Goat surgery - Page 4 - Defender Source
Old February 18th, 2010, 03:07 PM
something I never thought about.I can see how the galv acts as a seam selaer, but if it doesn't, or if the seam opens due to flex and vibration then you will have issues. The seam sealer is pretty important on bulkheads to keep the water out. I had a few inches of sealer come off on my 90 and I started getting water in all kinds of places. Redid the sealer and no more issues. Similar problem on my 109 where the sealer had failed and I ended up replacing the upper part of one of the footwells.
Originally Posted by evilfij View Post
Last night I wandered out to the garage to look at my galvanized bulkhead and it appears as though the zinc has acted as a seam sealer of sorts and capped off a lot of the gaps where two pieces of sheet metal go together. Not sure if it will eventually crack, but I thought it was worth noting. I am still not planning on painting anything, but I will probably spray some waxoyl in just because (even though I doubt I will have an issue given my location and use).
Old February 24th, 2010, 02:18 PM
LFORGUE8
Lucas Forgue
2011 Rangie
Kevin any updates.....or pics from Matt's refurb of the bulkhead?
59 SII....on the back burner!
11 Rangie
Old February 24th, 2010, 03:22 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Nothing new really. I started into the timing belt change but need to go get a puller to remove the crank pulley. From the looks of things so far, it seems that the belt has never been changed before contrary to what I had been told.
Old February 25th, 2010, 06:39 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I've had some issues with the replacement bulkhead parts......which after a long wait have turned out to have center sections built all wrong and has buggared up the whole process. I've got six bulkheads in the que and KB's is next in line. Hope to have it sorted by next week and then I can get KB's onto the jig.
Be patient KB....not with me, the crank pulley.
Matt Browne
Old February 25th, 2010, 09:01 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Soaking in Kroil right now MB. 2 of the 6 bolts that hold the outer pulley to the crank pulley are larger, I suspect these are for a factory tool gear puller, something I can rent down at Autozone.
Old February 26th, 2010, 08:12 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
fawkin kroil.....I don't know what I'd do without that stuff. That and the "red wrench", which is not much help with crank pulleys.
Matt Browne
Old February 26th, 2010, 09:08 AM
LFORGUE8
Lucas Forgue
2011 Rangie
is that kroil better than rost-off? ive had really good luck with that stuff from wurth...........also rover came out with a "silicone" spray for removing problem o2's and that stuff is like liquid red wrench!
11 Rangie
Old February 27th, 2010, 06:36 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Crank pulley off thanks to the proper tool. Pretty darn similar to the LR diesels as you can see. Just need to rotate the engine to line up the timing marks and then relax the tensioner to swap the belt.
Old February 27th, 2010, 08:37 PM
Looks in good shape in there!
Don't take this the wrong way Kevin, but kind of glad to see a human pace on your project. Some of the guys doing builds are machines...
Old February 27th, 2010, 09:02 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
No offense taken at all, I get what your saying. I did this in winter so I would not be rushed to get back on the road, no wheeling now anyways. Between work and this little guy I don't have a ton of free time to spend in a cold garage lately but the pace will pick back up again in the coming weeks.
Old March 4th, 2010, 11:16 AM
Cute kid KB. Like father like son. Heartwarming!
Old March 4th, 2010, 11:41 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
LOL! Thanks for the laugh Dave, I needed it today.
Old March 4th, 2010, 09:17 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Isn't it like 5 weeks to the first wheeling runs? I see some late night wrench parties coming up ;-)
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old March 4th, 2010, 11:28 PM
Don't blink or you'll be looking at this...
Oh and I dunno what this 5 weeks nonsense is, I'm wheeling this weekend at Rausch Creek!
ID:	25545   Click image for larger version
Old March 5th, 2010, 04:37 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
New timing belt is in and bumper, sliders and Matt Brownes custom radiator support (neccessary with the PS conversion) are back from the galvanizer after a hot dip and powdercoat.
Old March 26th, 2010, 09:45 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
As promised (finally) some before pics off the bulkhead
ID:	26028   Click image for larger version
Matt Browne
Old March 27th, 2010, 05:24 AM
Any progress to report over the last 3 weeks Kevin?
Old March 27th, 2010, 09:17 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Just little things. Scrape , grind and prime some rusty patches on the door frames, started sanding panels. Fuel tank to fabricators to recreate in SS. Replacing some small hoses etc.
Old April 15th, 2010, 04:12 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Matt has my bulkhead cut up and ready for new parts but is having supplier problems with replacement parts being ill fitting. I picked up my new fuel tank today. Gone is the crusty box replaced with this SS beauty.
Old April 15th, 2010, 04:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Forgot the pic.
Iron Goat Dash CDeWan Defender Technical Discussions 16 September 3rd, 2013 10:30 AM
Iron Goat Dash Overlander For Sale - Parts 5 February 21st, 2008 11:54 AM
Iron Goat dash? JackW Defender Technical Discussions 12 September 29th, 2007 06:55 PM
Rotator cuff surgery Rover- Girl Misc. Chit-Chat 13 June 28th, 2006 02:19 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
