NAS Toylander build - Page 3 - Defender Source
Old September 12th, 2013, 04:42 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I used Kilz oil based primer, I believe it has some waterproofing properties to it, on my MDF. I believe the MDF was as close to the MDF Richard at toylander recommended. I did use wood glue on the edges of the MDF. On the underside I used caulk along all the edges, seams and everything. Then I painted the underside black with an outdoor spraypaint.
For the body I used automotive paint. Don't do that. I would use the Kilz again, but this time I would just use an exterior latex paint.
The kids run it into all kinds of things. Our has been driven in mud, water, rain, sprinklers, left in the yard and sprinklered on. The wood has been fine.
Old September 12th, 2013, 05:05 PM
How about after painting, undercoating the bottom? Look at expedition trailer builds for ideas about keeping wood from rotting. Lots of them on expedition portal.
Old September 13th, 2013, 05:46 PM
Loic, this might interest you for batteries
http://www.ebay.com/itm/2pk-12V-8AH-...-/400543662768
Originally Posted by pendy
I'm here for the D's
Old September 16th, 2013, 11:21 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by tjfslaughter View Post
I have worked with water resistant MDF. Take a scrap piece and throw it in a mason jar with water before you do anything and see what you are working with.
Never assume anything right??? Jeeze.... I took a small piece and put it in a glass of water. Made sure I rubbed it good to remove as much air/allow it to soak as best as possible as quickly as possible. I let it sit for two hours. Took the piece out of the slightly yellowished water and it looked the same as before (except wet). Impressed! I thought it'd expand like crazy!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 17th, 2013, 04:02 PM
MonLand
Loic Fabro
September 2013 - Accelerator pedal
Got a chance to work on the accelerator pedal over the weekend. I've been looking for the hinge portion of it and figured I would create a spring-loaded hinge. I got the spring for a set of $1 set of 3 spring-loaded plastic clips. Then I used piece of the (future) aluminum trim for the body to make the hinge. Spring mechanism is looking strong enough, hinge is definitely strong enough and will be lightweight!
ID:	80108   Click image for larger version
MonLand
1995 D90 NAS
1996 Discovery NAS
crazyproject, getalife, nas, timesink, toylander
what does NAS mean? danpetrov Defender Technical Discussions 15 December 17th, 2012 08:56 AM
NAS 90 Project NORAD 110 Crew Build SafariHP Truck Build-up's & Restores 37 May 16th, 2012 10:19 AM
FS Parts Leftover from NAS 110 Build surf110 For Sale - Parts 32 March 2nd, 2010 11:24 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
