NAS 110 145/500 Restoration - Page 8 - Defender Source
Old November 19th, 2009, 04:59 PM
Actually I do need those brackets. The rusty bolts metastasized and spread to the surrounding metal.
Old November 19th, 2009, 06:12 PM
Hmmm, those I might not have. I think they are with the old t-pieces.
Old November 19th, 2009, 06:40 PM
Worst case scenario I can just buy 'em - I'm sure they're not rare.
Old November 19th, 2009, 07:10 PM
Ok, let me go dig in the garage.
Old November 29th, 2009, 09:36 AM
Lots of little jobs over the holiday weekend. This stuff takes up so much time.
I finally got the new felts put in the side windows. Just cleaning those things up makes such huge difference.
If you forget to remove your vent screens before galvanizing, you will spend several hours with the 5/64ths drill bit and the approximately 6400 holes in the mesh.
Continuing my trend for excessive refinishing, I disassembled the pedal boxes and send them out to be blasted and powder coated. The do look really spiffy now.
Reinstalling the c-pillar cage supports is pretty awful. I didn't take note of some of the holes that needed to be drilled into the rear part of the t-piece before I installed it, so I had to work the drill in at an angle. The support is a really tight fit in the space anyway.
Some of the other stuff bolts up really easily, got the front cage supports up off the floor and loosely attached - much easier to re-tap the holes that way. Also started putting all the various plumbing bits back on.
The rest of the truck goes to paint at the end of the week. I hope evilfij sends me the sill plates in time
Name:	DSCF4571 - Resized.jpg
ID:	23279   Click image for larger version
Name:	DSCF4585 - Resized.jpg
Name:	DSCF4584 - Resized.jpg
ID:	23281   Click image for larger version
Name:	DSCF4591 - Resized.jpg
Name:	DSCF4594 - Resized.jpg
ID:	23283   Click image for larger version
Name:	DSCF4595 - Resized.jpg
Name:	DSCF4568 - Resized.jpg
Old November 29th, 2009, 11:06 AM
Looking good Jim!
Old November 29th, 2009, 11:38 AM
They are sitting in a box. If I fail, I will buy you sliders as RN has mantec for $349. edit: do you really need working vents. I never use mine as I assume if i do they will leak sort of like the sunroof on the lwb that has not been used in 5 years.
Old November 29th, 2009, 01:18 PM
Alright, that sounds like a good offer to me!
Of course I need vents. It would always bother me if I left the screens blocked. My vents on the 90 only leaked until I realized someone had cranked away on the vent levers, which left them bent and incapable of closing completely. As far as I'm concerned, they work fine.
Old November 29th, 2009, 01:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jim, That would drive me nuts. I always remove the screens prior to galv. as well. YOu could always remove the screens and run without them. Series trucks do not have them. My IIa use to get so much air flow it was rediculous.
Legend in My Own Mind.
Old November 29th, 2009, 04:18 PM
I actually started drilling because removing them seemed to be too much of a hassle, and a big mess. They're pretty much galvanized on now. I'm OK with the drilling, a wire brush cleans up the rough edges really well and the shape of the screen guides the drill bit, so the overall effect is very even and properly-spaced.
Old November 29th, 2009, 06:09 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Im surprised you just didnt take a blowtorch and an air gun to the glavi'ed vents since zinc has a low melt point.
Old November 29th, 2009, 06:12 PM
I did, but it set the paint on fire.
Old November 29th, 2009, 07:17 PM
Looks great.. Did you use ECR's stainless brake lines?
Old November 29th, 2009, 07:38 PM
Yep - ECR stainless fuel and brake lines.
Old November 29th, 2009, 09:15 PM
Jim, when I get a NAS 110, I am going to send it to you to restore. Are you bringing the 90 to Germany too?
Old November 29th, 2009, 09:39 PM
The 90 is going to stay in the states at an undisclosed location. I can't have you people trying to liberate it, and my wife would park it on my chest if I tried to sell it. I'm thinking it needs a color change to G4 orange and a return to soft-top configuration when we get back to the states on a permanent basis.
I've got my wife to agree-in-principle to the idea of a Rover project every 5 years. So as soon as the 110 is done, I'm going to start scheming for a 130 project for the 2015 restoration season! Of course if I'm assigned to Upper Asswipistan or the Kingdom of Shithed at the time, it might have to be delayed.
Old November 30th, 2009, 08:50 PM
KKilo23's Avatar
KKilo23
Kenny
Looks great Jim!
Old December 1st, 2009, 05:14 PM
Sills went out yesterday.
Ron
Old December 1st, 2009, 05:17 PM
You're a great American fij.
Old December 1st, 2009, 05:37 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
The SIII vents go in nicely with a few rivets once you gnaw the old ones out.
110, nas, nas 110, restoration
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
NAS Defender 110 AirConditioning Parts COSteve Defender Technical Discussions 5 May 19th, 2004 03:54 PM
