LR 110: Two years and thousands of hours - Page 2 - Defender Source
Old February 5th, 2016, 10:05 AM
Azarur
AZ
LR 1984 110
Here's the engine running. Not sure if you guys will be able to tell from the sound, but that's one smooth running 200 Tdi. BTW, I know that it looks like a 300. It's not, we just adapted the 300 cover to reduce noise.
Old February 5th, 2016, 10:10 AM
Azarur
AZ
LR 1984 110
Air Con
After the mounts were sorted out, it came time to look into the air conditioning system. Very quickly we passed on the original factory system. Why? Again, because I'm insane! So, we went instead with a Gen IV Vintage Air system. If you haven't looked into it, then you should. It's more compact and significantly more efficient than the LR systems. Furthermore, the controls are all servos, meaning you have a variety of options for dash-mounted or even lever-mounted switches.
Old February 5th, 2016, 10:12 AM
Azarur
AZ
LR 1984 110
Perhaps the most gratifying aspect of this project was how involved my kids were. Here's Alex fabricating the compressor mount for the Vintage Air System and the final product:
ID:	141583   Click image for larger version
Old February 6th, 2016, 12:17 PM
vrivas
Victor Rivas
1994 D90
Your truck looks awesome, just sent you a PM.
Old February 6th, 2016, 08:01 PM
Azarur
AZ
LR 1984 110
Finally, we replaced the turbo and put in a high-capacity intercooler. Decided to use orange piping for exhaust gases (why not!!!). Also added a k-type thermocouple to the exhaust port to be able to measure EGT. Other than that, and as I mentioned earlier, adding the 300TDi style cover to reduce knocking sound, no further modifications were made to the engine. Here are photos of the proces and the final engine bay.
ID:	141716   Click image for larger version
Old February 6th, 2016, 08:11 PM
Azarur
AZ
LR 1984 110
Body Work
By far, the toughest part of the project was the body work. The vast majority of parts needed significant repair, and about a third of them had to be replaced, including all four cabin doors. We made an early decision to absolutely not cut corners, but at the same time wanted to keep as many of the original body panels. Yet another bad decision, because in order to give repaired parts the structural integrity that would be comparable to new parts, it took an insane amount of shop time.
But enough talk. Here are the process storyboards by major body area, starting with the favorite of all defender fans: The Bulkhead!!!
And this is how bad it was when we first removed the just stupidly bad web of wires:
Old February 6th, 2016, 08:13 PM
Azarur
AZ
LR 1984 110
More "before" pictures...
ID:	141719   Click image for larger version
Old February 6th, 2016, 08:32 PM
Azarur
AZ
LR 1984 110
Doesn't look to bad right?
Ok. Let's take a closer look:
Name:	2014-08-21 15.01.59.jpg
ID:	141721   Click image for larger version
Name:	2014-08-21 16.26.01.jpg
Name:	2014-07-22 18.09.32.jpg
ID:	141723   Click image for larger version
Name:	2014-07-30 17.39.08.jpg
Old February 6th, 2016, 08:35 PM
Azarur
AZ
LR 1984 110
OK. So, it's bad...
Should we replace it? Of course not! That would be too easy!!!
Let's just rebuild the damned thing! I mean how bad could it really be?
Alright, first the footwells need to be completely redone, because they are rotten to the core, so, here we go!
Name:	2014-08-14 16.32.01.jpg
ID:	141725   Click image for larger version
Name:	2014-08-15 11.37.53.jpg
Name:	2014-08-15 11.38.02.jpg
ID:	141727   Click image for larger version
ID:	141729   Click image for larger version
Name:	2014-08-20 16.29.33.jpg
Old February 6th, 2016, 08:38 PM
Azarur
AZ
LR 1984 110
The mid part is ok, so let's not worry too much about that.
But the top... ay ay ay.
