Goat surgery - Page 3 - Defender Source
Old January 22nd, 2010, 07:39 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Well one of the door posts collapsed when I was loading it into the Land Cruiser if that gives you a hint. Previous owner didn't know how to use a hose apparently. The bottom of the door posts and the outer side of the toe boxes are totally rotten, exactly what happens when you leave them packed with wet mud.
Old January 23rd, 2010, 05:57 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I'll take some pictures on Monday
Matt Browne
Old February 6th, 2010, 02:12 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Bulkhead is at Matt's for some love, meanwhile I dropped the fuel tank today. You can see how it is basically an ordinary series tank with the inside edge chopped off to clear the rear link mount. It is going to a local radiator guy who will boil it out and beadblast it for me. Then is getting internally sealed with a kit from KBS coatings and painted with Eastwood chassis black before going back in.
ID:	24980   Click image for larger version
Old February 6th, 2010, 02:18 PM
sn1987's Avatar
sn1987
Sandy
2008 D110 SW <3<3
i have nothing to say except that Kevin's yellow series is freaking awesome :-O
Old February 6th, 2010, 03:25 PM
This is why I don't understand why people don't galvanize the bulkheads. I don't care how much paint or sealer you put on it, galvanizing is 10x better at fending off rust. Dip it and forget it.
Old February 7th, 2010, 11:54 AM
LFORGUE8
Lucas Forgue
2011 Rangie
was that bulk head prepared by ECR to begin with.....with their dunk tanks? i have to agree galvy should be the way to go when i ever get to mine on my series....
59 SII....on the back burner!
11 Rangie
Old February 7th, 2010, 11:59 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The truck was done in '96 by ECR and had bulkhead repairs done since then by a second owner. They may have not done the dunk primer back that far.
Old February 9th, 2010, 07:37 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Looks Good Kevin... At this point, just strip it down and redip the frame to look all shiny again. I always end up over doing everything... lol
Legend in My Own Mind.
Old February 9th, 2010, 10:47 AM
That would be merely cosmetic.
Old February 13th, 2010, 03:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I know Ron... I have problems... Im so shallow. I should consider more that just looks...lol
Old February 15th, 2010, 03:37 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Rockware bumper stripped and vent holes drilled for the galvanizer. I use 7, 3/4" holes across the bottom of the blade with the corner ones as close to the ends as possible. The sliders were sandblasted by a neighbor who has a booth.
ID:	25220   Click image for larger version
Old February 17th, 2010, 07:11 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Galvanizing is not the cure all for frames or bulkheads. Galvy will not get into the gaps between overlapping layers of steel if they are smaller than 3/32 ". I have galvy frames show up at the shop with rust drooling out of cavities and areas in the rear crossmember. I'm not saying don't do it as I have done many at this point, and some of the trucks I build seem to have more galvy than paint. The point is that most of the rust issues can be solved by keeping internal cavities as clean as possible and by treating with a good rust preventative coating such as Waxoyl cavity wax. You certainly cannot "dip it and forget it.
Matt Browne
Old February 17th, 2010, 11:52 AM
"I have galvy frames show up at the shop with rust drooling out of cavities and areas in the rear crossmember."
I don't doubt you because I have seen runs of rust on galvy stuff a but everytime I have seen it, it is merely cosmetic and also the zinc acts as an annode or cathode (I forget which) and corrodes before the steel for the most part. Also, there are not a lot of areas where this can occur (the two stacked pieces of steel at the bottom of the cross member in the rear comes to mind). Now as far as dip it and forget it, I disagree, because as a practical matter you really can short of parking in the ocean or maybe using it as a working vehicle as a salter and plow. I have a galvanized series rear cross member that was on a truck in buffalo for >15 years and it is perfect other than being a dull grey color and a couple specs of rust where stones chipped the galvanizing off. I also have doors and cappings off of a 1951 SI that have no corrosion (just very, very dull grey) but the bulkhead itself is lace. I had a galvanized series bumper I left outside and it got burried for a few years and, you know what, no rust.
So until someone shows me a picture of a galvanized frame that has structural rust or a bulkhead someone properly prepped and dipped that is rusted out in any meaningful way, I stand by my Rover Chrome and will be dipping it and forgetting it
Old February 17th, 2010, 02:27 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Yeaaahhh... But no.
