Nev (89 110) rhd - Defender Source
Old August 26th, 2015, 10:28 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Nev (89 110) rhd
Picked up a 1989 110 2.5TD, RHD while I was stationed overseas . . . a bit rough. Had a little done to it to start off with and have a bit more to do.
What I started out with:
ID:	128034   Click image for larger version
ID:	128036   Click image for larger version
ID:	128038   Click image for larger version
ID:	128040   Click image for larger version
Old August 26th, 2015, 10:37 AM
wanabewheelin
Michael Sword
Plan to start out:
2 new front doors, didn't feel like playing around with the cancer on these
Seats were ok, but started looking for some newer ones out of a Puma and also looking at the kits to recover them. Ended up picking up the front 2 and middle row out of a 2014 for about the same cost
Dyanamat
Stereo
new belts, hoses, fluids
paint
head liner was rough so had it done
added a roof rack and RTT
adding more pics below
Old August 26th, 2015, 10:44 AM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
There's something special about patina on red rovers. Looks like a fun project (welcome back).
Old August 26th, 2015, 10:51 AM
wanabewheelin
Michael Sword
Removal of seats, prep for paint, install of Dynamat and seats, headliner etc.
ID:	128043   Click image for larger version
ID:	128045   Click image for larger version
ID:	128047   Click image for larger version
ID:	128049   Click image for larger version
Old August 26th, 2015, 10:55 AM
wanabewheelin
Michael Sword
More of this than I would have liked. A project that will need to be tended to at a later date, repairing properly.
ID:	128051   Click image for larger version
ID:	128053   Click image for larger version
Old August 26th, 2015, 11:00 AM
Man, are you *sure* you need paint? I thought my red was toast, but it came right back to life with a day of buffing with 3M compound:
ID:	128056 Click image for larger version
EDIT: whoops, just saw your recent post with the paint strip down .
Old August 26th, 2015, 11:09 AM
wanabewheelin
Michael Sword
Back from the paint shop . . .
ID:	128058   Click image for larger version
ID:	128060   Click image for larger version
ID:	128062   Click image for larger version
Old August 26th, 2015, 11:22 AM
Does look pretty good! Just clean up the overspray on the chassis frame horns, tie rod, etc .
Old August 26th, 2015, 11:31 AM
wanabewheelin
Michael Sword
Dynamat going in, head liner . . .
ID:	128064   Click image for larger version
ID:	128066   Click image for larger version
ID:	128068   Click image for larger version
ID:	128070   Click image for larger version
Old August 26th, 2015, 12:15 PM
wanabewheelin
Michael Sword
new carpet going in, head liner, rear bumper, seats being fitted, came together nicely
ID:	128073   Click image for larger version
ID:	128075   Click image for larger version
ID:	128077   Click image for larger version
ID:	128079   Click image for larger version
ID:	128081   Click image for larger version
Old August 26th, 2015, 12:28 PM
wanabewheelin
Michael Sword
Seats fitted, MUD console and stereo, RTT tested SAT . . . this is on the outskirts of London, we also camped in Belgium and Normandy. PRICELESS!!!
Name:	seats final.jpg
ID:	128083   Click image for larger version
Name:	Three Rivers-20141001-00090.jpg
ID:	128085   Click image for larger version
Old August 26th, 2015, 12:29 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
That looks really nice.
Is the truck still in the UK or back in Wash DC?
Firemanshort
1980 Stage One 109
Sterling, VA
Old August 26th, 2015, 12:31 PM
wanabewheelin
Michael Sword
Shocks were rusted badly so replaced all and added a 2" lift in the process as it was no additional cost . . . seemed to be a no brainer
ID:	128087   Click image for larger version
Old August 26th, 2015, 12:32 PM
wanabewheelin
Michael Sword
She is thankfully here in DC, my DD . . .
Old August 26th, 2015, 01:43 PM
wanabewheelin
Michael Sword
So upon picking it up at the Vehicle Processing Center, she was overheating something awful. 3 gallons low on coolant believe the guys said. The Kenlow had malfunctioned at some point, ended up replacing the entire unit and luckily doesn't appear any other damage has been done to the engine. Have been driving it for about a month daily with no overheating.
Have a laundry list of items to get knocked out:
Heater fan seems to be out, have read up on this on the forum. Looking to replace it with perhaps this unit (Thanks Red90)
http://www.summitracing.com/parts/su...hartsandguides
Am working on sealing up the cab, the guy that did some of the work replaced the 2 front door seals with after market seals and they curve at the upper front corners which allows a water and air to come in. He also didn't align the doors when he replaced them, they didn't close very well, I have learned a ton about the doors since last year. They close much better.
