NAS 110 145/500 Restoration - Page 7 - Defender Source
Old November 1st, 2009, 01:57 PM
Slow progress. This weekend all I got done was installing the ECR LED's - its always nice to install parts that have been sitting in your stash for several years.
Fortunately, the NAS plinths do cover the holes left by the old trailer-style lights, but only just. I had to carefully place the first light on each side to ensure that the inside light would cover the big hole.
Not much explanation required for the pix, but the old hole is pointed out with the red arrow. Not that I'll be going back to trailer lights, but this mod is theoretically reversible.
One thing to note is that the roll cage support is in the way if you try to install the regular NAS-style lights with bulbs. The ECR LED's are flat on the back, so they don't "foul the cage" as they would say in brit mags.
Name:	DSCF4517 - Resized.jpg
ID:	22596   Click image for larger version
Name:	DSCF4518 - Resized.jpg
Name:	DSCF4519 - Resized.jpg
ID:	22598   Click image for larger version
Name:	DSCF4520 - Resized.jpg
Name:	DSCF4521 - Resized.jpg
ID:	22600   Click image for larger version
Name:	DSCF4522 - Resized.jpg
Old November 17th, 2009, 08:45 PM
Some more slow and minor progress last weekend.
The back seat is installed. There was some space remaining between the cross-piece on the frame and the part of the tub where the seats mount, so my wife made some ABS spacers in Solid Works and cut them out on a laser cutter. Not that there would be a problem with the galvanized steel against aluminum, but its also nice to have a plastic piece in there to separate the metal parts.
Eww, seats need a cleaning.
On the motor I've almost finished reassembling the parts I pulled off and sent to the powder coater. These were previously a gold color, but I had them re-done. Next mission is to swap out the valve covers and plenum so they aren't white.
And my assistant is always ready to use her rubber mallet to "fix the ro-ro." I'm going to have to go back and find all the bolts she's stuffed into holes, fix the scratches she's putting in the paint, and re-buy some of the parts she is carrying off and hiding - but I wouldn't miss those opportunities for anything at all.
Name:	DSCF4548 - Resized.jpg
ID:	23046   Click image for larger version
Name:	DSCF4550 - Resized.jpg
Name:	DSCF4551 - Resized.jpg
ID:	23048   Click image for larger version
Name:	DSCF4553 - Resized.jpg
Name:	DSCF4554 - Resized.jpg
ID:	23050   Click image for larger version
Name:	DSCF4559 - Resized.jpg
Old November 17th, 2009, 09:32 PM
Priceless!
Not the quality time with your kid, but the fact your wife made you spacers using Solid Works and a laser cutter!
Old November 17th, 2009, 09:58 PM
KKilo23's Avatar
KKilo23
Kenny
Looking great!!
Old November 18th, 2009, 09:47 AM
The picture of that little girl with a big rubber mallet next to the windsheild gives me apprehension. It may work with your daughter. Mine would have taken a swing...
Cabell's 3 yr old daughter calls rovers RoRo as well.
Old November 18th, 2009, 11:01 AM
discotdi
Todd Miller
Land Rover
I am pretty sure this has been covered before, but how did you get the LR limited ed. Badge looking so good? We have D110 LRNA/1 here at our dealership but the number badge is grey and faded. I would love to 'restore" it.
Thx
Old November 18th, 2009, 12:42 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Originally Posted by JimC
The plaque was pretty easy, but it was a few steps. I bead blasted it, the powder-coater put a flat black on it. I sanded the black off the letters and then they did a gloss clear powder coat over the top. It should be pretty good for a long time now.
yes and this is what he said.
Old November 19th, 2009, 08:41 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
JimC,
What changed your mind on the engine, I recall a wish list for a TDI, even a 2.8 TVG?
Just curius as to why the turn around, although the 4.6 looks very good & nicely done.
Old November 19th, 2009, 09:01 AM
KKilo23's Avatar
KKilo23
Kenny
Originally Posted by FlaD90
JimC,
See Post 102 http://www.defendersource.com/forum/...&postcount=102
Old November 19th, 2009, 09:06 AM
JimC,
German emissions laws. In about a year I'll be assigned in Germany, and they actually check the emissions compliance of the engine which is installed. Petrol engines with catalytic converters get a Green Sticker, which means you can drive anywhere. Diesel engines get a Green, Yellow, Red, or no sticker at all depending on their level of emissions compliance, and many cities restrict vehicles without green or yellow stickers. The 2.8 only qualifies for a Red Sticker, and I'd have to have the latest Puma diesel to get a green one. Moreover, the place where I'll be assigned is in a Green Sticker area, so if I ever want to drive to work I had to install either a gas engine or a Puma diesel.
Clear as mud?
Old November 19th, 2009, 10:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thx
Drill the rivets out
Use a light sandpaper on the badge. Make sure you hit every area that is black
Use a prep clothe to clean
Spray with krylon semigloss black
Sand off raised area for a nice new looking badge
Old November 19th, 2009, 10:34 AM
The only problem with that is that the aluminum remains unprotected and can start corroding again. I went with a clear powder coat to avoid that, but the method is pretty much the same.
Old November 19th, 2009, 11:33 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
This is what I plan on doing, very good Jim.
Old November 19th, 2009, 11:51 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Looks great Jim.. you better stop over with that thing when you are done....
Legend in My Own Mind.
Old November 19th, 2009, 12:44 PM
discotdi
Todd Miller
Land Rover
Jim- you used this method but then used a clear coat protectant on the whole badge?
Old November 19th, 2009, 12:49 PM
To be specific:
1) removed badge
2) bead-blasted
3) had it power-coated flat black
4) sanded down the face
5) had it powder-coated clear gloss all over.
I don't know what it cost, it was with a bunch of other parts. You could accomplish the same thing with spray paint, but as far as I'm concerned, anything worth doing is worth over-doing.
You'd better stop off and see it before I leave the country again. I'm gonna finish putting the body together and then its going to Pendy for motor tuning, under-body neon, toyo proxes, etc.
Old November 19th, 2009, 02:51 PM
discotdi
Todd Miller
Land Rover
thanks Jim
Old November 19th, 2009, 03:20 PM
Did your 4.2 ECU and old valve covers and wires I sent you?
When do you need the sills by? How are you going to paint them?
Old November 19th, 2009, 03:44 PM
Jill says a box showed up from you, so yes.
I need the sills by early December so they can go to the paint shop when I take the roof.
Old November 19th, 2009, 04:21 PM
Ok, will see what I can do. I take it you don't need the little brackets or do you?
110, nas, nas 110, restoration
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
NAS Defender 110 AirConditioning Parts COSteve Defender Technical Discussions 5 May 19th, 2004 03:54 PM
