How do I fix this? - Defender Source
Old March 4th, 2015, 11:02 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
How do I fix this?
This is a picture of my drivers side door sill. Passenger side is the same. Is this fixable or do I need to buy new?
Old March 4th, 2015, 11:35 AM
What many do is cut that rusty tube off that is holding the lower door seal and switch to the new style which attaches to the bottom of the door instead.
Old March 5th, 2015, 08:17 AM
jason1st
Jason Crandall
OK. Thank you sir.
Old March 5th, 2015, 10:15 AM
Essentially as Doug said. I *believe* that "tube" is just spot-welded on, so in theory you can find and drill out the spot welds to make removal of the tube a little easier. Then maybe smooth out the spot weld holes with a dab of bondo and repaint.
I've been planning to do this same thing on the 130, but just haven't "gotten around to it".
Old March 5th, 2015, 10:20 AM
The NAS Defender 90 sills are galvanized but the NAS 110 sills are not, right? I could swear mine are galv but that I've seen some of the flippers fill in the area with bondo on NAS 110s (it looked terrible, btw) and covered with fresh paint.
Old March 5th, 2015, 10:25 AM
Correct, galvy on the NAS90 but the NAS110s still have that tube/lip. If you want to remove that lip, you're going to have exposed spot-weld holes so filling it is probably the best option (though I'm not a big fan of bondo either). I *think* Barry did this on his old NAS110 if I recall, and when done right it doesn't look bad. In my opinion, it's much better than the hideous lip/tube (and that is prone to catch moisture/etc anyhow).
Old March 5th, 2015, 11:14 AM
bjf's Avatar
bjf
barry f
94 ST #395
Correct I did it and moved the seals to the bottom of the doors.
The issue is where does the rust stop. My truck was fairly rust free. I removed the lip and grinded the meta down. It then looked all pock marked but was easily fixed with a light skim of bondo followed by paint.
Old March 5th, 2015, 11:35 AM
doing a quick bondo search by your name pulled this up.
http://www.defendersource.com/forum/...ust-26670.html
and wow this old gem! I love how much bondo is on your old truck and how quickly this thread went downhill.
http://www.defendersource.com/forum/...r-19444-2.html
Old March 5th, 2015, 11:54 AM
Those were the classic Barry days. He has mellowed considerably with age.
Old March 5th, 2015, 12:19 PM
cbfritz_03
Carmen
none
Take the old one out and replace it with a new galvy one.. powder coat it too if you want. I'd be making sure that the corrosion didn't get any farther than that, like to your floor. Just say NO to bondo ... not a fan.
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
The dreaded 30 second blinking oil light at startup - anyone have a fix for this? solihul Defender Technical Discussions 10 December 2nd, 2004 01:39 PM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
Cracked Cat - fix? (pic) wicks Defender Technical Discussions 14 May 20th, 2004 12:17 AM
How to fix squeeky suspensions??? JRowe Defender Technical Discussions 1 February 4th, 2004 06:29 PM