Ok, so here we go:
Name:	2014-07-30 17.39.35.jpg
ID:	141731   Click image for larger version
Name:	2014-07-30 18.15.10.jpg
Name:	2014-07-30 18.15.24.jpg
ID:	141733   Click image for larger version
Name:	2014-08-22 14.06.54.jpg
Name:	2014-08-22 14.07.07.jpg
ID:	141735   Click image for larger version
Name:	2014-08-25 12.15.53.jpg
Old February 6th, 2016, 08:42 PM
Azarur
AZ
LR 1984 110
OK. Bulkhead is patched up, heat-stress-relieved, measured and aligned. So now let's sand, prime and get ready to paint!!
ID:	141738   Click image for larger version
Name:	2014-12-16 17.33.53.jpg
ID:	141740   Click image for larger version
Name:	2014-12-17 19.41.25.jpg
Name:	2014-12-18 17.23.34.jpg
ID:	141742   Click image for larger version
Name:	2015-01-19 12.32.53.jpg
Name:	2015-01-22 16.51.55.jpg
ID:	141744   Click image for larger version
Name:	2015-01-22 16.52.04.jpg
ID:	141746   Click image for larger version
Name:	zarur tub 033.jpg
Old February 6th, 2016, 08:55 PM
Azarur
AZ
LR 1984 110
Ok. So now the time has come to pick a color!!
First round of votes:
Me: Racing Green
Alex: Black
Antonio: Blue
Andrew: White
Wife: "Just finish the stupid thing already and leave me alone"
So, no winner. We eliminate the Green (because "who cares what dad thinks!!?") and the white because Andrew got bored and left. So run off vote:
Me: Blue
Alex: Grey ("I am allowed to change my mind between votes!!)
Antonio: Blue
Andrew: Grey (Me" I thought you left!", Andrew: "Alex gave me a bag of chips if I vote with him")
Wife: "If you idiots ask me again, someone is going to get hurt!"
Ok. So we have a tie, and no tie breaker. So let's do it again.
Me: Grey
Antonio: Blue and "Alex, if you say blue I'll let you play Xbox even though I had called it before"
Alex: Blue
Me: What??? You can't change votes again!
Alex: "Why not??"
Wife: "Good grief"
Andrew: "I'm hungry, can we leave already. I want to eat at Koto"
Alex: "Yeah, me too! I'll have the steak"
Antonio: "Oooh. Yes. I want the spicy tuna and shrimp tepanyaki"
Wife: "Let's go!"
Me: WTF???? I guess we'll paint it blue
Name:	2014-11-05 15.52.15.jpg
ID:	141748   Click image for larger version
Name:	2014-11-05 15.53.54.jpg
Name:	2014-11-05 15.54.34.jpg
ID:	141750   Click image for larger version
Name:	2014-11-05 15.55.15.jpg
Old February 6th, 2016, 08:57 PM
Azarur
AZ
LR 1984 110
OK. So with the color picking fiasco behind us, time to paint the bulkhead!!
Name:	2015-01-22 18.17.32.jpg
ID:	141752   Click image for larger version
Old February 6th, 2016, 09:09 PM
Azarur
AZ
LR 1984 110
BTW, in case anyone cares, the blue is the authentic land rover "Loire Blue Metallic."
I figured, we are being so liberal with how we are changing the car, the least we can do is pick a land rover authentic color!!
Old February 6th, 2016, 09:36 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Which particular model system did you use of the Gen IV? Does that system replace the old heater core and blower assy? Does it contain both the heater and condenser coil and thus blow cold air through the bulkhead and then through the existing (and if desired) additional vents in the dash or do you still have to mount a blower unit in the cabin?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 7th, 2016, 12:11 AM
Azarur
AZ
LR 1984 110
I'll post the exact model on Monday. No need for the old core and/or blower. It all gets replaced by the Gen IV: it contains heater, condenser and blower. You can use existing duct work or (like we did) replace with 2" tubing and new vents.