I have a bulkhead that has seen 5 years of ontario winters and it is starting to rust through in places. Was done by Argo Coatings in Nova Scotia. I sandblasted it and prepped it. It is coming through at the top near the hinge where there are 5 thicknesses of metal. I can take pics but it's pinholes right now. I am junking it so I can cut it apart to investigate. This is on a salt-covered worked hard and put away wet beater that has plowed snow so it is probably a worst case scenario.
JL
Old February 17th, 2010, 02:33 PM
JL, I would like to see pictures.
Was it new when it was blasted and dipped? I can certainly see how a bulkhead that has interior rust (which you can't get at with a blaster) could rust away inside out after being dipped.
Ron
PS BTW if you are junking it and it is a defender/90/100 bulkhead, why don't you not do that and sell it to me.
edit: can we at least agree that galvanizing is better than any form of paint?
Old February 17th, 2010, 05:05 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Ron
1966 109 bulkhead, sandblasted through pockets in door pillar and through the front fold, then pickled in acid and dipped. They were never painted inside and the acid wash would remove all the rust. The bad prep work argument does not fly as the inside everywhere but where there are multiple thicknesses is mint, even where no sandblast sand has gone before. Matt has a point that the stuff just does not penetrate between the multiple spotwelded thicknesses. I do 100% agree that it is the best treatment though. With real rustproofing a galvanized bulkhead should last ten years at least in my climate, which means 50 years + anywhere where salting is not a national sport.
I should clarify that it has a bent doorpost or I would run it for another 5 years at least.
JL
Old February 17th, 2010, 07:07 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
No.
Our dunk tanks didn't exist until Chris Komar worked at the shop and came up with that thought and made them. That was years later.
The yellow 88 was the second coil 88 we ever built and it started life as a nice solid truck that got a chassis and paint work, bulkead was "as found" but painted yellow from its original pastel green.
Each project is done to the customers work orders and their budget. Just because we built it doesn't mean it underwent a full restoration. If we had it to do again with all we have learned it would have a lot of changes from SS brake pipes to our SS coil gas tank and much more... but then again that would depend on the customers budget and what he/she wanted.
Kevin, nice to see the old girl getting a new lease on life with you. Great job!
------ Follow up post added February 17th, 2010 07:23 PM ------
I've got a folder full of photos from that truck at the old shop. I should dig them out and send them to you for "history" of the beast.
Email:
Old February 18th, 2010, 07:45 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Depending on where applied I would agree 100%. Bulkheads are still going to be iffy at best and will require an additional rustproofing of some sort and a carefull eye toward maintenance.
I'm a big fan and will always galvy anything I reasonably can including every bit of steel that is bolted to the frame and all door frames and internal bits, hood frame, shock towers, coil buckets, etc etc..........starting with a bare 110 that amounts to an additional 347lbs of zinc (well, on the last one I measured....they are all different). Just feel the need to assert that it is not a dip it and forget it sitiuation as far as the bulkheads are concerned. You'll be disappointed, and in fact will be fairly quickly disappointed as rust will develop readily in a galvanized defender bulkhead which is not the case if seam sealed, painted and waxoyled.
The last bunch I have done are galvanized, painted, seam sealed and waxoyled (cavity wax). we will see how that works. I have one living on one of the saltiest islands in the world.
Matt Browne
Old February 18th, 2010, 10:46 AM
Well whatever you do hopefully the "Previous owner" has learnt how to use a hose and won't leave the bottom of the door posts and the outer side of the toe boxes packed with wet mud again.
Old February 18th, 2010, 01:21 PM
Last night I wandered out to the garage to look at my galvanized bulkhead and it appears as though the zinc has acted as a seam sealer of sorts and capped off a lot of the gaps where two pieces of sheet metal go together. Not sure if it will eventually crack, but I thought it was worth noting. I am still not planning on painting anything, but I will probably spray some waxoyl in just because (even though I doubt I will have an issue given my location and use).
Iron Goat Dash CDeWan Defender Technical Discussions 16 September 3rd, 2013 10:30 AM
Iron Goat Dash Overlander For Sale - Parts 5 February 21st, 2008 11:54 AM
Iron Goat dash? JackW Defender Technical Discussions 12 September 29th, 2007 06:55 PM
Rotator cuff surgery Rover- Girl Misc. Chit-Chat 13 June 28th, 2006 02:19 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
