Maiden Voyage into Landrovia... - Page 5 - Defender Source
Old July 9th, 2014, 10:22 PM
cbfritz_03
Carmen
none
Today I started breaking down all the body panels. I removed all the old gaskets, bolts and anything steel. There are some cracks and patch welds that need to be done on some.
The shifter has been broken and repaired at some point. Since I have the glass out - I'm going to go on and see about replacing it with tempered or laminated.
Contacted the galvanizing facility in San Antonio again and was able to speak with someone this time. He said they could do all the galvanizing for her and the turn around is one week.
Mon-Mon or Tues-Tues.
Pricing is .43/lb if bare metal, no cleaning or prep and I do all the wiring up of the smalls - spacing is at a minimum of 4in per piece. Is .64/lb if they have to blast it and wire it up. There is a $110 minimum charge and the weight is taken after the pieces have been galvanized. He asked that I send him a picture to give him an idea of scale - so I pulled a few. I need to know what dimensions equate to 'smalls' so I can wire correctly.
I didn't get a picture of the tub - but I started pulling it apart. It's an adventure! If you haven't taken apart a tub...you are missing out! Good gravy...I was a different shade of brown when I decided to call it a day.
I just keep envisioning what she will look like when she's done ""
ID:	98524   Click image for larger version
ID:	98526   Click image for larger version
ID:	98528   Click image for larger version
ID:	98530   Click image for larger version
Old July 10th, 2014, 10:08 PM
Nicely done, and nice shop footwear. You have me looking like a right slacker.
That galvy pricing sounds pretty good, even with blasting.
Originally Posted by pendy
I'm here for the D's
Old July 13th, 2014, 12:07 AM
cbfritz_03
Carmen
none
Thank you Charles, on the progress and my choice in footwear. I like to be comfortable. In one of those pictures I'm sitting in the wing grinding off bolts - had a hot one land in between my toes
Tomorrow I'll be at it again.
Also, I am taking two other members bits for galvy with mine - I'm planning to go in two weeks.
If you have something you want done - Get it to me soon please.
Old July 13th, 2014, 08:18 PM
Thanks for the offer, but I have half a truck worth of bits to galvy (already did one run). Hopefully the second run will be soon.
Old July 14th, 2014, 07:35 PM
cbfritz_03
Carmen
none
You're welcome Charles. I can't wait to have my first stack of rover chrome.
Old August 13th, 2014, 12:28 AM
cbfritz_03
Carmen
none
Sooo this week I actually have a few days off, and today I built a 10x10 electrolysis tank. I am surprised at how quick this process is. I have a bunch of stuff 'cooking' and can't wait to see what it all looks like in the morning!! ...
Old August 13th, 2014, 10:03 AM
cbfritz_03
Carmen
none
Humm...looks interesting!...
ID:	100747   Click image for larger version
Old August 14th, 2014, 01:33 AM
Ignotus
gene
1960 109, w/200TDI
So what's it doing? How many volts?
Gene
1960 109
1960 88 Ignotus
Blog;
Old August 14th, 2014, 10:40 AM
cbfritz_03
Carmen
none
Hello Gene! It ate everything off to bare metal and 12v. Pretty neat.
Old August 14th, 2014, 10:47 AM
that's pretty impressive.
I've always thought that someone needs to build a drive-in tank made of concrete with ramps for a Defender to drive into. The pit would be about 6' wide and 5' deep and filled with enough phosphoric acid to submerge an entire truck up to the footwells.
Drive the truck in, pump in the acid, let sit for 3 days, pump out the acid through several filters, and drive out the truck for a complete power wash.
Old August 14th, 2014, 10:48 AM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Very cool, always wanted to try this. Sanding becomes a pita quickly. Do you have any after shots?
Old August 14th, 2014, 11:36 AM
cbfritz_03
Carmen
none
Lol ...we are on the same page
------ Follow up post added August 14th, 2014 10:39 AM ------
Yes ...it does. This restore has been many 'first times' for me and I am embracing it, so when I saw the electrolysis demos I had to try it. Here are the two main videos I went off of and just did it bigger.
Old August 14th, 2014, 11:54 AM
cbfritz_03
Carmen
none
Humm...it's not allowing me to attach links today? I'll post pictures and try again later.
Old August 14th, 2014, 05:20 PM
Great idea to make a large tank. Looking forward to seeing the results - when I did it in a bucket it worked so-so
Old August 14th, 2014, 05:50 PM
cbfritz_03
Carmen
none
The most stubborn has been the breakfast, where there are multiple layers of paint. The issue I ran into was that my set up was wrong. I was allowing the the steel wire that strung together my anodes to touch the water, so it was disintegrating and the process would stop. Had originally ran my rebar horizontally now they are vertical and wire is running along the top and out of the water.
Old September 18th, 2014, 12:37 AM
Ignotus
gene
1960 109, w/200TDI
Ok Carmen, We've been patient, but it's been a month...........
Still moving forward?
Gene
1960 109
1960 88 Ignotus
Blog;
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
Getting into gear, but not *moving*! chris72982 Defender Technical Discussions 3 February 9th, 2004 12:38 PM
Hard to get into reverse Troys Defender Technical Discussions 4 January 11th, 2004 01:32 PM
How to make my jpeg into a thumbnail? Chris Cox Support & Suggestions 6 October 2nd, 2003 07:18 PM
» Recent Discussions
» Defender Registry
2016 Land Rover Defender 110
Sanbornc
The Landy
Mike Botha
Add your Defender
