New 4.6 issue - Page 6 - Defender Source
Old May 1st, 2016, 10:12 AM
User Name
User
NAS D90 '95
I'll say in my conversion to the 4.6 I can easily do 80 mph on the highway and it's smooth. That said, I did a few of those additional upgrades: chip, five-o injectors (LUCAS 01D062B), ceramic coated headman headers (part# 39806), Eastern high flow bullet cats, Magnecor ignition cables (part # 85196), Mallory distributor (part # 4764301). It's all about how much you want out of it.
Old May 6th, 2016, 11:19 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I replaced my ECU with a used ECU from a Discovery. The 4.6 now runs great. So that makes me wonder what ECU was put into my truck by the guy I paid big $$ to do the work. Any idea what this ECU is out of? Hooked up to the wide band computer, the truck runs completely differently.
ID:	148911   Click image for larger version
Old May 6th, 2016, 11:27 AM
phoenix37's Avatar
phoenix37
john
google?
1997-1999 Discovery I Engine Electronic Control Unit ECU - ERR6738
Old May 6th, 2016, 11:42 AM
jason1st
Jason Crandall
Yup. Well then something is wrong with this one.
Old May 6th, 2016, 11:47 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Sell it for cheap in the used section... LOL
Rent my
Old May 6th, 2016, 12:18 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Jason, did you install the 4.6 chip that you were considering?
Old May 6th, 2016, 12:30 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Did you see any corrosion in the original ECU? Pull the plastic covers and see what prom numbers you had.
Old May 6th, 2016, 01:32 PM
You should open it up, I bet there is some corrosion inside.
Old May 6th, 2016, 02:26 PM
jason1st
Jason Crandall
No. I installed a used 4.6 ECU as troubleshooting and it now runs so well I may do nothing til I pull the truck apart again.
------ Follow up post added May 6th, 2016 02:27 PM ------
Will do
New soft top header bar issue...help? josh-man Defender Technical Discussions 7 November 25th, 2013 12:31 AM
New Guy w/Brake Issue... emmodg Defender Technical Discussions 5 May 12th, 2011 08:30 PM
New Brake Issue bcourtney Series Technical Discussions 5 June 19th, 2010 06:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Private Messaging "Read Reciept" issue? chrisvonc Support & Suggestions 0 May 23rd, 2004 08:51 AM