Have new seals on order. Think this will help a ton. Also have new seals on hand for the front vents, just need to install.
Just installed the KBX High Force wing top vent, don't think this is the answer to my problems, but looks cool
Wipers don't seam to stop when I turn them off, read up on this and will see if any of the items I found will work. Believe I may have water coming in and have a short on the wiper motor, very possible. Plan on pulling down the head liner to see where water is coming in. Initially the sun roof was leaking, have fixed this, the 1000 mile drive from London to Naples, Italy was even longer as it was raining the majority of the time and constant cold drips made me want to strangle someone. It happens . . . I do recall asking him if the sunroof leaked, the gasket was old and had pulled back. Ended up cutting it in the middle back and applying some marine caulk to seal it up until I could get a new gasket ordered.
Also have the wonderful Wiper Slap, so will need to see if I can work some magic on that. Set screw huh . . . we will see
Put 2 speakers in the front dash, wanted to put a set in front doors and a set in the middle row doors, but we shifted gears as it didn't seem like the doors would support the heavy speakers. Ended up putting them firing forward in the battery box on both sides. Sounds good, down side is unless I turn it up super loud you can't hear it in the back.
Have a amp pushing it, it gets loud and will blow you out, but then the wife isn't happy.
Will have to run another set in the rear to resolve the issue and make
Wife also wants a step on her side, might better get this done sooner than later
Also debating a Webasto . . . (pros/cons)???
Have oil leaking from the axle tubes, from research it sounds as if the dust caps need to be replaced. I have crappy plastic ones which are loose and cracked or scared in areas. Have new OEM (rubber) ones on order.
Was reading last night about wipers and saw that it was suggested to replace the fuse box for the newer style. Not something on the top of my list, but think I may add it to the list, just down a bit. Hate the old style, if only because I end up breaking them half the time or can't tell if they are blown the other half. Need to add a few things anyway so might be a good time to do just that.
Insufficient leg room in middle row due to battery box . . . still working on fix for this
complicated by me being 6'1" and having moved the drivers seat back additionally. The newer style seats from the Puma seam to sit much flatter, they need to have the front edge moved up to support the thigh which would also tilt the back of the seat I believe. May have to cut into the rear wheel arch, have seen the done, not in my wheel house. Anyone in the DC area like to weld aluminum??
Made room for the seat to be pushed back by putting the smaller 2 person bench on each side vice the 3 person bench. Just need to figure out the rest, which is the hard part unfortunately.
Additional items completed:
Replaced front seat belts.
Installed tree sliders
Installed front winch bumper (need winch)
Installed MUD Seat rails
Think that gets us up to date . . .
Old August 26th, 2015, 03:49 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Looks great. How was the bulkhead? Did you have to repair the upper part?
Also where did you source the "country" stripes decals?
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Great looking truck. Which paint shop did you work with?
Old August 26th, 2015, 04:05 PM
wanabewheelin
Michael Sword
Some work was done to it, all of the work above was done last year over in the UK. Decals were sourced over there as well. I can see if I can get the contact. They were not spendy if I recall
------ Follow up post added August 26th, 2015 11:07 PM ------
The paint was done in the UK as well, not a quality job, my guy has since shifted to a new shop.
Old August 26th, 2015, 04:11 PM
1of40's Avatar
1of40
1of40
No biggie. It'll fit in with 90% of the rest of our old Rovers then.
Old August 30th, 2015, 09:39 PM
wanabewheelin
Michael Sword
Made a little progress, pulled the headliner down and had my son up on the roof with hose so we could find leaks. Not as bad as I thought it was, but did find a few. Will post pics later. Rear vents, couple other places. Marine adhesive caulk like I used on the sun roof.
Also started to build the rear speaker boxes for the upper corners. Have the MDF all cut and almost all dry fit. Just ran out of time tonight, had to get the truck back together.
Took a look at the wipers for the wiper slap issue, might be a more serious issue.
All for now . . .
110, rhd
NEV :: 1989 Land Rover 110 wanabewheelin Defender & Series Truck Registry 0 December 2nd, 2014 04:19 AM
Series 3 RHD 2.25 Petrol :: 1977 Land Rover Series 3 RHD 88" 2.25 Petrol fsquared11 Defender & Series Truck Registry 0 September 20th, 2013 12:42 PM
110 TDI RHD Station Wgaon For Sale 107One For Sale - Vehicles 10 November 24th, 2007 02:23 PM
Feeler Janey 1984 RHD V8 110 evilfij For Sale - Vehicles 69 November 6th, 2007 02:49 PM
RHD D90/110 Steering Guard JohnC The Vendors Loft 0 November 4th, 2005 02:02 PM
