Mercedes OM617 Powered 110 Build Up - Page 13 - Defender Source
Old July 7th, 2015, 10:59 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by ontheway View Post
We pretty much have the same stuff left... But you are one step ahead of me because you have a downpipe. I'm going to try and find someone to do at least the first bend and a flex pipe this weekend!
I just used the stock Merc one - any chance you can source one of them? I did have to mod the bottom of the DP and increased the OD to 2.5"
I may go back at some time and do a true 2.5" DP tho.
Old July 8th, 2015, 06:13 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I'm dead set on doing an immediate expansion to 3" right after the flange. I figure I'll appreciate the extra flow as I start to tune her!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old July 8th, 2015, 08:51 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Dave:
I buy mandrel bent pipe from an exhaust supply and then weld up my own exhaust systems.
Be sure and add a flex joint so it doesn't rattle.
The Mercedes muffler is ideal.
RDavisinVA
Old July 8th, 2015, 10:10 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haha - I like that idea. Well - if I end up doing the DP over I might have to do the same!
If you can post up what you are doing about the air intake - trying to figure out a clean setup. Was going to go the stock Merc air filter canister but things are tight with the heater box and windshield washer canister.
Old July 11th, 2015, 08:48 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Any of you guys have pics of your throttle setup?
I bought an NAS 90/110 throttle cable and was going to run it straight to the main IP lever but found it won't be able to use the kill/STOP feature. I still have the valve cover Merc linkage but was seeing if there were some simple options.
Old July 11th, 2015, 08:55 AM
ontheway's Avatar
ontheway
Dave
Originally Posted by don View Post
Haha - I like that idea. Well - if I end up doing the DP over I might have to do the same! If you can post up what you are doing about the air intake - trying to figure out a clean setup. Was going to go the stock Merc air filter canister but things are tight with the heater box and windshield washer canister.
Parts for intake are on the way. Will post photos of the mockup if it works and will let you know what parts I used.
Haven't delved into the accelerator cable yet. Just been too busy.
Old July 11th, 2015, 09:53 AM
scrubs
henery
1974
Pics in route, share if u like
Old July 11th, 2015, 05:21 PM
ontheway's Avatar
ontheway
Dave
please share don!
Old July 11th, 2015, 05:47 PM
scrubs
henery
1974
Downpipe pic sent, share if you like
Old July 11th, 2015, 06:57 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Robert, your 75mph speeds--is that with the boot on the throttle? Curious what you get at a comfortable throttle input.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old July 11th, 2015, 08:30 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Here are Pictures Scrubs sent...
ID:	124826   Click image for larger version
ID:	124828   Click image for larger version
RDavisinVA
Old July 11th, 2015, 08:33 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
That's with stock IP and your foot in it, but not all the way down to the floor.
RDavisinVA
Old July 12th, 2015, 10:57 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks for uploading the pics Robert - was a busy day yesterday.
Here is a pic of mine after some fiddling last night:
I can get the STOP to engage but it seems the throttle side doesn't have much. I took the bolt out of the accelerator pedal so it has full travel.
Might just have to start it and see how it revs/feels.
Old July 12th, 2015, 11:52 AM
scrubs
henery
1974
Don, took a bit to figure the full travel on the IJ pump, when figured out ran just fine.
Pretty sure we talked via email last year about it ;-)
Old July 12th, 2015, 05:56 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Don, took a bit to figure the full travel on the IJ pump, when figured out ran just fine. Pretty sure we talked via email last year about it ;-)
I remember now - will look up those emails. I'll have to fiddle with it once I am done with the rest of the build.
Old July 12th, 2015, 08:40 PM
ontheway's Avatar
ontheway
Dave
Looks good. The issue with mine is the return spring on the IP Is useless. Going to either replace it and see if it helps, or more likely going to have to rig up a return spring up on the valve cover. Does your accelerator/throttle spring back to the stop position?
In other news, went back out today to fire up the engine just for kicks and it was the fastest and smoothest starting diesel I've ever been around. Can't wait to get this thing rolling.
Old July 14th, 2015, 04:48 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Dave - my throttle goes back. Gave her a test fire last night and the throttle felt pretty good. It will need to be fine tuned but for now I will it as is so I can finish all the other little items.
Old July 15th, 2015, 10:30 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Attachment 124855
That stop is a manual shutoff that isn't needed when you connect up the vacuum shut-off button.
------ Follow up post added July 15th, 2015 11:32 AM ------
When revved off idle, the engine sounds like a V8 gasser...
RDavisinVA
Old September 13th, 2015, 11:51 AM
ontheway's Avatar
ontheway
Dave
My conversion is practically complete...
So naturally on a recent test-start I noticed exhaust coming from the heater output (no coolant added yet).
Everything I know tells me this is a head/head gasket issue. Awesome.
Truck idles, revs fine. But has never been run under load or more than 60 seconds.
So now it's a matter of deciding if I finish the install and attempt to drive... Or go backwards 6-12 months and start with a different engine.
Old September 14th, 2015, 02:49 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
My conversion is practically complete... So naturally on a recent test-start I noticed exhaust coming from the heater output (no coolant added yet). Everything I know tells me this is a head/head gasket issue. Awesome. Truck idles, revs fine. But has never been run under load or more than 60 seconds. So now it's a matter of deciding if I finish the install and attempt to drive... Or go backwards 6-12 months and start with a different engine.
Sorry to hear. Sure it's not a loose downpipe and exhaust just coming thru?
If it's the head/head gasket it shouldn't be too crazy of a job. Do you know the mileage on the motor?
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 01:02 PM
110 Rock Sliders tobit3 For Sale - Parts 4 March 24th, 2005 04:17 PM
Looking for 110 CSW tub. C-Delta Wanted 2 December 7th, 2004 06:43 AM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 12:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 09:32 AM
