gear box supports? 300tdi - Defender Source
Old March 24th, 2013, 04:17 PM
defenderizl's Avatar
defenderizl
leon bonhomme
defender 110
Fist a little introduction. I,m doing a chassis swap on a 300tdi def 110.
Originally the 110 came with a 2,5na. Diesel/lt77 gearbox.
This was changed over to 300tdi/r380 gearbox. I changed the engine mounts took the transfer case from the lt77, and bolted everything straight in.
Swapping the chassis now confronts me with the problem that the supports for the transfer case on the chassis don,t seem to fit. (marsland
chassis)But other mounts appear to be there.
Do any of you guys know what i can do. Some pics to clearify.
Leon
ID:	68932   Click image for larger version
ID:	68934   Click image for larger version
ID:	68938   Click image for larger version
ID:	68940   Click image for larger version
Old March 24th, 2013, 04:19 PM
defenderizl
leon bonhomme
defender 110
For some reason i doubled some of the foto,s
Old March 24th, 2013, 05:12 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Disco or Defender mounts?
Leon:
Have run into similar issues when removing an LT77 and 2.25 or 2.5 4 cylinder engine and replacing it with a Disco 300TDI & R380 into a 90 or 110.
I can take some pictures for you when it stops raining, but I keep all my transmission mounts in a box and just pull out the box and pick what works when doing an install, but think the disco mounts are different from the Defender on the R380.
Did you get the bolt on metal mounts with your R380 transmission?
The old LT230 T-case, is a 1.6 and will be geared too low for a 300TDI.
Hope this helps.
RDavisinVA
Old March 24th, 2013, 05:21 PM
defenderizl
leon bonhomme
defender 110
I Didn't change the chassis/transfer case mounts. This seems to be the problem. Do you think changing the transfer case will solve it and what kind do i neef instead of the lt 230 t
Old March 24th, 2013, 05:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Divide questions?
The LT230 mount looked different from the RR Classic and the Defender when I just crawled under 2 of them outside in the rain... it's OK because am about to quit for the day. I could be wrong as some of the mounts had the same positions, but look different.
BUT
The 300TDI mount on a 110 looked very different from the ZF automatic mount on the RR Classic. so you didn't answer if you got the R380 metal mount and if your setup came from a Defender 300TDI/R380 or a Disco 300TDI R380 as I think those rear mounts are different.
The LT230 came in many different ratios:1.6 is one of the lowest (used with 2.25 and 2.5 engines), then 1.4 with 200 - 300 TDI, then 1.22 used with V8 and TDI automatic setups. There were others, but these are just general rules for the gearing. You need a 1.4 LT230 or a 1.2 if you are in a flat area.
I have a dutch friend we can conference in if you want to make a 3-way call. I can bring him in at this end to eliminate translation issues...
RDavisinVA
Old March 24th, 2013, 05:59 PM
defenderizl
leon bonhomme
defender 110
Thanks for all your effort.
To correctly answer your questions as best as i can.
300tdi is from a disco
R380 was a reconditioned unit from a defender.
The transfer case stayed in its place.
The problem only occured when i frist looked at my new chassis. These mounts will never fit the old case
From your info i can conclude that i need to change the transfer case anyway. Will this solve the situation
------ Follow up post added March 24th, 2013 04:01 PM ------
I,ll sleep over it anyway. But thanx for the 3 way solution
Old March 24th, 2013, 06:06 PM
380/lt230 mounts are different than the lt77 mounts. If you didn't change those when you made your first conversion that explains why things don't line up with the new frame.
Old March 24th, 2013, 06:29 PM
defenderizl
leon bonhomme
defender 110
I was concluding this myself also. The question now is do you know which mounts (part nummer) i should use with a different case,(1:4) to make it fit the marsland chassis
300tdi, tdi
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
gear box jimmy salmon Defender Technical Discussions 4 June 8th, 2005 04:18 PM
