MINI seats in a 90 - Defender Source
Old October 19th, 2015, 03:20 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
MINI seats in a 90
Had some fun fitting MINI seats in a NASD90, without any modifications to the Rover.
ID:	132763   Click image for larger version
Email is
Same place, new dogs.
Old October 19th, 2015, 03:35 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
very cool mod! how is the height to the original seats?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old October 19th, 2015, 04:01 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Did you use the rover seat mounts or the mini mounts in the existing holes? Hard to tell from pics...........Do the bottoms come out?
Todd
'95 D90 #2206
'66 109" P/U
Old October 19th, 2015, 04:21 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
A w e s o m e
Old October 19th, 2015, 05:21 PM
Roverlab
Trevor Griffiths
Thanks!
Very high bolsters on the side, but the front at thigh is about 2" higher.
Fabricated a frame that is secured to the factory bolt holes.
The MINI frame/tracks is bolted to that. The MINI rails are narrower.
The driver's under box cover required a little trim on the left hand side, but is still secured with the clasp. Made a L shaped tab at the rear to locate it the same way as stock. Used the foam that seals floor boards to seal the cover to the seat box. Basically, the cover is 1/8" higher. The seat has a manual height adjuster that when fully up, the jack will pass through and jumper cables could be manipulated safely.
Email is
Old October 28th, 2015, 08:02 AM
LRover's Avatar
LRover
J. Michael McCaig
Nice Job on the install! What year Mini? Did the seats have heaters and air bags? I loved the seats in the Mini I had and I miss the seat heaters.
Old October 28th, 2015, 09:00 AM
Look comfy. Butt warmers to?
Old October 28th, 2015, 09:25 AM
Roverlab
Trevor Griffiths
Air bags and belt tensioners yes, heaters no. Obviously did not wire up the air bags, removed the tensioners and buckle......
Not sure the year of the seats, the customer bought them from LKQ and had them shipped here.
Email is
Old October 28th, 2015, 09:28 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Trevor, what is the advantage here?
Are Mini seats more comfy and/or cheaper?
Follow up question....would it be possible to fit the REAR Mini Countryman seats in place of the 90 bench??
Rent my
Old December 2nd, 2015, 06:28 PM
I need to look into this for my truck.
Old December 2nd, 2015, 06:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
How do you get to the battery box?
I have had to completely remove non-Rover seats to remove or replace the battery.
RDavisinVA
Old December 3rd, 2015, 07:34 AM
Roverlab
Trevor Griffiths
Jeff, The owner rode in his friend's MINI and decided he liked them.
Robert, the seats have a manual lever for adjusting the vertical height. Allows enough room to manipulate jumper cables and the bottle jack through the gap. Maybe not gracefully, but hopefully doesn't need those on a regular basis!
The seats are mounted to a fabricated frame that is in turn mounted to the 4 original mounting holes. Just remove those 4 bolts and the fabbed frame and seat come out as one unit. Passenger's seat the same way.
Originally, we had left the MINI adjustable seat tracks in place, but when Randy came out to take the car home, we all decided the overall seat height for him, at 5'9", was too high. Taking the tracks out lowered the seat 1.250". Should have done that in the first place, but I was hung up on having adjustability.....
Email is
90, seats
modular seats, load area seats, standard seats mgreenspan For Sale - Parts 4 July 6th, 2013 10:31 AM
Recaro Trend Seats, Jump seats, bench seats, Exmoor tbutzow For Sale - Parts 1 June 12th, 2007 04:39 PM
Need mini dash bulb light replacement Doug Young Defender Technical Discussions 8 January 27th, 2005 07:02 PM
Mini! TwisteD90 Misc. Chit-Chat 1 April 2nd, 2004 08:01 PM
Mini to Robot Conversion newfD90 Misc. Chit-Chat 3 March 19th, 2004 05:10 PM
