My 1988 LHD 110 Heritage Buildup - Page 8 - Defender Source
Old August 26th, 2017, 01:48 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Nice work. Looking like a real truck now.
Old September 13th, 2017, 04:42 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
Safety devices interior roll cage mounted. A little fiddly to install but it is in. FYI Safety devices instructions are horrible. It was easier for me to organize bolts and count the number/size of holes to figure out where they go. It was so bad that they have the upper horizontal pieces lightly stamped with which side they go on and wether it was top or bottom. To make a long story short, after spending several hours trying all different types of combinations, I called them to find out that they sometimes stamp them incorrectly.
Old September 13th, 2017, 04:45 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
60% of the time, they're right every time.
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old September 13th, 2017, 05:09 PM
AdamSanta85
91' D90 200TDI
Oh man. Looks good! I went through similar situation with my SD roll cage. 30 or so emails later... At least they were responsive and helpful.
Old September 13th, 2017, 05:28 PM
The Dro
Dro
1988 Ninety
Excellent work. Love the truck
Old September 13th, 2017, 06:04 PM
DiscoDavis
C Davis
1990 110, 1995 Disco
Love the internal cage. Good choice!
Old September 19th, 2017, 02:00 PM
stancey's Avatar
stancey
steven stancey
Fitted door handles, strikes, etc. only issue I had was the front left door seal pushing the door out. I needed to order a new door handle that is made for a key, so we will see if it compresses. If not, I might be stuck with buying a $80 lr door seal. Ugh
Also dry fit the rear side windows. The window latches are hitting against the roll cage. We are going to try and take apart the frames and switch the front piece of glass, so that the handle drops to the bottom, which should allow them to clear the roll cage.
Starting soon, then off to muffler shop.
Old September 19th, 2017, 05:27 PM
airbalancer's Avatar
airbalancer
1988 RHD 110 5 Door
Man that looks good!!
Old September 20th, 2017, 01:22 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Indeed it looks good. I had a SD cage on a 90 years back, it seemed to go together ok, but I have a P&P one on my current 110 and used their template to drill the holes, which all were in the wrong place :-(
Old September 20th, 2017, 08:10 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Looks great, Steve.
How did you finally resolve your radiator/fan clearance?
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old September 20th, 2017, 11:35 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Doin' us proud!
Old September 20th, 2017, 12:03 PM
stancey's Avatar
stancey
steven stancey
We ended up moving the radiator forward about 4-5". I could do this because the heritage grill bump out is a bit longer than the normal a/c grill. By doing this, I got rid of the fans that I got with Nick's setup and put 2 - 14" fans that pull 2750 cfm. We now have a shroud on it. We had to modify the slam panel, offset the pin on the hood, and fabricate some brackets for everything, but all in all, I think it looks really good. If someone wanted to undue this for some reason, it would require a new slam panel, grinding off some radiator tabs that we welded in, and that is it. I feel like this is the best setup we could think of. If it doesn't work to keep the condenser cool, then I have nothing else to offer b/c I have no room at the front to toss in another fan. I'll take some pics and post them without the radiator in so that you can see what was done...
Old October 12th, 2017, 09:52 AM
stancey's Avatar
stancey
steven stancey
Here are some pics of how the radiator got mounted. I wish I had a better angle of the fans in the shroud b/c they look really good.... We put 2- 14" high volume perma cool fans. Notice the condenser (which is pretty much why we did this) and how the transmission cooler is mounted right under it. After doing some research, I determined that the trans cooler in Nick's BOM was undersized, especially in Central Texas towing a boat. I ended up getting a much larger one, which I believe had about double the cooling capacity. Everything is snug, but I think it fits perfect. I'll paint the rest of the plastic pieces when I know I won't take them off and on a hundred more times. Still haven't started it yet b/c I was waiting on a couple of trans cooler line fittings... fingers crossed.
ID:	312153   Click image for larger version
ID:	312169   Click image for larger version
Old October 12th, 2017, 09:55 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
I've said this before. LR genuine door seals are night and day better than aftermarket. Totally different.
Old October 12th, 2017, 11:08 AM
stancey's Avatar
stancey
steven stancey
I think you are right about that. I finally got the new handle on the driver door, so I'm able to latch and shut it. Its tight, but I want to let it stay closed for a few weeks and see what happens. I might be investing in a LR genuine seal in the future...
Old November 1st, 2017, 04:45 PM
stancey's Avatar
stancey
steven stancey
Started yesterday. No mufflers, just cats.
https://youtu.be/dIJAElz-93M
Old November 2nd, 2017, 03:52 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Nice
110, lhd
MNIVAN :: 1988 Land Rover 1988 Defender 110 Brentflyfish Defender & Series Truck Registry 0 February 11th, 2016 06:20 PM
M416 buildup javelinadave Smaller Projects 7 October 5th, 2014 02:03 PM
19J pressure buildup grapplerdan Defender Technical Discussions 22 July 18th, 2014 10:39 AM
1988 110 3.5 v8 lhd DutchSafari For Sale - Vehicles 23 August 20th, 2013 06:46 PM
1988 Land Rover 110 V8 LHD johan For Sale - Vehicles 2 August 8th, 2013 11:51 AM
