My 1966 Series IIa 300tdi Defender Build - Defender Source
Old April 21st, 2015, 10:25 AM
MountDisco
Christian Toth
97 d-90 rolling chassis
So after having a couple series rovers I have decided to build my very own Frankin-Rover.
Major Parts include:
NAS Defender 90 frame
Complete 300tdi engine and trans
Defender axles
And Series IIa with rotted frame (Rihno Rover)
I've started setting up the workshop (barn) with the axles under the frame.
I've bought cranked front radius arms and adjustable rear trailing arms to accommodate the RTE 3" springs (Told that they will actually be 4" on a 90)
1)
First question is, what shocks, shock towers and brackets do you recommend? (Frame is compleyely bare)
Thanks in advance for the help!
-Christian
------ Follow up post added April 21st, 2015 08:27 AM ------
Here is my shop
Old April 21st, 2015, 12:08 PM
Hmmm, this seems vaguely familiar in some way.....
Old April 22nd, 2015, 10:27 AM
MountDisco
Christian Toth
Also, tire size would be helpful too, hoping not to cut the fenders. I have the 16 inch rims.
I had on a previous series, size 235-85-16 with parabolics, but on this one I'll have a lot more hight, so not sure if I should run a bigger tire.
Thanks!
------ Follow up post added April 22nd, 2015 08:31 AM ------
Bill do you have some insight for me?
Here is my shops
Old April 22nd, 2015, 10:37 AM
Here is my shops
Start here:
http://www.defendersource.com/forum/...ersion+project
MountDisco
Christian Toth
For some reason my pictures are not posting
Old April 22nd, 2015, 10:39 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Use Imgur.com Christian
Old April 22nd, 2015, 10:46 AM
Why such a big lift on a 90? A 3 or 4" lift seriously messes up all of the suspension geometry, IMO. Doing it properly is very complicated.
Old August 20th, 2015, 11:07 AM
MountDisco
Christian Toth
D90 Tub or Frame Chop?
Ok, so I've reached a really tough decision. I've realized where the 2 inch difference is between the 88's and 90's, it's the rear tub.
So I am left with this decision:
1) buy a D90 rear tub which is $2,200 (factory takeoff, only one I could find)
-cons are my hard top won't fit
2) use my series tub and cut the middle of the frame down 2 inches.
-I don't trust myself doing this, and fear about messing up the structural integrity of the frame.
-not sure where I'd cut out the 2", and would also require me to move the front tub mounts on the frame.
All opinions and suggestions are helpful.
Again I'm in Baltimore
Christian Toth
Current Inventory:
Kitted out 2004 Discovery
1966 IIa (rolling body)
97 NAS D-90 rolling Chassis
Old August 20th, 2015, 11:12 AM
It is not 2". It is a 5" difference in the wheelbase (88" versus 92.9"). I'm pretty sure most of it is in the cab. The bulkhead is further back.
Old August 20th, 2015, 11:28 AM
MountDisco
Christian Toth
Oh, ok. So what I meant to say is, with the firewall installed, it's a 2" difference.
So I'd chop it in the middle section
Christian Toth
Current Inventory:
Old August 20th, 2015, 11:34 AM
The difference is all in the tub. Cab is the same.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 20th, 2015, 11:57 AM
Depends how you look at it. The bulkhead is further back in a Defender.
Series...
Defender 90
Old August 21st, 2015, 04:41 PM
Series...
Defender 90
yup but the bulkhead is part of the tub. And 109 2 door bulkhead and tub front is the same as defender 90 and 110s. Only the Series 88s are different.
Present:
1987 RRC- "Chewy 2"
Past:
Old August 21st, 2015, 04:59 PM
MountDisco
Christian Toth
Oh, by bulkhead, I meant firewall. So the distance of the door jam is 2 inches longer with the 88 tub
Christian Toth
Current Inventory:
Old August 21st, 2015, 09:18 PM
I did something similar, but shortened a 110 frame down to fit a 109" body. IN my case I was doing the rear crossmember as well which helped - as others are saying it's not as simple as just taking out a section of the frame, but you want the rear wheels to line up in the wheel wells, and also maintain the body mounting positions.
That said, where you want to cut is somewhere that doesn't affect the suspension or the amount of work you will have to do will ripple even further. This page shows where I cut mine
http://www.defendersource.com/forum/...-41368-10.html
Originally Posted by pendy
I'm here for the D's
Old September 3rd, 2015, 04:32 PM
98 HOO's Avatar
98 HOO
Josh Smith
1960 Series 2a/D90 Hybrid
Mine is somewhat similar to what you are describing. It has a 90 frame and tub, but the series windscreen. To make a top that worked, a 109" roof was cut down so it would fit the 90 tub, but still bolt to the series windscreen.
Old September 4th, 2015, 01:24 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Just sent you a PM. This is my last Ser II A 300 Tdi hybrid
ID:	128774   Click image for larger version
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 4th, 2015, 01:54 PM
roverex, that looks amazing.
Is that a series dash on a defender bulkhead or a series bulkhead and dash?
Old September 4th, 2015, 10:43 PM
roverx's Avatar
roverx
Scott Preston
That was a Ser IIA bulkhead on a defender chassis. To avoid the issues that arose from using the Ser bulkhead, I'm using a upper Ser tray and welding it onto a defender bulkhead for my current build.
Scott Preston
Old September 7th, 2015, 04:25 PM
MountDisco
Christian Toth
Great info. Thanks guys, looks like space will be a hot commodity under the hood
Christian Toth
Current Inventory:
300tdi, defender, series, tdi
