Goat surgery - Page 7 - Defender Source
Old June 1st, 2010, 08:08 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Great minds think alike, I was going to do exactly what you described. The insides of the door posts are absolutely hosed with waxoyl clear wax too. I'm thinking of making my own or adapting some sort of plastic mudshields instead of the stock ones.
Old June 1st, 2010, 08:19 PM
Ike Goss fabbed up some aluminium ones on my series truck (he made the fenders). They flare down lower so that nothing can get up in that area. If I can make my way to the back of my garage and remember when I am out there, I will take a picture or two.
Old June 3rd, 2010, 05:50 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Ive been running a spacer (3/16") behind the mudsheilds where they bolt to the bulkhead which allows the dirty stuff to fall through.....especially if helped by pressurized water.
Matt Browne
Old June 3rd, 2010, 11:05 PM
That'sa good idea. I've always done the same but just with plain washers. It isn't really enough space though. John Gerding at Forever Rover made some nice S.S. ones that went down much lower covering more of the toebox.
The one time I didn't install a mudshield I ended up having to do quite a bit of welding about 5 or 6 years later.
Old June 6th, 2010, 10:06 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Heater blower and core mounted on the passenger toebox, couple of new pieces of heater hose and the radiator filled back up. Cleaned and reoiled the K&N, mounted new SS fuel tank and reinstalled sender and pick up, new electric lift pump mounted on top of frame rail inboard of tank, clutch piping locked down and refilled, engine bay wiring all hooked back up. Got the yellow topped charged up and should be turning the key in a day or so, then the wings and lights. Seatbox and dash completion after that.
Old June 7th, 2010, 08:22 AM
LFORGUE8
Lucas Forgue
2011 Rangie
sweet to hear Kevin....that great day when you start it up again! love that day!
59 SII....on the back burner!
11 Rangie
Old June 7th, 2010, 08:25 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Debut at SVTX?
Old June 7th, 2010, 09:24 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
No, too soon to push it like that even if it was driveable. Needs an inspection too.
Old June 7th, 2010, 06:56 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It runs!
Old June 7th, 2010, 09:13 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sort of, I think I got the timing off by a tooth. Nothing to do but go back inside and check it out.
Old June 8th, 2010, 11:15 AM
LFORGUE8
Lucas Forgue
2011 Rangie
Originally Posted by kevinny View Post
sort of, i think i got the timing off by a tooth. Nothing to do but go back inside and check it out.
thats the worst! Good luck
11 Rangie
Old June 8th, 2010, 03:07 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
WOW, I dodged the bullet! Went back in and found that I was one tooth off on the timing belt thanks to counting from a smudge on the crank gear rather than the timing dimple. Reinstalled belt, closed it back up and turned the key with fingers and toes crossed and it started on the first turn of the key with the old familiar rumble of a perfect idle! I better go to church soon.
Old July 19th, 2010, 06:54 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
make sure you pray to the right god. The one with dirty fingernails.
Matt Browne
Old August 8th, 2010, 08:21 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I have not updated this in a while but the work has continued. It's pretty much all back together and has passed inspection. Everything works as far as gauges and switches and it's running great. Finished the paint (just the tub) on Friday. I now need to put the doors back together and on as well as the trim bits like sliders, winch, CB antenna, corner protectors, raised intake and roll bar. That and install the new ARB compressor under the seat. Need to adjust the fit of the passenger wing and radiator panel so the hood will latch properly too.
Old August 8th, 2010, 08:56 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Looks great, Kevin. I think you made the right decision on color.
Old August 9th, 2010, 03:46 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Wow Kevin - looking good ...
Old August 9th, 2010, 05:12 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I really like that paint job a lot! the black accents really make the combination work great. Have you thought about changing out those RRC rims for some series steelies? just a thought. Overall, looks sweet!
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 9th, 2010, 05:16 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I think LR alloys are one of their most underrated accomplishments, they hold the SSR's like friggin beadlocks. I would not want to go any narrower either.
Old August 9th, 2010, 05:24 PM
I was partial to the yellow, but do like that color. Looking forward to seeing more pictures once the doors are on.
Old August 9th, 2010, 07:39 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I tried to get a better shot of the paint finish, I'll take beauty shots once it's all trimmed out. I'm really happy with the color and the almost flat finish.
ID:	30009   Click image for larger version
Iron Goat Dash CDeWan Defender Technical Discussions 16 September 3rd, 2013 10:30 AM
Iron Goat Dash Overlander For Sale - Parts 5 February 21st, 2008 11:54 AM
Iron Goat dash? JackW Defender Technical Discussions 12 September 29th, 2007 06:55 PM
Rotator cuff surgery Rover- Girl Misc. Chit-Chat 13 June 28th, 2006 02:19 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
