More hybrid than your prius - Page 2 - Defender Source
Old November 10th, 2014, 01:49 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Ouch! You could also wrap those brackets around the frame to gain a lot of strength.
-Ash
Geared Restoration Co.
352-572-3236
Old November 13th, 2014, 06:00 AM
supercharged67gt's Avatar
supercharged67gt
Andy
64 series IIa x3
fixed everything last night with some help from my brother. I made a new bracket design as I should have from the beginning... patched frame and installed new shock.... we couldn't get springs off the bent shock with a spring compressor or any other way, so we tried to plasma cut the shock shaft- couldn't fit the cutter in-between springs.. next up sawzall which melted the blades instantly... lastly ended up hacksawing hardened shock shafts forever...
Old November 24th, 2014, 09:49 AM
supercharged67gt
Andy
64 series IIa x3
broke more shit last time I went out... I must of fractured the top link tubing from last time and didnt see it before I went to rausch ... so it eventually failed >>> lots of damage.... lower crank pully, steering ram mounts, steering hoses, drive shaft, yoke bearing, brake lines, belts, all tubing on housing destroyed (granted I should of made it thicker walled)
Old November 24th, 2014, 10:00 AM
The solution to an engineering problem is...more engineering!
Old November 24th, 2014, 01:58 PM
aka rover's Avatar
aka rover
ed angel
95 D90
More about this Jump 😄
------ Follow up post added November 24th, 2014 10:01 AM ------
Hey how to you like the Trepadors ? A few of us up here have been thinking about running them on our trail trucks in the 37s.
Cheers
85 D110 3.5 3 DR
Old November 25th, 2014, 09:33 AM
supercharged67gt
Andy
64 series IIa x3
Originally Posted by aka rover View Post
More about this Jump ��
Cheers
the trepadors are by far the best tire I have ever ran, they are unreal on the rocks and do very very well even in mud. another tire to try also is the creepy crawler.
Old December 15th, 2014, 07:44 AM
supercharged67gt
Andy
64 series IIa x3
Steering (round 2)
everything is tacked in.. have some additional support/bracing I am going to add but need to cut some more brackets out
Old December 22nd, 2014, 08:16 AM
supercharged67gt
Andy
64 series IIa x3
got some welding done... still not done tho.. had to do a lot of fab to get gussets to fit so I made my wife do it.... all that's left is the top link mount now.
Old December 22nd, 2014, 01:17 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Nice .. And that's an incredible hammer collection you have .
Staying tuned for round two .
85 D110 3.5 3 DR
Old December 22nd, 2014, 02:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Very nice work as always. Love seeing someone on here pushing the capabilities of a Rover. Actually going beyond the capabilities, breaking stuff then fixing it, haha
So rad your wife is helping cut metal!
Old January 5th, 2015, 07:56 AM
supercharged67gt
Andy
64 series IIa x3
removed rear bulkhead or whatever you want to call it... re-bracing and ties to frame incoming
also got some amazing lights from Lucky8... So I will be redoing my front headlight buckets as well.
Old January 5th, 2015, 08:17 AM
Your girl does some pretty nice work. You should hire her.
Old January 12th, 2015, 08:28 AM
supercharged67gt
Andy
64 series IIa x3
attached middle exo to inner hoop... then attaching that to frame... then adding new seat mounts... and whatever else...
Old February 2nd, 2015, 06:34 AM
supercharged67gt
Andy
64 series IIa x3
finished up my new seat mounts / cage to frame... also added some awesome LED reverse lights from Baja designs....
Old February 2nd, 2015, 12:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow - looks great! I'll need to look back at these pics when I do a front cage and take out the bulkhead for mine.
Old February 23rd, 2015, 10:42 AM
supercharged67gt
Andy
64 series IIa x3
FIXED Seat belt mounts... my bracket wasn't working how I wanted it to so I threw it in the garbage and added a 2nd bar to achieve the correct belt angle...
also fixed my motor mounts... they were starting to collapse the super strong series frame... lol so I added .187 plate in a few places around frame to beef it up then re-welded mounts back on....
Old February 23rd, 2015, 11:23 AM
Originally Posted by supercharged67gt View Post
F starting to collapse the super strong series frame... lol
cool truck but don't blame LR engineers for your failure to triangulate and account for transfer of forces.
You put a v8 engine out on the end of a 2" high and 8 or so inch-long mount arrangement/assembly butt-welded to a 3/32" piece of flat steel and blame the guy who drew up the frame 60 years ago when it stats to move on you??
lol, indeed...kids these days
Old February 23rd, 2015, 11:25 AM
supercharged67gt
Andy
64 series IIa x3
you got me lolol
but in all seriousness the frame actually is quite amazing with what it will put up with
Old February 23rd, 2015, 11:43 AM
looking forward to seeing it in further destructive testing mode.
cheers
you got me lolol
Old March 2nd, 2015, 08:45 AM
supercharged67gt
Andy
64 series IIa x3
finished up front bump stop mounts on frame and also on axle housing. wired up the Baja designs reverse lights, also wired up ARB locker switches and aux power to whatever comes in the future... Gas tank is also re mounted. turned crank pulley on lathe and cleaned up all damage from hyd ram smashing it. front axle has been sent off to powder coaters. next up is rear axle upgrades
Anyone know of a 94-95 NAS ST thats more of a driver than a showpiece? 84ninety Defender Technical Discussions 1 August 25th, 2012 11:02 AM
Need a tow vehicle, room for 6, and more TVs than you can count? down_shift Misc. Chit-Chat 2 November 23rd, 2011 02:13 PM
Wave to the Prius driver! Davis Misc. Chit-Chat 7 May 2nd, 2008 11:08 PM
Exhaust - louder than stock, quieter than Borla? don Defender Technical Discussions 14 April 4th, 2008 01:36 PM
More than one Defender woldd90 Misc. Chit-Chat 28 July 8th, 2006 05:31 PM
