Mercedes OM617 Powered 110 Build Up - Page 2 - Defender Source
Old December 29th, 2012, 07:39 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by Trey C View Post
Robert who imports your trucks for you ?
The "Man" if there ever was one... My friend and long time associate in the marque, someone close to both of us!
FWIW dad and I drove this about 35 miles and had it up to 75 but also ran it on winding mountain roads and it does very well. Definitely smoother than the tdi's. Robert has a year of his life and a ton of money invested in machine work and perfecting prototypes. Lost track of how many times he's had that engine in and out again getting it just right.
Yes I had forgotten that I loaned it to you and Doug when he busted something, for a Walmart trip to get valuable supplies like fermented beverages, food, birthday gifts for your niece... How about a chicken schnackkk, chicken schnackkk, chicken schnackkk? Can't wait until the next event.
Good times!
RDavisinVA
Old February 9th, 2013, 07:41 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Kits finally coming out soon...
RDavisinVA
Old February 9th, 2013, 08:00 AM
Robert did you ever swap in a different tcase ? That 1.6 is costing you mpg. I think most people will be installing in trucks already equiped with 1.2's and would probably like to know your experience with that ratio.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old February 9th, 2013, 08:18 AM
Sprinter vans had a 31mph per thou top gear ratio. Think you can do better than that given lower frontal area and weight. The lightest Sprinter was 4800lbs unladen and the heaviest were closer to six thousand.
Old February 9th, 2013, 09:42 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Higher Ratio T-Case
As a matter of fact am swapping the 1.6 LT230 out on the Red Swiss X-Fire Brigade 110 5 door this weekend.
Then am pulling the OM617 engine out of the 110 pickup to replicate the remaining kit parts. Before it goes back in, it will get a 1.2 or a 1.4 LT230.
Oil pans are already at the machine shop. Have 3 vehicles lined up for conversions and a number of kits to ship out next month.
RDavisinVA
Old February 10th, 2013, 06:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Interested in seeing more of these. Probably won't do it for the NAS 90 but if I ever built a 110 or 100 it seems like it would be a nice power plant option.
Old February 15th, 2013, 09:25 AM
Think it would be great in a 90. Shame Zo have a v8 already installed
What's the fuel pump need for this engine?
Old February 26th, 2013, 07:02 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1.22 with the OM617
Over the weekend got the LT77 bolted behind the OM617 with new shift fork, release bearing, and slave cylinder in the white pickup.
Now a 1.22 LT230 will go behind it.
Will report back on driveability.
Meanwhile have been driving the Swiss 110 SW with 200TDI and 1.22 LT230 and it is really nice in this area of VA which is mostly flat. You're right regarding better fuel mileage if you match the engine revs to the gears and don't shift too early going up the gears and downshift when coming down so you're not over geared.
RDavisinVA
Old March 10th, 2013, 02:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1.22 is in.
Doug, you're right.
The 1.22 LT230 makes a big difference when compared to the stock 1.6 that came with the 110 when it had the original 2.5 Petrol.
The Pickup is very driveable now.
The Mercedes OM617 3.0 Liter 5 cylinder Turbo Diesel does very well with the higher gearing. Just ordered an early Range Rover spedo drive gear and shaft that will take the earlier cable.
RDavisinVA
Old March 10th, 2013, 04:06 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Very interesting.
Which OM617 version are you using? The later ones had quite a bit more horsepower than the early ones.
"These are the best traveled nuts on d-90 . . ." ABrooks
Old March 10th, 2013, 05:42 PM
cool. Now you have two hot rod 110's.
Old March 28th, 2013, 06:42 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
all of this has my curiosity piqued... are you selling kits? If so, where?
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 28th, 2013, 06:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
PMs are welcome!
PMs are welcome!
RDavisinVA
Old March 30th, 2013, 11:26 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
90 or 110 kits due out the end of April
Finally have the oil pans being worked on after sitting at a shop for almost 4 months.
RDavisinVA
Old March 31st, 2013, 02:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Bump
RDavisinVA
Old July 4th, 2013, 09:44 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Motor Mounts are in shipping conversion kits this weekend!
After waiting months, have the motor mounts for both the series and for the 90 & 110...
These bolt right to the existing frame mounts in the Series II, IIA, III. Also in a 90 or 110 that originally had a 2.25, 2.5, 2.5 TD.
ID:	75375   Click image for larger version
RDavisinVA
Old July 4th, 2013, 11:07 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wait as second. If I buy a galvy 110 frame and had 2.5NAD mounts on it would these then work to bolt the 617 to?
Old July 4th, 2013, 12:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Correct.
Yes these would bolt the engine to your existing frame mounts.
You would need the rest of the kit of which these mounts are components.
RDavisinVA
Old July 4th, 2013, 12:20 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Optimal gearing is 1.4
Doug, you're right.
The 1.22 LT230 makes a big difference when compared to the stock 1.6.
The 1.2 is a little tall, so switched to 1.4 which is the best gearing with 235 85 16 tires.
RDavisinVA
Old July 4th, 2013, 12:33 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Weren't you at one time thinking about developing a hydraulic-style mount for the 200 and 300 tdi's?
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 01:02 PM
110 Rock Sliders tobit3 For Sale - Parts 4 March 24th, 2005 04:17 PM
Looking for 110 CSW tub. C-Delta Wanted 2 December 7th, 2004 06:43 AM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 12:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 09:32 AM
