Mercedes OM617 Powered 110 Build Up - Page 5 - Defender Source
Old September 27th, 2013, 09:06 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I still have to go thru the bag of bolts but I so have everything save for one on the pans. I am excited to get my frame so I can start bolting things on.
Quick question: the new pans have more, less or the same oil capacity? They look great in the pix.
Old September 27th, 2013, 11:36 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
They have more oil capacity... anything worth doing is worth overdoing.
RDavisinVA
Old September 27th, 2013, 12:30 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nice to hear - I like your way of thinking, haha
Old September 28th, 2013, 07:51 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
"SMac" stopped by on his way through the area and drove the Mercedes 110.
He provided lots of positive feedback.
Test drives available at MAR and Uwharrie if all goes well with my leave schedule.
RDavisinVA
Old September 28th, 2013, 09:21 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I could have spent a full day roaming around Robert's place! Rovers and diesels everywhere. Great meeting you Robert and that OM617 is somethin.
Old October 9th, 2013, 03:21 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Nice to see a nice kit out there!! I really like my OM617 in my 109 . Building a 110 next and am on the fence of what power plant to go with. But I'm liking what I see here.
85 D110 3.5 3 DR
Old October 9th, 2013, 07:04 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks... It was a lot of work to design, prototype, and manufacture... worth every minute and penny spent!
Kits are starting to sell and as soon as people have them up and running and others get a chance to see them and drive them, they should be very popular.
Have been so busy have not had much time to play around with the tuning.
We did install a boost bleed off valve to bring the boost up to about 12 - 14 bar on the scale, but it increased the engine temperature when above 75 MPH in the hot summer, so we took it out and the boost stays at 9 bar max and the higher temperatures are no longer an issue.
This is probably a non-issue where you are in Alaska.
Sometime in the future want to install a larger intercooler as we have the small 300TDI intercooler at present. As you can see in the pictures, there is loads of room up front to mount a thicker radiator, larger oil cooler, and larger intercooler.
Also want to use a variable vane style turbo to get more boost at low RPM.
This will improve the off road performance which is not bad, but could always be better.
The thing that is so impressive regarding the OM617 is how smooth it is.
The faster it revs the smoother it gets.
It's the best running small diesel I have ever encountered.
With all the hooey lately regarding imports, the OM617 engine is completely federalized and 100% legit, legal, and so on.
The OM617 engines can be had at pick-n-pull for about $300 and were imported by the hundreds of thousands in North America.
Since they rarely go bad, the OM617 is relatively easy to find in good used condition at bargain prices.
RDavisinVA
Old October 9th, 2013, 09:32 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Ed:
Forgot to ask, did you do any fine IP tuning?
RDavisinVA
Old October 9th, 2013, 01:09 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Ed:
Richard
I did remove the alda and and turned the fuel up just a bit using OM606s procedure from the STD forum. I timed the pump using the drip procedure and am running 14 psi of boost . I ran 15 k miles on my last trip with the boost at 10 psi as I have no intercooler. And still walked away from a D110 from this board running a TDI on the hills.
85 D110 3.5 3 DR
Old October 11th, 2013, 10:19 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Typos - put in bar instead of PSI
Should have read:
We did install a boost bleed off valve to bring the boost up to about 12 - 14 PSI on the scale, but it increased the engine temperature when above 75 MPH in the hot summer, so we took it out and the boost stays at 9 PSI max and the higher temperatures are no longer an issue...
RDavisinVA
Old December 15th, 2013, 09:20 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Pan shipped last week.
Kits are sold out with the second batch available in Jan/Feb 2014.
We have not tuned our engine much, but here is an interesting thread:
http://www.superturbodiesel.com/std/...m-MW-to-M-pump
RDavisinVA
Old December 16th, 2013, 05:41 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by jrose609 View Post
Weren't you at one time thinking about developing a hydraulic-style mount for the 200 and 300 tdi's?
Yes making custom mounts for the 200 and 300TDI are on the list, but am too backed up with work to get to them.
RDavisinVA
Old December 16th, 2013, 10:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Would this be the Mercedes hydraulic mounts fitted to a 200/300tdi?
What are the part #'s for those mounts?
Rent my
Old December 16th, 2013, 01:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If I were to make a custom motor mount for the Land Rover TDI, it would be using Mercedes mount: 2012403917.
RDavisinVA
Old January 29th, 2014, 11:28 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Currently discussing buying an M-Series IP for the OM617 that will yield some decent low end torque and 160 - 165 HP.
RDavisinVA
Old January 29th, 2014, 12:50 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Robert,
I just found out what this year's tax refund is going to be....
What does your current stock of kits look like. Any manufacturing runs planned this year? -Dave
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 29th, 2014, 01:57 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by ontheway View Post
Robert,
We have 1 defender kit in stock that I was saving to replace the 200TDI in our 1983 110, but it is available now because by the time I clear all the other projects out of the way, the second production run will be completed.
Was also saving it to have parts in case someone installing a kit made a major mistake and broke something.
In other words, we have one left if you need it.
Can't wait to install that new IP and have 40 more HP and lots more torque.
Won't know the numbers exactly, but am hoping for 220 lbft of torque with 160 HP.
The stock IPs are tuned to prevent the engine from putting out any smoke.
Was behind a 300D sedan last week on the interstate and you could net tell it was a diesel.
It smoked a lot less than the 200TDI.
With the new settings it will definitely put out more smoke, but not an unacceptable amount.
RDavisinVA
Old January 29th, 2014, 02:36 PM
ontheway's Avatar
ontheway
Dave
Ok thanks for the info - I will be back in the states later in February and will be in touch regardless. I've got your e-mail from previous conversations.
Are you going to be at Uwharrie Safari in April?
Old January 29th, 2014, 03:26 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Can't wait to install that new IP and have 40 more HP and lots more torque. Won't know the numbers exactly, but am hoping for 220 lbft of torque with 160 HP. The stock IPs are tuned to prevent the engine from putting out any smoke. Was behind a 300D sedan last week on the interstate and you could net tell it was a diesel. It smoked a lot less than the 200TDI. With the new settings it will definitely put out more smoke, but not an unacceptable amount.
I will definitely be interested in seeing how the new IP does. 40HP is not bad at all. What is the cost on the IP?
Old January 29th, 2014, 04:02 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
Hello Richard
I have a custom, precision, computer-aided, metal fabrication company that could help you with the mounts, or anything else, if that's of any benefit to you.
Regards
Jack
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 02:02 PM
110 Rock Sliders tobit3 For Sale - Parts 4 March 24th, 2005 05:17 PM
Looking for 110 CSW tub. C-Delta Wanted 2 December 7th, 2004 07:43 AM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
