NAS 110 145/500 Restoration - Page 10 - Defender Source
Old December 31st, 2009, 04:28 PM
Jim,
How's it coming along this week?
Have you found out your deployment date yet? Let me know if you need me to come up and do that driver's side vent before you leave.
Old December 31st, 2009, 08:38 PM
Ha ha, I'm out of town this week, and I ship out on the 15th or 16th. You're more than welcome to come drill if you want, and any one else is always welcome. I can't always guarantee brats though...
Old January 7th, 2010, 11:22 AM
Lots more work done, but now its getting to be stuff that isn't so visible. The big deal is that the cage is on and lines up just fine.
I tried stretching the rubber cage foot gaskets (like on the NAS 90s where the front cage meets the fender) around the rear cage feet, but I didn't like the result at all. What I ended up doing was getting out some more of my trusty pond liner. I lined up the cage support until it was correct, then I sealed the hell out of it with 3M 4200 and basically glued on the rubber pond liner (I did make bolt holes before gluing it on). So the cage supports should be water tight before bolting on the cage. Then the cage itself just bolts right on top and everything should be (fingers crossed) OK. Plus the black backing helps disguise one damaged cage foot and keeps it from being so obvious.
Name:	DSCF4733 - Resized.jpg
ID:	24179   Click image for larger version
Name:	DSCF4729 - Resized.jpg
Name:	DSCF4728 - Resized.jpg
ID:	24181   Click image for larger version
Name:	DSCF4732 - Resized.jpg
Name:	DSCF4734 - Resized.jpg
Old January 7th, 2010, 11:40 AM
Nice! Think you'll get this completed before you go Jim?
Completed as completed can get anyway - drivable, registerable etc.
Old January 7th, 2010, 11:59 AM
Nope, I'm making arrangements to have a noted Rover Specialist spend a few months ministering to it.
Old January 7th, 2010, 12:16 PM
surf110's Avatar
surf110
Ze
130 Project
Jim. Great idea on the pond liner. My cage lines up like s****t. Need to redo it. Did you set the cage in place first then tightened up the inner supports?
Old January 7th, 2010, 12:19 PM
Ugh, sorry to hear that.
Originally Posted by pendy
I'm here for the D's
Old January 7th, 2010, 12:24 PM
I set the supports and aligned them so that the cage feet would sit on them properly, then bolted them in place. I have a couple feet that don't conform well to the shape of the tub, but its not too bad. At least all the major pieces bolt together on top. I did have to use a quick-clamp in a couple places to get holes to line up.
Old January 7th, 2010, 05:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
So when I did my cage I tried the 90 feet as well and hated the results. I didn't even like how they came out on the front. I removed them all and have not sealed the cage. I have a tube of 4200 but haven't tried it yet. I didn't repaint my truck so you can image where the feet were it looks like poop as the old white sealant remnants are there. The rubber feet would have covered it but since that wont work and I am not painting the truck I want to know more about this pond liner you did.
Old January 7th, 2010, 06:01 PM
Jim, where did you say you were storing the 90? :-)
Old January 7th, 2010, 06:37 PM
I used the thicker pond liner, there are usually 2 thicknesses available. The thinner one is shinier and "blacker" and the thicker one is more "rubbery" looking. It slips easily between the cage and the body, so you can trace the outline quite easily. Cut it a bit oversize if you want, it will look good. I cut a couple of mine a bit over to cover some corrosion pinholes in the body.
At an undisclosed location!
Old January 7th, 2010, 06:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
Can you show me better pics of the all the feet to show me. Where did you get the liner?
Old January 7th, 2010, 07:16 PM
What else do you want to see exactly?
Lowe's!
Old January 7th, 2010, 07:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
I want to see it with the bolts through it. The whole foot at once. I guess I am confused as to what it covers if you cut it the same size as the foot.
Scott you are in luck! This narrows it down to two locations.
http://maps.google.com/maps?f=q&sour...sed&hnear=&z=4
LOL
Old January 7th, 2010, 07:46 PM
We need to rescue it until Jim comes home, as Rovers especially diesels don't like to sit around for years.
Old January 9th, 2010, 09:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
Jim
So why cover the feet if it is an exact fit?
Old January 9th, 2010, 09:37 AM
It covers the hole in the body. The feet are definitely not exact fits to the tub (but they line up so that I can bolt it down). Even if the feet were a perfect fit, the metal on metal would never be a watertight seal. My idea was to ensure the hole was sealed (except for the bolt holes) and then use sealing washers for the bolts to prevent water going through there. I obviously want the best fit possible, but an exact fit isn't necessary.
Old January 13th, 2010, 11:26 AM
Been doing lots of work, but not a lot that is exciting to see. Things like installing calipers, brake lines, tapping holes, etc don't make good porn.
I do though have a mostly installed new-style dash and a lot of rivets in the body.
Saturday the 16th is the last work day on the truck before I ship out. Anyone who wants to come by is welcome. If several people come, we can do food again. There should be lots of fun things to do now like bleed brakes and find un-tightened bolts/screws.
Name:	DSCF4752 - Resized.jpg
ID:	24329   Click image for larger version
Name:	DSCF4753 - Resized.jpg
Old January 13th, 2010, 12:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
Looks good
110, nas, nas 110, restoration
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
NAS Defender 110 AirConditioning Parts COSteve Defender Technical Discussions 5 May 19th, 2004 03:54 PM
» Defender Registry
Dennis
juddy
1994 D90
tgraham
Add your Defender
