gun case fabrication - Defender Source
Old April 21st, 2013, 09:15 AM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
Im thinking of having a gun case fabricated that will fit under the 2nd row in the 110. I'd like a side access door under the left hand 2nd row seat. It would be just big enough to hold one rifle or shot gun with a tuffy-style lock. Has anyone else done this?
Old April 21st, 2013, 11:18 AM
Spanner110
I
1993 Defender Pick up
similar, I had a weapons locker mounted in the enclosed back of the 110 CSW along with a separate ordnance safe. Totally out of sight and didn't take up too much of the load bed (which is more than can be said for the Hi-Lift jack that was bolted to the front of it)
How will you access your guns? I am imagining them just stuffed into the void! Have you thought about a purpose built slide out tray that they are clipped to? there would even be room for boxes of shells etc with that configuration. With a bit of careful measuring and clever design input there is no reason why you couldn't fit four or five guns in the space available.
Old June 1st, 2013, 03:25 AM
alkhalifa's Avatar
alkhalifa
Nasser Al-khalifa
2001 Defender 90
Spanner110 do you have pic?
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
rivnut gun mattdh Defender Technical Discussions 6 March 30th, 2004 06:46 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
