Iveco TD in a 110 one step at a time... - Page 2 - Defender Source
Old May 17th, 2015, 05:27 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks good Robert - are any oil pan modifications needed?
Old July 1st, 2015, 07:20 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No oil pan modifications are required.
RDavisinVA
Old July 1st, 2015, 09:05 AM
ezzzzzzz
Mark Garrenton
Looks great, Robert.
Old July 1st, 2015, 09:22 AM
Way of Life's Avatar
Way of Life
1988 Defender D110
Nice swap, I think the Canadian Military uses that engine in their Iveco trucks.
I live close to the base and see a lot sitting around must be waiting for to be sold off.
I have a pal waiting for that he is going to build a Overland truck out of one.
Old July 8th, 2015, 09:57 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Finally got my second starter from Mean Green.
The machine shop had to fix the offset, but it now works just fine.
So we started the engine.
It will be nice to see how well it pulls the 110 around.
If it can haul a Land Rover Santana, it should work fine in a 110.
From this link you can see the same engine:
http://www.4wdonline.com/Misc/Santana.html
When in England there were business that ran fleets of Iveco trucks and swore by them.
The larger trucks have a 6 cylinder engine, but the smaller van type have the same engine as the Land Rover Santana PS-10.
I think it's a good choice for an Overlander platform, Randy.
RDavisinVA
Old July 8th, 2015, 10:50 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Whoa - Mean Green gave you a call back?
Good to hear about the Iveco - love hearing the different power-plants you've been using. Can't wait to hear how it does on it test run.
Old July 8th, 2015, 11:11 AM
Way of Life
1988 Defender D110
getting closer to the big day like a kid with a new BIG wheel.
I'm not sure what I'm doing maybe a 3.9 Cummins or Ford 5.0. 412 HP would be nice.
Keep the posts coming.
Old July 9th, 2015, 09:10 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yep after a few years they called me out of the blue and sent the second starter.
It was a shock!
RDavisinVA
Old July 9th, 2015, 09:16 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Coolant hoses finally done complete with zip tie mounted radiator that will be changed in the future.
It took a little layout time to get the routing correct and out of the way.
This was as close to a factory look we could get.
Since this is a prototype first run, just looped the heater hoses for now and will test with tap water.
Machine shop is making a clevis with a hole, so we can mount the accelerator cable that we bought yesterday at a bicycle shop.
Will post more when it is driving later this week or even as soon as today if the machine shop gets to the clevis.
ID:	124614   Click image for larger version
RDavisinVA
Old July 10th, 2015, 02:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Went for a drive today.
Was very fast... pulled nicely.
RDavisinVA
Old July 10th, 2015, 03:39 PM
I hope those aren't used zip ties. I see you switched over to using new hose clamps. Lookin good!
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 11th, 2015, 09:35 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We used the stock radiator mounts before the test drive and removed the zip ties.
Nice private joke regarding the hose clamps.
ID:	124765   Click image for larger version
RDavisinVA
Old July 11th, 2015, 09:45 AM
Robert don't sell anymore rusty rovers out of the back yard to your proctologist.
That last sale damn near killed you when he got you on the table....
Damn that should be a signature line.
------ Follow up post added July 11th, 2015 09:52 AM ------
Originally Posted by Iamkraig View Post
We need more washers.
" I am in the presence of greatness, we call that the Robert Davis effect in Canada"
Said with conviction while dropping to one knee.
Name that event
Old July 11th, 2015, 10:08 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Your hypothesis is flawed in that everyone knows Land Rovers don't rust... don't rust while parked in the garage is more like it.
Name that event
That would be Uwharrie...
------ Follow up post added July 11th, 2015 10:15 AM ------
Today will start on the exhaust as soon as the lift is open.
Picked up the exhaust flange from the machine shop yesterday.
The challenge will be to weld the down pipe onto the flange without warping it...
It needs to seal flat or the exhaust will leak.
Looks like opposite side "fish scale" welding is in order.
ID:	124767   Click image for larger version
RDavisinVA
Old July 11th, 2015, 10:26 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Name that event
I'll never forget that day...
Rent my
Old July 15th, 2015, 11:34 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Found some downloads off the Iveco Daily Forum and this 2.8 TDI style engine is around 120 HP with over 200 FT LBs of torque.
RDavisinVA
Old July 15th, 2015, 11:45 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Nor will I.
Old August 8th, 2015, 01:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Hope to get back to the Iveco project this weekend.
RDavisinVA
Old August 20th, 2015, 10:39 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Update:
New short belhousing R380 Stumpy and new 1.4 T-case (both from Ashcroft) were installed over the weekend.
Drove it down the local bypass at 75 MPH with plenty of petal left.
More clunky sounding than the OM617 and 4JB1-T, about on par with a 200TDI or a little louder, but no real vibrations.
Without tuning or intercooler, seems about the same as a Land Rover TDI, although known for bullet proof reliability in the PS-10 and Daily trucks.
It will be interesting to drive it in the future intercooled with the fuel turned up and a manual boost controller when ever I have some time to spend on it.
RDavisinVA
Old August 20th, 2015, 11:32 AM
I convinced Clay to use all new hose clamps on his 200tdi swap. But he really wanted to stick with the old ones. So, I think we'll use an old one on the power steering hose. Maybe two.
Present:
1987 RRC- "Chewy 2"
Past:
Iveco Uncle Douglas Misc. Chit-Chat 4 November 24th, 2010 07:42 AM
LR->Santana->Iveco Monkeyboy Misc. Chit-Chat 1 November 18th, 2007 06:54 PM