Old February 7th, 2016, 06:27 AM
this is an amazing thread
thank you for sharing
Old February 7th, 2016, 06:40 AM
vrivas
Victor Rivas
1994 D90
Owning a 110 gets more exciting everyday! Unbelievable work and amazing attention to detail, looking forward to seeing it complete.
Old February 7th, 2016, 07:19 AM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Ok. So now the time has come to pick a color!! First round of votes: Me: Racing Green Alex: Black Antonio: Blue Andrew: White Wife: "Just finish the stupid thing already and leave me alone" So, no winner. We eliminate the Green (because "who cares what dad thinks!!?") and the white because Andrew got bored and left. So run off vote: Me: Blue Alex: Grey ("I am allowed to change my mind between votes!!) Antonio: Blue Andrew: Grey (Me" I thought you left!", Andrew: "Alex gave me a bag of chips if I vote with him") Wife: "If you idiots ask me again, someone is going to get hurt!" Ok. So we have a tie, and no tie breaker. So let's do it again. Me: Grey Antonio: Blue and "Alex, if you say blue I'll let you play Xbox even though I had called it before" Alex: Blue Me: What??? You can't change votes again! Alex: "Why not??" Wife: "Good grief" Andrew: "I'm hungry, can we leave already. I want to eat at Koto" Alex: "Yeah, me too! I'll have the steak" Antonio: "Oooh. Yes. I want the spicy tuna and shrimp tepanyaki" Wife: "Let's go!" Me: WTF???? I guess we'll paint it blue
Well done! I really enjoy your "story" thread. My favorite part is the involvement of your family in the process. Unless you took notes on what you would eventually post, it sure seems like your memories of the process are tied to the time with your kids. This is the most enjoyable build thread I have read. Please continue the story as you have time.
Old February 7th, 2016, 10:24 AM
Azarur
AZ
LR 1984 110
The Tub
After we got the bulkhead done, I assumed the worst was over.
Oh boy. Was I mistaken.
As I've said before, the frame was super solid, so I (wrongly) assumed the floors in general would be in ok shape. Of course corrosion is a bitch, and the fact that one specific part made of a specific metal is solid, that does not mean that another metal subject to the exact same set of conditions will be the same. In fact, anyone who has taken a class in electrochemistry knows that a metal with a certain electronegativity in contact with another metal with a different electronegativity in contact with a corroding fluid (i.e. water) will rapidly decay.
And we had ample proof of this! Every inch of the underside of the driver, passenger, middle row and tub floor was rotten to hell. So we basically had to replace everything. It was an interesting discussion. How do we make sure we have the absolute best material in terms of strength and corrosion resistance (for example stainless steel sheet) and at the same time prevent future corrosion when it will be in contact with the aluminum body panels? By the way, did you know the original choice by land rover to go with aluminum was a result of steel shortages in the UK in the 1940s and not the savings in weight usually quoted by people? Should we forgo stainless and go with thicker aluminum sheet needing more weight and giving up on rigidity? Should we use stainless and insulate the joints with epoxy? Given that the floor supports are steel we decided to stay steel throughout and epoxy the joints prior to riveting. Overkill? For sure! But hey, I'm not spending two years building this guy just to end up with a corroded floor in a year!!
Here's the before photos.
ID:	141756   Click image for larger version
Name:	zarur defender bed 001.jpg
ID:	141758   Click image for larger version
Name:	zarur tub 028.jpg
Name:	zarur tub 029.jpg
ID:	141760   Click image for larger version
Name:	zarur tub 020.jpg
Name:	zarur tub 024.jpg
Calvin decoder just saved me thousands asif k. Defender Technical Discussions 7 July 14th, 2015 09:31 AM
2006 HONDA Rubicon TRX500 with Plow and low miles/hours Rugbier The Flea Market 2 June 22nd, 2014 11:09 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 07:10 AM
Well, I just wasted 2 hours trying to cheer myself up Hans Misc. Chit-Chat 10 November 21st, 2004 08:38 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 03:47 PM
