue? chrisvonc Support & Suggestions 0 May 23rd, 2004 08:51 AM
